What apps am I missing for my MacBook travel kit?
I’m putting together a MacBook travel kit for work trips and just realized I may be overlooking some must-have travel apps. I already have the basics, but after a recent trip I ran into issues with file access, Wi-Fi, charging, and staying organized on the go. I’d love help figuring out which MacBook travel apps or productivity tools are actually worth adding before my next trip.
Building out a MacBook travel setup, what else would you add?
I’m getting my MacBook ready for a pile of trips this year, including a few stops in different countries for the 2026 World Cup. I already grabbed the usual stuff, Google Maps, Google Translate, and a flight tracker. Good start, but I know I’m forgetting the less obvious things. Apps, tiny utilities, boring stuff you only miss when you’re stuck in an airport. Here’s what I’d put on it.
  1. XE Currency
This saved me from doing bad head math in shops and train stations. You pull up a price, convert it fast, and move on. It also keeps the last exchange rates saved for offline use, which helped me when my data was dead and I still hadn’t set up a local SIM. I used it mostly to check if a snack, cab, or random charger was priced fair or if I was geting fleeced.
  1. A password manager, 1Password or Bitwarden
Travel means logins everywhere. Airline sites, hotel Wi-Fi portals, booking apps, banking alerts, email verifications. I got tired of digging through notes or resetting passwords on sketchy public networks. Keeping it all in one locked place made things less annoying and felt safer too. If you end up signing into your accounts from a hotel lobby at 1 a.m., this matters more than you’d think.
  1. MacDroid
If your phone is Android, I’d keep this around. I used it to move photos and video off my phone straight to the MacBook, then clear storage before it filled up. This got useful fast when I was shooting a lot and didn’t want to babysit storage warnings. USB transfer is the main reason I kept it installed. No internet needed. When Wi-Fi was available, that worked too. Simple, and it fixed one of those dumb friction points I kept running into.
  1. Spotify
Offline playlists are one of those obvious things I still forgot once, and I regretted it for hours. Flights, trains, bus rides, airport delays, none of those are improved by staring at a dead loading screen. I downloaded playlists and a few podcasts before leaving, and it made the dead stretches feel shorter.
  1. Elmedia Player
I ran into this after collecting a mess of clips in different formats. macOS handled some fine, then choked on others. This played nearly everything I threw at it, which meant no wasting time converting files in a hotel room. I also liked pushing footage to a bigger screen later. Watching trip videos on a TV beats hunching over a laptop and pretending it’s fine.
  1. Wise
If you’re hopping between countries, this one earns its spot. I used it to keep spending in check across different currencies without eating ugly conversion fees every time I tapped my card. The app made it easier to see where my money was going, which helped because travel spending gets sloppy fast.
  1. Amphetamine
Small app, big payoff. It keeps your Mac awake when you need it awake. I used it during long downloads, while uploading files, and once when I didn’t want the laptop going to sleep in the middle of a hotspot session. You set a timer or leave it running until you switch it off. Not flashy, but I’d miss it right away if it was gone.
  1. Sublime Text
I don’t only use this for code. It’s one of the fastest places to dump notes, edit plain text, clean up copied info, or keep rough plans without opening a heavier app. It launches fast, stays out of the way, and doesn’t chew through resources. Good for travel notes, ticket refs, packing lists, and random address dumps.
  1. Alfred
This sped up day to day use more than I expected. I hit the shortcut, type a few letters, open what I need, find files, run searches, done. Less clicking through folders, less hunting through menus when I’m tired in an airport or trying to do something quick at a café table before the battery drops another 8 percent. Once I got used to it, going back felt slow.
A few things I’d also think about, since I forgot them on earlier trips, offline maps for specific cities, a decent VPN, cloud storage with offline access, and some kind of backup routine before your photos pile up. Losing files mid-trip feels bad in a way I can’t make sound normal.
I’d add a few things @mikeappsreviewer didn’t hit much.
TripIt or Flightsy. Better for keeping flight, hotel, and train details in one place. Search in email at 5 a.m. is a dumb way to travel.
Obsidian or Apple Notes with offline folders. For boarding passes, meeting notes, addresses, copies of passports, and local contact info. Keep a pinned “travel” note. Saves time.
Dropbox or iCloud Drive with files marked offline. This matters if hotel Wi-Fi is trash. I keep contracts, decks, PDFs, and receipts local before I leave. File access failure is one of the most common travel annoynaces.
Tailscale. This one is huge if you need files from your home machine or office NAS without exposing stuff to the internet. Easier than messing with port forwarding.
Little Snitch. Not for everyone, but great on public Wi-Fi. You see what apps are phoning home. Helps catch weird traffic fast.
NetSpot or WiFi Explorer. If your issue was bad Wi-Fi, these help you see channel congestion and weak signal spots in hotels or conference spaces. Niche, but useful.
PDF Expert or Preview plus a scanner app. Signing forms on the road always happens at the worst time.
I kind of disagree on Amphetamine being essential. Nice app, sure. I’d rank offline file sync and remote access way higher.
If you use Android, MacDroid is still worth packing. Wired transfer beats flaky cloud sync when you need files now, not later.
I’d add a few boring-but-clutch things neither @mikeappsreviewer nor @codecrafter really leaned into enough.
  • Velja: lets you choose which browser opens what. Super handy when hotel portals only behave in Safari but your work stuff lives in Chrome.
  • LocalSend: dead simple device-to-device file transfer on the same network. Great fallback when AirDrop gets weird.
  • Keyboard Maestro or Shortcuts: automate dumb travel tasks like opening your airline, notes, calendar, VPN, and expense sheet in one click.
  • BatteryBoi or Stats: I like having a lightweight menu bar tool to catch battery drain before I’m stuck outlet hunting like a goblin.
  • Downie or a read-later app with offline save**:** for grabbing docs/videos before a flight.
Small disagreement: I think Wi-Fi analyzers are overkill for most work trips. If hotel Wi-Fi sucks, it usually just sucks.
If file access burned you last trip, I’d prioritize:
  1. offline folders
  2. remote access
  3. wired phone transfer
That’s where MacDroid is actually legit if you use Android. Faster and less flaky than waiting on cloud sync when you need files right now. Also install a proper 2FA app on both Mac and phone, not just SMS, or you’ll hate life at the worst possible time.
I’d add a couple of boring lifesavers that @codecrafter, @reveurdenuit, and @mikeappsreviewer only brushed past.
  • Bartender or Hidden Bar: if you travel with lots of utilities, your menu bar turns into a junk drawer fast.
  • A proper backup app like Backblaze or ChronoSync: cloud sync is not backup. Different problem.
  • Totp auth on Mac like 2FATOTP or built-in support through your password manager: I actually think this matters more than another travel planner app.
  • An expense tool like Expensify or even a simple receipt scanner workflow. Work trips create admin sludge.
  • A browser just for captive portals: weirdly useful. I keep Safari clean for hotel and airport logins, everything else in my normal browser.
Small disagreement with the Wi-Fi tool crowd: for most people, fixing hotel Wi-Fi is fantasy. Better to prepare for failure than diagnose it.
On MacDroid if you use Android:
Pros
  • fast wired transfer
  • no waiting on cloud sync
  • useful when data is bad
  • easy for big photo/video dumps
Cons
  • only really valuable for Android users
  • one more utility to maintain
  • wired transfer is less convenient than seamless sync when both are behaving
Competitor-wise, Android File Transfer was always the obvious comparison, and KDE Connect / LocalSend can cover some sharing jobs, but MacDroid is usually smoother for drag-and-drop file work.
My actual priority order:
  1. backup
  2. offline docs
  3. auth access
  4. phone-to-Mac transfer
  5. then the nice-to-have utilities
