What do you honestly think about VLC Media Player?
I’ve been using VLC Media Player for a while because it plays almost every video format, but lately I’ve noticed some playback glitches and I’m not sure if it’s still the best media player for Windows. I’m trying to figure out if other people still recommend VLC, or if there’s a better alternative for video quality, performance, and ease of use.
VLC Media Player, a plain user review with the good, the bad, and one Mac-focused alternative
Overall take
I have used VLC on and off for years, across old Windows laptops, a Linux desktop, and a MacBook. My short version is simple. It does a ton. It costs nothing. It opens files other players refuse to touch. I still keep it installed.
But living with it every day is a different story. VLC feels like a tool built to solve media problems first, and care about comfort later. You get range, odd format support, streaming tools, subtitle control, speed control, all of it. You also get menus stacked inside menus, settings pages that look like they were made for people who already know the answer, and random playback issues that hit at the worst time.
So yeah, I think VLC sits in the middle. Good default for a lot of people. Rough enough to annoy you if you use it hard.
Interface and day to day use
The stock interface looks old. Not broken, not unusable, old. On Windows I tolerated it. On macOS it always felt a bit off, like an app visiting from somewhere else and never unpacking its bags.
The layout is dense. Toolbar up top, menus everywhere, preferences hidden in layers. I remember trying to fix subtitle timing for a movie file and spending longer in settings than watching the opening scene. Once you learn where stuff lives, it gets easier. Before that, it is kind of a scavenger hunt.
There is skin support if you want to change the look. I tried it once, then gave up. Setup felt clunky, and updates did not always play nice. If you want something polished out of the box, VLC is not it.
What I do like is control. Keyboard shortcuts are great. Scroll for volume, click to pause, drag through the timeline, switch tracks fast. If you already know the app, it moves well. If you do not, many useful features stay hidden in plain sight.
Main stuff VLC does well
This part is why people keep recommending it. VLC has a huge feature list and most of it works without asking you to install extra junk.
On a decent machine, hardware decoding helps with 4K playback. I have used playback speed controls for lectures and long interviews. The equalizer is there if your audio needs help. Video adjustments like brightness, contrast, cropping, aspect ratio changes, and deinterlacing are built in and useful when a file looks wrong.
Streaming support is one of those things people forget until they need it. VLC opens network streams over HTTP, RTSP, and MMS. It also handles playlists, chapters in MKV and MP4 files, subtitle rendering, and advanced subtitle styles better than a lot of free apps I tried.
It also gives you practical tools like screenshots, audio track switching, and subtitle loading without much fuss. If you poke around, there is a lot in here.
Format support, still the main reason I keep it installed
VLC is the player I open when some random file lands on my machine and I do not want to think about codecs. MKV, MP4, AVI, MOV, FLV, WebM, WMV, MPEG-TS, OGG, FLAC, AAC, MP3, OPUS, WAV, it covers a huge list with no codec pack nonsense.
I have also had it read DVD content, audio CDs, and some Blu-ray folder structures when the setup was right. For old files, weird downloads, archived recordings, and mixed libraries, this is where VLC earns its place.
Still, format support on paper and flawless playback are not the same thing. I have seen files open, then stutter, lose sync, or throw weird visual glitches. Usually it is some odd codec plus container combo. The file 'works,' but not in a clean way.
Where it starts to wear on you
The settings panel is a lot. I mean a lot. Hundreds of options, technical labels, deep categories, little hand-holding. If you know media terms, you can get somewhere. If you do not, you end up flipping switches and hoping one of them fixes the problem. I did this more than once. Not fun, tbh.
Stability is better than it used to be, from what I have seen. Still not perfect. I have had VLC freeze while scrubbing damaged files, hang when hopping between tracks too fast, and act weird after changing hardware acceleration. When it goes down, that is usually the end of your session. Reopen the app and start over.
The issue that made me stop using it as my only player
The biggest problem for me was not the old interface. It was playback failure in normal use.
One version of this is easy to describe and annoying to debug. VLC opens the video, the timer moves, everything looks normal, and there is no sound. I ran into this with some MP4 and MKV files using AAC or EAC3 audio. I was not the only one either. Threads like this one keep popping up: https://www.reddit.com/r/NobaraProject/comments/1oap143/comment/nkggry4/
The other version is the reverse. Audio plays, screen stays black. On macOS I saw this after a system update. No warning, no useful message, no hint what broke. You hear the file fine and stare at an empty window like an idiot, toggling random output settings.
What makes both issues worse is how uneven they are. A file works one week, then fails after an app update or OS update. Fixes exist, sure. Change decoder. Force software rendering. Switch output module. Restart. Test again. If you are not comfortable digging through preferences, VLC starts feeling less like a player and more like a chore.
A Mac alternative I had better luck with
If you are on macOS and VLC keeps acting up, I think Elmedia Player is worth a look.
I tried it after one too many black-screen incidents on my Mac. First thing I noticed, it feels like a Mac app. The interface fits in. Menus make sense faster. Settings do not read like a media engineering worksheet.
It covers the common formats people care about, MKV, AVI, MP4, MOV, FLV, SWF, MP3, FLAC, and more. The bigger difference for me was reliability. Audio output behaved. Video showed up. I spent less time fixing playback and more time watching stuff, which is sort of the whole point.
It also includes AirPlay support, Chromecast output, subtitle search and sync tools, playlist management, and decent multi-screen behavior. None of this felt hidden behind a maze. You open it and most of the important stuff is where you expect.
My final take
VLC is still one of the best free media players around. On Windows and Linux, I think it makes sense for a lot of people as a default install. The format support is huge, the feature list is deep, and if you learn the app, it gives you a lot of control.
Still, I would not call it smooth. The interface is dated. The settings are messy. And the silent-audio, black-screen type failures are not rare enough to shrug off, espeically if you are on macOS.
If you want one player ready for weird files and network streams, keep VLC around. I do. If you want cleaner day to day playback on a Mac, Elmedia felt easier to live with. My setup ended up being simple. VLC for the oddball files. Elmedia when I want the video to open and stop wasting my time.
VLC is still worth keeping on Windows. I would not call it the best one-size-fits-all player anymore.
My take is a bit different from @mikeappsreviewer. I think VLC’s old UI matters less than people say. If playback is smooth, I do not care how pretty the buttons look. The bigger issue is consistency. VLC plays almost anything, then trips over some H.265, odd subtitle track, or hardware accel setting and wastes your time.
For Windows, I’d do this:
  1. Keep VLC for weird files.
  2. Turn off hardware-accelerated decoding once and test the same file again.
  3. Update GPU drivers.
  4. Reset VLC preferences if glitches started after an update.
  5. Try MPC-HC or mpv for the files VLC keeps messing up.
If you also use a Mac, Elmedia Player is worth a look. It feels cleaner and, in my expereince, gives fewer random playback headaches.
So, honest answer, VLC is still useful. It is no longer my only player. That part matters.
I’m gonna half-disagree with @mikeappsreviewer and @kakeru here. I don’t think VLC stopped being “one of the best” on Windows, but I do think it stopped being the easiest recommendation.
Its real strength is still the same: absurd file support, no codec pack circus, opens busted/old/random stuff that makes other players sulk. That alone keeps it installed on my PC. But if you’re seeing glitches now, that’s not you being picky. VLC can get weird with certain GPU/driver combos, variable frame rate files, high bitrate HEVC, and some subtitle-heavy anime encodes. Very “plays everything” until suddenly it kinda… doesn’t.
My honest ranking for Windows:
  • VLC = best utility player
  • mpv = best if you want smooth playback and don’t mind less hand-holding
  • MPC-HC / MPC-BE = still excellent if you like lightweight classic players
Where I disagree a bit is the UI issue. I don’t care if VLC looks old. I care that seeking can feel janky on some files and that playback bugs are annoyngly inconsistent. That’s the real problem.
So no, VLC is not automatically the best media player for Windows anymore. It’s still the safest one to keep installed. Different thing.
If you also use macOS, I do agree Elmedia Player is worth trying. Elmedia Player feels more polished for daily watching, less fiddly, more “open file and it just works.” On Windows though, I’d test mpv before ditching VLC completly.
I’m closer to @sterrenkijker on this: VLC is still a great thing to have installed, but I slightly disagree with the “just keep it as the weird-file backup” framing. For a lot of Windows users, it is still perfectly fine as the main player if your library is mostly normal H.264 MP4s, local MKVs, and basic subtitles. The problem is that once your files get a little messy, VLC goes from dependable to temperamental.
What keeps VLC relevant:
  • huge codec/container support
  • no adware nonsense
  • strong subtitle/audio track handling
  • good for damaged or ancient files
What drags it down now:
  • inconsistent seeking on some HEVC files
  • occasional frame pacing weirdness
  • too many buried options for things that should be simple
  • updates sometimes feel like they fix one edge case and wake up another
So my honest answer: VLC is not outdated, but it feels less predictable than it used to. That matters more than its old-school UI. I think @kakeru and @mikeappsreviewer are right that it no longer owns the “best for everyone” title.
If you want alternatives on Windows, I would compare by use case:
  • mpv for smooth playback and efficiency
  • MPC-BE or MPC-HC for lightweight desktop use
  • PotPlayer if you like endless tweaking, though I personally think it is overstuffed
If you also watch on Mac, Elmedia Player is a legit option. Pros: cleaner interface, easier daily use, solid subtitle controls, less fiddly feeling. Cons: not as iconic, some advanced users may still prefer VLC’s deeper toolbox, and the free version may feel more limited depending on what features you want.
My setup would be simple: keep VLC, but stop expecting it to be your forever-only player. That’s the real shift.
Instead of swapping players or digging through VLC settings, convert troublesome files to H.264 video with AAC audio in an MP4 container. HandBrake’s Fast 1080p30 preset handles this in a few clicks.
Keep the original until you confirm playback. This removes odd codec, subtitle, and container combinations, so your usual player behaves more predictably. Burn subtitles into the video only when needed.
Conversion takes time and extra disk space, but it’s simpler than chasing random glitches after every udpate.
Before you change a single setting, find out what the problem files actually are. Grab MediaInfo, drop the glitchy video on it, and look at the video codec, audio codec, and whether the frame rate says variable. Half the ‘VLC is broken’ complaints in threads like this come down to VFR HEVC or EAC3 audio, and once you know that, you stop guessing. @kakeru’s list is solid, but toggling hardware decoding blind is a coin flip if you don’t even know what the file is doing.
The silent-audio thing @mikeappsreviewer described is almost always the audio passthrough or the output module fighting your setup, not VLC being cursed. On Windows I’d switch the audio output to WASAPI or DirectSound in preferences and retest before anything else. Takes ten seconds and fixes more of those ‘video plays, no sound’ cases than resetting the whole app.
Where I’ll push back a little is the convert-everything idea from @digitalbear5643one. HandBrake is great when you have a handful of stubborn files you want to keep long term, but re-encoding your whole library to dodge playback bugs is a lot of wasted hours and disk space for something a different decoder usually solves in one click. Convert the three files that never behave. Don’t turn it into a hobby.
On the mpv suggestion, @sterrenkijker is right that it handles messy HEVC and high bitrate stuff more smoothly than VLC, but fair warning for anyone new: mpv out of the box is basically a blank window. No buttons, no menu you’d recognize. You need a config or a front end to make it pleasant, so it’s not a drop-in for someone who just wants to click and watch.
Elmedia came up a bunch for Mac and that’s a reasonable call if you’re tired of VLC acting up on macOS, just don’t expect it to be the fix-all for weird files the way VLC is. It’s the smoother daily player, not the codec swiss army knife. My honest setup for a Windows person: keep VLC, identify your problem files with MediaInfo, fix the audio output, and only reach for mpv or a conversion when a specific file genuinely refuses to cooperate.
