I’m trying to create my first project using Heygen AI video, but I’m confused about how to properly set up the avatar, voice, and script timing so everything looks natural. The previews don’t match what I expected, and I’m not sure if I’m missing a step in the workflow or using the wrong settings. Can someone walk me through the recommended setup process or share best practices for creating smooth, realistic Heygen AI videos?
Yeah, HeyGen can be pretty confusing at first. The trick is to stop trying to do everything at once and lock in each piece step by step so the previews don’t look like a glitchy puppet show.
Here’s what usually helps:
Start with the script only
- Paste the full script in first.
- Break it into scenes or paragraphs where you’d logically have a pause or a cut.
- Shorter chunks = more natural facial sync. Long monologues tend to look stiff.
Pick the voice before tweaking timing
- Choose the voice style (casual, promo, news, etc.) that matches your script tone.
- Slow, calm voices look more “natural” with realistic avatars. Super energetic voices can look weird if the avatar is very formal.
- Some voices have slightly different pacing, so always test with a small sample of your actual script.
Match avatar to the script + voice
- Professional script? Pick a more neutral avatar in professional clothing.
- Casual / YouTube style? Use someone less “corporate” and a more relaxed voice.
- Avoid mixing hyper-energetic copy with a deadpan office avatar. That’s when the uncanny valley hits hard.
Use punctuation to control timing
- Periods = normal pause
- Commas = short pause
- Ellipsis (…) or line breaks = longer, more dramatic pause
- If the preview feels rushed, you usually don’t need “timing settings,” just more punctuation and sentence breaks.
Check the preview in small chunks
- Don’t render a full 3 minute video while you’re still guessing.
- Do 10–20 second test clips until lips, timing, and tone feel right.
- If the mouth looks slightly off, try simplifying the wording or reducing weird proper nouns / acronyms.
Avoid these early mistakes
- Overstuffed sentences with no punctuation. The AI just blasts through them.
- Super fast speaking style for explainer content. Slower voices almost always look more natural.
- Expecting frame-perfect lip sync. It’s “good enough” but not Hollywood.
Rought workflow that usually works
- Write your script in a doc, clean it up for readability.
- Add punctuation + line breaks wherever you want a natural pause.
- Paste into HeyGen, choose avatar, then voice.
- Generate a 15–30 second test.
- Tweak text & punctuation until the preview feels right.
- Only then build out the full project.
If you share what kind of video you’re trying to make (promo, tutorial, talking head, etc.), people here can probably suggest specifics like which avatar/voice combos look the most natural for that style.
Couple of extra angles to try that build on what @voyageurdubois said, but slightly different approach:
Lock your framing & layout first
Before avatar/voice drama, decide: is it full‑body, mid‑shot, or just talking head?- Tight headshot usually hides minor lip‑sync weirdness.
- Full body makes every timing glitch way more obvious.
For a first project, go with a simple chest‑up shot, static background, no fancy overlays. Complexity multiplies the “this looks wrong” feeling.
Use a reference real‑life read
This is the part most people skip. Read your script out loud and record it on your phone.- Listen to where you naturally pause, speed up, or emphasize words.
- Then adjust the script text to match that rhythm instead of guessing.
If you’d never say the line out loud comfortably, the avatar won’t sell it either.
Don’t rely only on punctuation for timing
I slightly disagree with leaning too hard on punctuation alone. HeyGen’s TTS sometimes ignores your perfect commas.
Try:- Splitting big thoughts into separate sentences, even if it’s not “grammatically pure”.
- Changing phrasing: “Today, we’ll cover three things.” → “Today we’ll cover three things. First…”
Shorter, spoken‑style sentences usually sync better than one long pretty paragraph.
Simplify for the engine, not for humans
The model can choke on:- Acronyms (API, KPI, etc.)
- Tongue‑twister phrases
- Heavy jargon in one sentence
Hack: - Spell out tricky stuff once: “K P I (key performance indicator)”
- Or rearrange: “We’ll talk about the main KPI. That means our key performance indicator.”
The less the engine struggles, the cleaner the lip movement.
Use section-based projects instead of one giant script
Instead of one mega project:- Create multiple short scenes (intro, point 1, point 2, outro).
- Render separately, then stitch them in an editor (even a simple online one).
This way you can fix just the broken segment instead of re‑rendering a whole 3‑min chunk every time something feels off.
Micro‑tune the first 5 seconds
This sounds weird, but viewers judge the entire video in those first seconds.- Make sure the very first line is clean, not rushed, no weird lip lag.
- If needed, add a 0.5–1 second “silent” intro line like: “ ” or a very short simple phrase.
That gives the avatar a “warm‑up” instead of starting mid‑breath.
Voice pacing workaround
If a voice you like sounds too fast and tweaking punctuation still sucks:- Duplicate the scene.
- Try a slower preset of the same or similar voice.
- Compare both exports side by side, not just in the tiny preview.
Sometimes the engine’s preview feels more robotic than the final render, so don’t judge purely on that tiny window.
When previews look totally “off”
Common culprits:- Background too busy, making the avatar look pasted on.
- Lighting mismatch between avatar and background.
- Script tone doesn’t match expression.
Try a plain background and default lighting for now. Get realism first, aesthetics later.
If you share:
- Rough length of the video
- What it’s for (promo, course, onboarding, etc.)
- Whether you’re okay editing clips after export
people can suggest more specific avatar/voice combos and even how long each line should roughly be so it feels more like a real talking head and less like a talking powerpoint.
Skip avatar/voice for a second and think like an editor: the “natural” feel in Heygen usually comes from structure and post‑work, not from trying to perfect everything inside the app.
1. Treat Heygen like a camera, not a full studio
Use Heygen AI video only to generate clean talking‑head clips. Do the real timing work in an editor:
- Generate short segments (1–3 sentences each).
- Export them.
- Drop into a basic timeline editor (CapCut, VN, Premiere, whatever).
- Trim dead frames at the start/end, add pauses by inserting still frames or B‑roll.
This gives you frame‑level control over timing instead of fighting the internal preview.
2. Ignore “perfect sync,” chase believability
I’d disagree a bit with trying to micro‑control every comma. The engine will never give lip‑perfect sync across an entire long read, and trying to force it usually wastes time.
Focus on:
- First and last words of each line looking right.
- Major emphasis words matching facial expression.
- Cutting away to slides or screen recordings whenever the mouth looks off.
A simple cut to B‑roll hides 90% of uncanny moments.
3. Use B‑roll and cutaways on the “hard” lines
Whenever your script contains:
- Acronyms
- Fast lists
- Complex product names
Plan to cover those seconds with:
- Screen capture
- Product images
- Simple text overlays
Let Heygen handle the easy conversational lines where the face matters. Everything else becomes voice‑over.
4. Lock a consistent “template” for future videos
Once you find a combo that does not look weird:
- One avatar
- One or two voices
- One framing (medium shot, neutral background)
Save that as your personal template. Reuse it so you are not reinventing the wheel every project.
This helps avoid the trap of constantly chasing the “perfect” avatars and voices and never getting a workflow that feels repeatable.
5. Script for performance, not just text
You already heard good advice from @jeff and @voyageurdubois about splitting the script. I’d push it further:
- Write as if it’s subtitles.
- Short, punchy lines.
- One idea per line.
- Avoid long compound sentences entirely.
If it looks “too simple” for text, it is probably about right for synthetic video.
Example:
Instead of:
“In this onboarding video, we’re going to quickly walk through the three main features of our platform so you can get started today.”
Try:
“In this onboarding video, we’ll walk through three main features of our platform. By the end, you’ll be ready to get started.”
Same meaning, far easier for the engine to deliver.
6. About Heygen AI video itself
- Very fast for turning simple scripts into presentable talking heads.
- Large variety of avatars and voices, so you can find a consistent brand look.
- Good enough realism for promos, explainers, onboarding, and course intros.
- Fine‑grained timing and emotion control are still limited.
- Long, dense scripts almost always look robotic unless you break them up.
- Preview sometimes feels different from final render, so you have to iterate.
@jeff leans more into text and punctuation control inside the tool. @voyageurdubois adds smart tricks around structure and framing. I think the missing piece is accepting that Heygen AI video is just one part of the pipeline. Use it for what it is good at (generating a decent digital presenter), then fix rhythm, pacing and “realness” in editing and with B‑roll.
If you share a small sample (like 4–5 lines of your script and what type of video it is) I can suggest exactly how I’d chunk it and where I’d plan cutaways so the avatar does not have to carry every second.
