Need Help To Recover Data From Corrupted USB Drive
My USB drive suddenly stopped working after I removed it from my laptop, and now it shows errors or asks me to format it. It has important photos and work files I really need to recover. I’m looking for safe ways to recover data from a corrupted USB drive without making things worse.
I ran into this once with a flash drive full of work docs, and the first move was simple. Stop touching the drive.
Do not format it. Do not run CHKDSK. Do not copy new files onto it. I did all three on an old drive years ago and made the recovery worse, so I would not repeat tht.
Before you do anything bigger, check the obvious stuff:
  1. Plug it into a different USB port.
  2. Try it on another computer.
  3. See if it shows up in Disk Management on Windows or Disk Utility on Mac.
  4. Write down the exact error message, especially if you get something like “You need to format the disk before you can use it.”
If the system still sees the device at all, I’d skip repair attempts and go straight to file recovery. I’ve had decent results with Disk Drill when a USB stick was readable at the hardware level but the file system was a mess.
The steps I’d follow:
  1. Install Disk Drill on your main drive or another healthy disk, not on the damaged USB.
  2. Plug in the USB drive and open Disk Drill.
  3. Pick the USB device from the list.
  4. Start the scan and let it finish, even if it takes a while.
  5. Preview what it finds so you know the files are still there.
  6. Save recovered files somewhere else, never back onto the same USB stick.
If the files matter a lot, I’d make a byte-for-byte backup first inside Disk Drill, then scan the image instead of the original device. I’ve done this once with a flaky drive, and it felt safer because every extra read from bad media carries some risk.
After the files are safe, then deal with the USB itself. Repair it, wipe it, reformat it, whatever fits. Data first. Drive cleanup later.
If the USB shows the right size in Disk Management, your odds are better. If it shows 0 bytes, disappears, or gets hot, stop there. That points more to hardware failure than file system damage.
I agree with @mikeappsreviewer on avoiding format prompts. I differ a bit on one point. I would try a different cable or powered USB hub first if this is an external USB drive, not a small flash stick. Low power causes weird mount errors more often than people think.
What I’d do next on Windows.
  1. Open Device Manager.
  2. Check if the drive appears under Disk drives.
  3. Open Disk Management and note the status.
  4. If it says RAW, unallocated, or healthy but unreadable, use recovery software before repair tools.
For file recovery, Disk Drill is a solid pick because it handles deleted partitions, RAW volumes, and damaged file systems in one scan. Recover the files to your internal drive or a second external drive, never back to the bad USB. If previews work for your photos, that’s a good sign the file data is still intact.
If Disk Drill finds filenames and folders, the file system damage is limited. If it only finds files by signature, the folder structure got hit too. Photos often still recover fine in thsoe cases.
If the drive clicks, disconnects, or vanishes mid-scan, skip DIY and use a lab. Repeated reads make things worse.
For a simple USB data recovery guide, this video is decent: watch this USB data recovery walkthrough.
After recovery, replace the drive. A USB stick tht fails once is not storage you should trust again.
One thing I’d add to what @mikeappsreviewer and @suenodelbosque said is this: if the USB still mounts for even a few seconds, copy the most irreplaceable files first by priority, not by folder. Photos, docs, client work, then everything else. People get stuck trying to do a perfect full recovery and the drive dies halfway through.
I also would not assume CHKDSK is always evil, but for your case I still would not touch it yet. It’s a repair tool, not a recovery tool, and on a failing USB it can absolutely make a mess of filenames and folders.
My order would be:
  1. Test on another computer only once or twice.
  2. If it appears, check SMART only if it is an external USB SSD/HDD, not a tiny flash drive.
  3. Make an image of the drive if possible.
  4. Recover from the image.
If imaging fails in one app, try another tool made for unstable media, like HDD Raw Copy Tool or USB Image Tool. Then scan the image with Disk Drill. That’s the part I’d do diferently. Disk Drill is solid for actually pulling files from a corrupted USB, especially photos and office files, but I prefer to reduce stress on the original device first whenever possible.
Also, look at the drive in Disk Management carefully:
  • correct size shown = better sign
  • RAW = file system damage, often recoverable
  • unallocated = partition issue, still recoverable sometimes
  • 0 bytes or constant disconnects = much worse
If you want more opinions, this thread on best recovery tools for a corrupted USB drive is worth reading.
If the stick gets hot, vanishes, or freezes the PC, stop DIY stuff. At that point you’re gambling with the last readable bits of data.
Before trying anything else, I’d check whether the USB drive shows up with the correct capacity in Disk Management. If it does, don’t format it or run CHKDSK just yet, as that could make recovery harder.
Do you have access to another computer to check whether the same issue happens there? Also, is the data important enough that you’d consider making a full image of the USB before attempting recovery?
I also came across a thread about a corrupted USB drive that might be worth checking out.
Everyone’s talking like Disk Drill is the fix, but it’s really just the reader. If the controller on a flash stick is dead, no scanner on earth pulls files off it, so test whether the drive even stays mounted long enough before you pin hopes on any app.
Where it does earn its spot is letting you run the scan and eyeball what’s recoverable before you commit to anything. Just don’t expect it to revive hardware that’s already gone.
