My phone battery has started dropping from 83% to 31% before the afternoon, even with light use, after about a year. Battery usage does not show one app taking an unusual share, and I already disabled background refresh. What should I check to determine why it is draining so fast?
After a year, some battery wear is normal, but that kind of drop points to either poor battery health or the phone staying awake when it should be idle. Check the battery health or maximum-capacity screen, then compare drain overnight in airplane mode versus normal mode. A big difference usually means weak cellular signal, location services, mail syncing, Bluetooth accessories, or a stuck system process rather than a single app. Restart the phone, install any pending OS update, and check whether it gets warm while unused. If battery health is low or it still drains heavily in airplane mode, run the manufacturer’s battery diagnostic or have the battery tested.
Don’t do a factory reset yet. Charge the phone to full, use it normally for 24 hours, and check the battery graph for extended periods of poor reception or unreasonably long screen-on time. Poor signal drains the battery much faster than most apps ever would. If the graph looks normal, back up your data and consider getting the battery replaced before doing any more fiddling.
Check the phone’s battery health or maximum-capacity reading. If it shows degraded service status, settings tweaks won’t fix the underlying wear, and replacement is the practical move.
Some loss of capacity after a year is to be expected, but losing the majority of the charge before lunch is outside of normal degradation
Watch the percentage and see if it steadily decreases, which would point to the usage, not the battery, being the problem. Large sudden drops, charging to full without using the phone, or the phone dying despite a nearly full charge would point to the battery gauge or the battery itself being faulty. Charge the phone uninterrupted to full, use it until it dies, and recharge it to full. This should reset a faulty gauge, but frequent deep discharges won’t help a physically degraded battery.
I wouldn’t treat the maximum-capacity number as a verdict either. A battery can report an acceptable figure yet perform badly under load. Compare the phone’s runtime and percentage behavior, not only that screen. If it still drops sharply after the single charge cycle, @hacker7627’s replacement advice is probably the least frustrating route.
Don’t keep using or charging it unattended if the back panel is lifting, the screen is separating, or the phone becomes hot while sitting idle. Those can indicate a swollen or failing battery. Power it off and arrange service rather than pressing the case closed or trying another charge cycle.
If there are no physical warning signs, try safe mode for several hours. That temporarily blocks downloaded apps, including ones whose activity may be buried under system services in the battery report. If the drain settles down, remove recently installed apps, VPNs, security tools, widgets, and anything with constant notification or accessibility access. If it drains at the same rate in safe mode, hardware or the operating system becomes more likely.
I’d check the charging side too. Make sure it actually reaches a full charge and stays there briefly before unplugging. A damaged cable, dirty port, or unreliable wireless charging alignment can leave the phone less charged than the percentage initially suggests. Clean the port carefully with the phone powered off, using no metal tools or liquid.
The reception and battery-health checks are still worthwhile, but I would back up important data now rather than waiting for a shutdown problem. Once you have ruled out third-party apps and confirmed there is no swelling, a professional battery test is a more useful next step than repeatedly changing settings or doing a factory reset.
If the phone spends its mornings in some warm place: a car dash, a sunny windowsill, in your jacket pocket pressed against you, this on its own may rapidly drain a year old battery with no visible reason (no apps or hardware faults apparent). These cells are sensitive to heat and the phone’s gauge often dips by up to 40 points immediately after, making it look like a sudden big fall. It’s worth checking this out before spending money.
@zerobot647point is right that the max-capacity number isn’t a verdict, and that’s the part most people skip past. I’d go further though: the single full charge cycle rarely ‘corrects’ anything the way people hope. It can nudge a confused reading back in line for a day, but if the cell is genuinely worn you’ll watch it slide again by the next afternoon. So do it once, sure, but treat it as a diagnostic step, not a fix.
The overlooked clue nobody thought of was the time. Afternoon means that the room was brighter, so the phone’s display was maxed out either by brightness settings or by the auto-brightness. Check what was the screen-on time for that particular period instead of your entire day. If the display is the culprit, it won’t be the battery you have to replace. If the time is low, and the drain is still significant, get it checked and leave it be.
Whether the phone was bought new matters here. A year of ownership does not always mean a year on the battery, especially with refurbished phones, insurance replacements, or devices that sat in storage for a long time. If your settings show a cycle count, manufacture date, or repair history, check that before assuming this is ordinary wear.
I’m skeptical that more settings changes will solve such a large loss with light use. Battery screens show how the consumed power was divided among apps. They do not prove the battery still holds the amount of energy the percentage gauge claims. A weak cell can look normal in the app list and then drop rapidly when the phone raises brightness, connects to a tower, or performs another brief high-power task.
I would skip the intentional run-to-shutdown routine. It might help identify a wildly inaccurate gauge, but modern lithium batteries do not need regular deep cycling, and it will not restore lost capacity. Instead, charge normally, record the percentage before bed, leave the phone powered completely off overnight, and check it after startup. If the reading falls substantially while switched off, software activity and poor reception are unlikely explanations.
Back up the phone, document the battery-health screen and graph, then contact the seller or manufacturer before paying for anything. A battery behaving this badly around the warranty boundary is worth submitting as a defect claim, even if the health estimate has not crossed the company’s service threshold. Let them reject the claim rather than assuming it is excluded and spending days chasing background settings.
A phone that drains on cellular but not on Wi-Fi has a different issue than one that loses the charge anywhere. Spend one morning on Wi-Fi with mobile data turned off and compare it to a regular morning.
If the former improved, change from 5G to LTE and keep the second SIM card disabled for a day; neither is guaranteed to appear in the battery list directly, but the modem can burn the battery while switching between the two.
