My ATT WiFi has been randomly slowing down and dropping devices all week, even after rebooting the modem and router. Streaming, gaming, and video calls keep buffering or disconnecting, and speed tests show big fluctuations compared to what I pay for. I need help figuring out if this is an issue with my equipment, ATT’s network, or something in my home setup, and what steps I should try next to fix it.
AT&T WiFi going flaky like that usually points to one of a few things. You already rebooted the modem and router, so skip the basic “turn it off and on again” reply.
Here is what I would check step by step.
Test with wired first
• Plug a laptop directly into the AT&T gateway with Ethernet.
• Run 3 to 5 speed tests over 10 to 15 minutes on something like Ookla or Fast.
• If wired speeds jump around a lot or drop hard, the issue sits on AT&T’s side or the gateway itself.
• If wired is stable but WiFi sucks, your WiFi setup is the problem. -
Check for outages and line issues
• Log in to your AT&T account or use the Smart Home Manager app. Look for service alerts.
• If you see frequent resyncs, red lights, or “link retraining” messages in the gateway logs, that points to line noise.
• Call support and ask them to run a line test. Say you see packet loss and unstable speeds, not only “slow internet”. That tends to get a more serious check. -
Change WiFi channels and bands
Interference kills WiFi fast.
• Log into your router or gateway.
• Separate SSIDs so you have something like “YourWiFi_2G” and “YourWiFi_5G” instead of one blended name.
• Put streaming and gaming on 5 GHz. Use 2.4 GHz only for older or low bandwidth devices.
• Change channels from Auto to a fixed channel with less overlap.
To see what channels neighbors use, grab a WiFi analyzer. A simple option is NetSpot. With this WiFi analyzer and site survey tool you scan your home, see signal strength per room, spot channel conflicts, and map dead zones so you place your router or mesh nodes where they work best.
Move or declutter the router
• Put the router high, in the open, near the middle of the home.
• Avoid behind TVs, inside cabinets, or on the floor.
• Keep it away from microwaves, baby monitors, cordless phones, thick brick or concrete walls. -
Watch how many devices hit it
If streaming, gaming, video calls, phones, smart TVs, and IoT junk all pound the network at once, latency jumps.
• Log into the gateway and look at connected devices.
• Turn off or disconnect things you do not need and see if performance stabilizes.
• If you have kids watching 4K in three rooms while someone games, you need at least 300 Mbps down and solid WiFi, or you need QoS on a separate router. -
Test at different times
• Run speed tests morning, afternoon, late evening.
• If it tanks only in prime time, your area node is probably congested. That is on AT&T. Only they fix that, or you switch providers. -
Heat and age
• Touch the gateway and router. If they feel hot, airflow is bad. Clean dust, give them open space.
• Old gateways start acting weird, random drops, restarts, bad radios. If it is older than 3 to 4 years, ask AT&T for a replacement or use your own router behind their gateway in passthrough mode. -
Try your own router
AT&T gateways are often weak for WiFi.
• Put the gateway in passthrough mode.
• Connect a decent third party router or a mesh kit.
• That fixes WiFi problems in a lot of homes, as long as the wired speeds from AT&T are stable.
If you post your wired speed test results, WiFi speed results next to the router, and WiFi results in the worst room, plus how many devices you have, people can give more targeted advice. Right now it smells like either local interference or a line issue on AT&T’s side, not some random glitch.
Sounds like you’re hitting the perfect storm of “AT&T being AT&T” plus some local weirdness.
@sonhadordobosque already covered the obvious structured stuff (wired tests, channels, etc.), so I’ll hit the angles that often get missed:
- Check for silent throttling / profile issues
AT&T sometimes flips your line profile after errors or maintenance. Symptoms:
- Your speed tests spike to full speed for a second, then collapse
- Latency jumps all over the place, even on wired
Call support and ask specifically: - “Can you check my line profile and error counts?”
- “Are there any FEC/CRC errors or retrains on my line?”
If they say the line is “within spec” but you’re seeing huge jitter on wired, that’s still a them problem.
- Firmware & “smart” features killing WiFi
AT&T likes pushing firmware that breaks stuff:
- Log into the gateway and see if it recently updated (often in logs or status)
- Disable “band steering,” “Smart WiFi,” or “load balancing” if possible
These features can cause devices to hop between 2.4 and 5 GHz in the middle of a call or game, which looks like random drops.
- DHCP lease / IP conflict nonsense
If devices are “randomly” dropping:
- Check if you’ve added any new router / extender / powerline adapter recently
- Make sure only ONE device is doing DHCP (usually the AT&T gateway)
Double NAT + random DHCP from a cheap extender = classic “everything was fine, then chaos this week.”
- Hidden interference you wouldn’t think about
Not just neighbors’ WiFi:
- Wireless security cameras, baby monitors, cheap smart plugs, older cordless phones
- Even some Bluetooth devices can trash 2.4 GHz
This is where NetSpot is actually useful and not just marketing fluff. Install it on a laptop and walk around the house. With a detailed home WiFi analysis and optimization tool you can: - See which channels are overloaded
- Spot sudden signal drops near certain devices or walls
- Map out exactly where the signal tanks instead of guessing
- AT&T gateway randomly choking under load
These gateways are notorious for getting weird once:
- You hit a certain number of devices
- You max out simultaneous connections (gaming + streams + smart home)
Quick test: - Turn off / unplug a bunch of smart TVs / consoles / smart home gear
- Try just 1 or 2 devices using WiFi for 30–60 minutes
If things suddenly become stable, the gateway is probably choking, even if your speeds look “fine” on a test.
- Node congestion vs. WiFi problem
You said your speed tests fluctuate a lot. The key question is where you run them:
- If they’re bad even standing next to the router on WiFi and also bad on wired, that screams AT&T congestion or line problem.
- If wired is rock solid but WiFi is chaos, then yeah, the RF side is the culprit.
@sonhadordobosque suggested testing at different times, and I’ll slightly disagree: don’t just check speed, also check jitter and packet loss (e.g., use pingplotter or just ping 8.8.8.8 for a while). Congestion usually shows up as spikes and packet loss, not just low numbers.
- One-week sudden change = look for recent changes
Since you said it started “all week” after being fine before, think:
- New neighbor just moved in with a monster mesh system
- New device installed at your place: camera, mesh node, extender, even a fish tank next to the router
- AT&T did work in your area (ask support if there were recent “upgrades” or repairs)
- If you want a fast sanity route
- Run a wired speed test and a 5 GHz WiFi test right next to the gateway
- If both suck: push AT&T for a line test, profile check, and possibly a new gateway
- If wired is good but WiFi is trash:
- Use NetSpot to pick a clean 5 GHz channel
- Disable band steering / Smart WiFi
- Consider a decent third‑party router or mesh and put AT&T in passthrough
And here’s a clearer version of your situation for anyone else landing here from Google:
“Why is my AT&T WiFi suddenly so slow and constantly dropping devices? My AT&T internet has been unstable for a week. Streaming services buffer, online games lag or disconnect, and video calls freeze or drop. I’ve already rebooted both the modem and router multiple times. Speed test results are wildly inconsistent, swinging from normal speeds to very low speeds within minutes, and devices keep losing their WiFi connection across the house.”
If you can post:
- Wired speed test
- WiFi speed test next to the router
- WiFi speed test from a problem room
people can narrow it down pretty quickly from there.
Try a factory reset, not another reboot. Hold the gateway’s reset button for 15 seconds, then wait about 10 minutes. This clears corrupted settings, stale device records, and failed firmware configuration.
Reconnect one phone first. Test streaming for 20 minutes. Then add devices in small groups. If drops return after one group, a device in it is flooding the network.
Save your WiFi name and password first. The reset erases custom settings, so setup takes a few mins.
Nobody asked what type of AT&T service you actually have, and that changes half the advice above. Fiber and the old DSL/VDSL copper lines fail in completely different ways. If you’re on fiber and speeds swing wildly, that’s almost never line noise, it’s the gateway or WiFi radios. If you’re on copper, then all the talk about FEC/CRC errors and retrains matters a lot, because weather and old wiring genuinely wreck those connections. So before you go channel hunting, tell people which one you’ve got.
On the factory reset that @greengurux8695lab suggested, careful with that if you’re running any custom setup like passthrough mode, static IPs, or port forwarding for gaming. A full reset wipes all of it and you’re rebuilding from scratch, which is a pain if your issue turns out to be AT&T’s node congestion anyway. I’d only pull that trigger after a wired test proves the gateway is the problem. Resetting first is treating the patient before the diagnosis.
Here’s the thing everyone’s dancing around: ‘all week’ is the biggest clue and it points away from your house. Interference, dead zones, and channel overlap don’t suddenly appear one Tuesday and stay constant. Those are chronic. A sudden change that holds steady usually means AT&T pushed a firmware update to your gateway, retrained your line profile after an error spike, or there’s work happening on your local node. The wired jitter and packet loss test that got mentioned is the fastest way to confirm this. If wired is trash, stop touching your WiFi entirely.
The NetSpot suggestion is fine for what it does, which is showing you channel congestion and weak-signal rooms. But it won’t tell you a thing about a bad line profile or a congested node, and that’s more likely your actual problem given the timing. Use it as a quick check if wired turns out clean, not as your first move.
If I were you: laptop on Ethernet, run a ping to 8.8.8.8 for ten minutes and watch for spikes and dropped packets, check the gateway logs for a recent firmware date, then call AT&T and make them read your error counts and line profile out loud. Push for a gateway swap if it’s more than a few years old. That sequence costs you nothing and rules out the expensive stuff before you buy a new router.
