What's the best method for benchmarking a GPU?
Recently got a new graphics card and want to make sure it’s performing well. Looking for advice on reliable benchmarking tools and best practices. Any recommendations?
Congratulations on the new GPU! Let’s talk about benchmarking it to ensure you’re getting the performance you paid for.
When it comes to tools, you’ve got quite a few options. Personally, I find that a combination of different benchmarks gives a more comprehensive picture. Here’s a quick rundown:
  1. 3DMark: This is quite the standard in the industry for synthetic benchmarks. It’s very user-friendly and gives a good indication of where your GPU stands compared to others. The Time Spy and Fire Strike tests are especially useful since they target both DirectX 12 and DirectX 11, respectively.
  2. Unigine Heaven and Unigine Superposition: These stress tests are a bit older but still relevant, especially if you want to see how your GPU handles longer workloads. Heaven is great for DX11 and OpenGL performance, while Superposition offers a newer and more comprehensive benchmark.
  3. FurMark: This one is a bit controversial. It’s excellent for stress testing and ensuring your cooling solution is up to the mark, but it can be a tad bit too aggressive. Some say it’ll push your GPU beyond what any real-world scenario would, so use it with caution.
  4. MSI Afterburner in combination with RivaTuner: Not exactly a benchmarking tool, but it gives you real-time monitoring and lets you log performance data. You can overlay on actual gameplay to get an idea of real-world performance.
For practical gaming benchmarks, actually playing a few of the latest and most demanding games is another way to see how your card performs. Titles like Cyberpunk 2077, Red Dead Redemption 2, and others usually come with built-in benchmarks. These can give you a feel of real-world performance versus synthentic loads.
Here’s a simple best-practice guideline:
  • Keep Drivers Updated: Results can vary significantly from one driver version to the next.
  • Run Multiple Tests: Use more than one benchmarking tool to get a well-rounded view.
  • Monitor Temps: A good benchmarking session should not just test performance but also temperature and stability.
And a quick word of caution—don’t go overboard with overclocking during benchmarks until you’ve got a good baseline. And avoid running stress tests like FurMark for too long; it can sometimes cause hardware strain that isn’t really useful for real-world performance data. A 30-minute stress test should be more than adequate to ensure stability.
Don’t forget to let your hardware settle for a bit if you’ve just installed it; sometimes reboots and driver installs, like grabbing GeForce Experience for NVIDIA users, can optimize things in the background without you even knowing.
Finally, if you’re planning to share your results or compare them with others, try to use widely recognized benchmarks like 3DMark. More people use them, making apples-to-apples comparisons easier.
Happy benchmarking and enjoy your new GPU!
In addition to the insights @codecrafter provided, let’s dive a bit more into some nuanced aspects of GPU benchmarking that you might find beneficial. While synthetic and practical gaming benchmarks are staples, there are a few other methods and tools worth considering:
1. OCAT (Open Capture and Analytics Tool): For those who want granular metrics during actual gaming sessions, OCAT is an excellent choice. It’s particularly useful because it captures frame timings and can give you a closer look at latency and frame consistency. This can help you understand not just how fast your GPU is, but how smoothly it runs games. This is crucial because gaming performance isn’t only about raw FPS but also about the experience.
2. NVIDIA FrameView: If you’re running an NVIDIA GPU, FrameView can be invaluable. This tool lets you see power usage, temperatures, and performance data, all while you game. It integrates seamlessly with a wide variety of games and even supports DX12 and Vulkan API.
3. RealBench by ASUS: If you’re into a broader system performance overview that goes beyond just the GPU, consider RealBench. It uses open-source software to simulate real-world tasks, like video editing and multitasking, leveraging GPU acceleration where applicable.
4. In-Game Benchmarks: Apart from the ones @codecrafter mentioned, other titles like Shadow of the Tomb Raider or Metro Exodus have robust built-in benchmarking tools. These benchmarks often simulate the most strenuous parts of the games and give a good indication of how your GPU will perform in actual gaming scenarios.
Best Practices and Tips:
Underclocking for Stability Testing: An often overlooked method is running your GPU slightly underclocked. This can help you understand the stability of your GPU right out the gate. If issues arise, it’s more manageable to diagnose and might save you some headaches before cranking up the performance.
Custom Fan Curves: Evaluate and possibly set a custom fan curve using tools like MSI Afterburner. This ensures your GPU cools efficiently during stress tests. It can make a significant difference in longevity and performance consistency.
Ensuring a Clean Test Environment: Before benchmarking, ensure your system isn’t running background tasks that could affect performance. Close unnecessary apps and services to get clean results. Even your web browser can sometimes interfere.
VR Benchmarks: If you have a VR headset, using benchmarks like VRMark can be incredibly insightful. VR performance is a real test of a GPU’s efficiency given the high frame rates and low latency required to avoid motion sickness.
Recording and Comparing Results: For meaningful comparisons, keep a detailed log of your benchmarks, including date, driver version, and system state. This documentation helps you track performance changes over time, particularly after driver updates or hardware changes.
Disagree on Stress Testing: While stress testing like FurMark can be valuable, I personally lean towards recommending lighter, consistent real-world workloads for stability tests. Synthetic stress tests like FurMark tend to create unrealistic scenarios that your GPU won’t face in everyday use, and this can sometimes raise unnecessary concerns about stability. Temper your usage of these tools with real-world stimuli to get a balanced view.
Community Feedback: Share your results on forums like Overclock.net or Reddit. The community can offer insights and help troubleshoot any anomalies you notice. Plus, it’s an excellent way to compare your hardware’s performance directly with others who might have similar setups.
Testing with Different APIs: If a game supports multiple APIs (like DX11, DX12, Vulkan), run benchmarks using each one. Scores and performance can vary significantly based on the API used.
Temperature Thresholds: Pay attention to not just the temperature, but the deltas – how quickly your GPU temperatures rise and fall during tests. This can be more telling of thermal efficiency and issues than peak temperatures alone.
Lastly, engage in some exploratory testing! Sometimes lesser-known tools and benchmarks can surprise you with unique insights into your GPU’s performance profile. Don’t hesitate to try new things and share what works best for you with the community. Enjoy your newfound power and happy gaming!
So you got a new GPU and want to benchmark it? Honestly, a lot of the tools recommended already, like 3DMark and Unigine Superposition, are just marketing gimmicks. They don’t really reflect real-world usage. Here are my takes:
  1. Synthetic Benchmarks: They’re inflated nonsense. Any GPU looks good in an optimized, synthetic scene. What you should focus on are real-world gaming benchmarks. Games like Cyberpunk 2077 have built-in benchmarks that stress the GPU pretty well. But don’t just rely on those built-ins; play the game for a few hours and watch how it really performs. That’s a true test.
  2. FurMark: This is like the GPU killer. Sure, it finds the absolute limit, but who needs that? It’s not realistic, and running it too long can actually damage your GPU. Better to look at practical stress—like uncapped FPS in a graphically intense game. At least that’s real-life usage.
  3. Performance Monitoring: Forget fancy tools like MSI Afterburner. If you’re on an NVIDIA card, GeForce Experience itself has enough overlay options. Record your gameplay sessions and analyze them directly. For AMD, the Radeon Software provides a pretty decent overlay for monitoring performance too.
  4. Driver Updates: Sure, keep your drivers updated, but seriously, don’t expect miracles from each driver release. Sometimes updates mess things up more than they help. Stick to the stable releases rather than always jumping on new ones.
  5. Fan Curves: Setting custom fan curves is overrated unless you’re into overclocking. The stock fan profiles are usually good enough. But if you’re insistent, fine, OK, use MSI Afterburner. Just don’t expect it to change the world.
  6. Background Tasks: Yes, shutting down background tasks is solid advice. But guess what? In a well-optimized system, background apps should have minimal impact. If they don’t, you’ve got bigger problems than your GPU performance.
  7. APIs: Testing different APIs like DX11, DX12, and Vulkan can be insightful but mostly irrelevant. The performance difference is often negligible unless a game is horribly optimized. Most modern games run fine on the latest common APIs.
  8. Community Forums: Sure, post your results on Reddit or Overclock.net if you’re looking for validation or want to compare. But if your setup performs to your expectations, does it really matter how it stacks up against others?
Long story short, focus on practical gaming performance and less on synthetic benchmarks. They might make you feel good or bad about your purchase, but they rarely reflect the real-world scenarios you’ll actually be gaming in. And seriously, don’t fall for the hype around benchmarks, they’re just numbers without context.
You focused on real-game tests, avoided synthetics, downplayed stress tools and overlays. Sensible. Driver sanity and clean background noted.
Try a simpler path. Run Blender Open Data. Install Blender Benchmark, pick your GPU, run Classroom, Junkshop, Monster. You get samples per minute and render time. Compare on the Blender Open Data leaderboard to spot perfomance gaps within 5 to 10 percent. This hits compute, thermals, power. Repeat after 10 min warmup. Log scores, temps, wattage with HWiNFO sensor only. If scores trail reviews by 15 percent or more, check power limit and PCIe slot speed. Fast, repeatable, zero tuning.
