Need help figuring out how to use the Tlife App?
I just installed the Tlife App and I’m confused about how to set it up and use its main features for daily tracking. The interface isn’t very clear to me, and I can’t find a clear guide or tutorial. Can someone explain the basic steps, best settings, and any tips to get the most out of the Tlife App?
Yeah, the Tlife UI is kinda confusing at first. Here is a simple setup path that works:
  1. First run and basic setup
  • Open the app, skip any promo popups.
  • Go to Profile or Me tab.
  • Set: name, weight, height, age, gender.
  • Under Goals, pick what you want: weight loss, maintain, gain, or “healthy habits”.
  • Set target steps per day and sleep target if it asks.
    Those values control most of the daily summaries.
  1. Turn on tracking
  • Go to Settings.
  • Turn on:
    • Activity or Steps tracking
    • Sleep tracking
    • Notifications / Reminders
  • If it asks for permissions, allow:
    • Motion and fitness
    • Notifications
    • Access to Health / Google Fit if you want sync.
    If you skip this, numbers stay at zero and the app feels broken.
  1. Daily home screen
    Usually shows 3 or 4 main widgets:
  • Steps or Activity ring. Tap it to see: steps, distance, calories, active time.
  • Sleep card. Tap to see last night, weekly trend, sleep stages if supported.
  • Heart rate card if you have a wearable linked.
  • Weight card if you log weight.
Tap each card instead of hunting menus. Most options hide behind those cards.
  1. Logging stuff manually
    If you do not use a watch or band:
  • On Home screen, look for a “+” button.
    Common quick logs:
    • Weight
    • Water
    • Food or calories
    • Exercise session
    Example: For a workout log
  • Tap +
  • Choose Exercise
  • Pick type, enter duration and effort.
  • Save.
    You should see numbers update on the home ring or activity tile.
  1. Linking a device
    If you have a Tlife band or watch:
  • Go to Devices tab.
  • Tap Add device.
  • Turn on Bluetooth.
  • Pick your device model from the list.
  • Wait for pairing, accept any pairing code.
    After that, the app syncs steps and sleep automatically.
    If sync fails
  • Kill the app, reopen.
  • Make sure Bluetooth is on and band screen is awake.
  1. Notifications and reminders
    Go to Settings, then Reminders.
    Common useful ones:
  • Move reminder every 1 hour.
  • Drink water reminder.
  • Sleep reminder at a fixed time.
    Start with 1 or 2 reminders. Too many gets annoying fast.
  1. Daily routine that works
    Morning
  • Open the app.
  • Pull down on the home screen to sync.
  • Log weight if you track it.
    Daytime
  • Let it track steps automatically.
  • Open it 1 or 2 times to check steps.
    Night
  • Check sleep from last night.
  • Review steps and total activity.
  • Optional: log workout if you did one.
  1. Where stuff usually hides
  • Trends or Statistics tab shows week and month graphs.
  • Profile > Goals lets you change calories, steps, weight target.
  • Settings > Data or Permissions links to system settings if tracking looks wrong.
  1. If things still look confusing
  • Tap every icon on the home screen once. The app often uses icons instead of labels.
  • Long-press tiles if supported, some layouts let you rearrange the home view.
  • If numbers stay at zero all day, check:
    • Permissions in phone settings
    • Device pairing
    • Motion / fitness access toggle
If you share what phone you use and whether you have a Tlife wearable, people here might be able to give more exact steps, since the menus move around a bit between versions.
Yeah, Tlife’s UI feels like it was designed by three different teams who never met each other, so you’re not alone.
@reveurdenuit already laid out a nice step‑by‑step for setup, so I won’t repeat that. I’ll just add how to actually make it usable day to day and where stuff is hiding logically (or… illogically).
1. Start by cleaning up the home screen
The default home layout is usually cluttered. Try this:
  • Long‑press on empty space or on a tile (if your version supports it).
  • Look for “Edit” or a tiny pencil icon.
  • Hide tiles you don’t care about (heart rate if you don’t have a wearable, for example).
  • Move the tiles you use most to the top: Steps, Sleep, maybe Weight.
The app feels 2x clearer once you stop scrolling for the same tiles every time.
2. Ignore half the menu labels at first
Instead of hunting in the bottom tabs or hamburger menus:
  • Tap what looks tappable on the main screen: numbers, rings, small graphs.
  • Anywhere you see a tiny graph, percentage, or “>” arrow, assume it opens details.
    Tlife is weird in that a lot of features are hidden behind those little visuals instead of actual buttons.
3. Set only one primary goal
I kinda disagree with loading it up with multiple goals right away like “water, steps, weight, sleep” all at once. That gets noisy if you’re already confused.
Pick one for the first week:
  • Steps if you walk a lot
  • Sleep if that’s your main issue
  • Weight if you’re really focused on that
Then:
  • Go to Profile > Goals and set that one properly.
  • On the home screen, mentally ignore the other cards for a few days.
    Once you’re comfortable, re‑enable the others and adjust goals.
4. Make the graphs actually useful
The “Trends” or “Statistics” tab is where the app stops being random numbers:
  • Switch to weekly view, not daily. Daily is too noisy.
  • For steps and sleep, look for a horizontal line that shows your target.
  • If it’s not there, check Goal settings again; sometimes the target isn’t applied until you reopen the app.
Use the weekly view to answer “am I generally doing better” instead of obsessing over today.
5. Manual vs auto tracking strategy
If you don’t have a band or watch:
  • Turn off or ignore features that look blank all the time, like heart rate or detailed sleep stages.
  • Rely on
    • Steps from phone motion (if enabled in permissions)
    • Manual logs for things like workouts and weight
If you do have a device:
  • Don’t log exercise manually and also record it on the watch, or you might double count.
  • Check after a workout: open Tlife, pull down to refresh, and see if it auto‑logged before adding anything.
6. Fix the “everything is zero” bug behavior
Instead of re‑installing instantly:
  1. Check OS permissions:
    • On your phone settings > Apps > Tlife > Permissions
    • Make sure “Physical activity” / “Motion & fitness” is on
    • Make sure “Location” is on if your OS requires it for Bluetooth
  2. Open Tlife, go to Settings > Data / Sync, and toggle things off and on again.
  3. If you have a band, wake the band screen, then open Tlife and wait 5–10 seconds.
Reinstall is a last resort, because you’ll lose some history if it’s not synced elsewhere.
7. Daily routine that doesn’t feel like a job
Mine, roughly:
  • Morning
    • Open Tlife once, pull down to sync
    • Glance at sleep tile, weight if I’m tracking it
  • Afternoon
    • One quick check of steps, adjust if I’m way below target
  • Evening
    • Look at weekly view instead of obsessing over a bad day
Total time actually touching the app: maybe 2 minutes a day.
8. When you get overwhelmed
Honestly, if a screen looks too busy:
  • Ask yourself: “What 1 number do I care about on this screen?”
  • Mentally ignore the rest for now.
  • If you constantly ignore a tile, edit the home screen and hide it.
Tlife doesn’t become “clear” so much as “tolerable once you hide 30% of it.”
If you mention if you’re on Android or iOS and whether you’ve got a Tlife wearable or just the phone, people here can probably tell you exactly which tab names you’ll see, since they shift between versions and that’s half the confusion.
Short version: Tlife is usable once you stop treating it like a “life OS” and treat it like a dumb stats board. Here’s how I’d approach it slightly differently from @viajeroceleste and @reveurdenuit.
1. Ignore goals at first, focus on accuracy
They both start with goals; I’d actually start with: “Is the data even right?”
  • Wear your phone or band for half a day.
  • Compare:
    • Steps in Tlife vs your phone’s built‑in health app
    • Sleep in Tlife vs how you actually slept
      If Tlife is way off, fix that first (permissions, device pairing, etc.). Goals are useless if the numbers are nonsense.
2. Use Tlife as a mirror, not a coach
The app tries to be “motivational” with rings, colors, badges. You can safely ignore most of that.
Treat it like a basic dashboard:
  • Check only:
    • Steps total
    • Sleep duration
    • Weight trend (if you log)
      Forget about:
  • “Scores”
  • Random badges
  • Vague “health index” cards
That alone makes the interface feel 50% less noisy.
3. Pick one “anchor screen”
Instead of tapping every card like @viajeroceleste suggests, find the single view that feels most understandable and keep coming back to it:
Common options:
  • Home for a quick daily snapshot
  • Trends / Statistics for weekly understanding
    Then let everything else be secondary. Tlife is easier if you mentally crown one screen as “home base” and ignore the rest unless needed.
4. Use manual logs as reality checks, not just fillers
If you do not fully trust auto tracking:
  • Log one or two key things manually:
    • Weight in the morning
    • A main workout (run, gym, etc.)
      Then compare how Tlife interprets your day versus your manual entries. Over time you’ll see where the app consistently undercounts or overcounts and adjust your expectations.
5. Pros & cons of using Tlife for daily tracking
Pros
  • Works as a single hub if you are okay with a slightly clunky UI
  • Solid for simple metrics like daily steps, sleep hours, and weight
  • Syncs reasonably well with a Tlife band or watch when permissions are correct
  • Weekly graphs can be genuinely useful for “big picture” trends
Cons
  • Interface feels inconsistent; icons instead of labels make discovery harder
  • Too many features turned on by default make it overwhelming at start
  • Data can appear stuck at zero until permissions / sync are handled properly
  • Motivational elements (scores, random tiles) can distract from core numbers
6. Quick compare to what others already said
  • @viajeroceleste gave a very structured setup flow. Good if you like checklists, but you might not need every tracking feature enabled on day one.
  • @reveurdenuit is right about decluttering the home screen, but I would not spend too long rearranging tiles until you know which ones you actually care about after a week or two.
If you share whether you are using only the phone or also a Tlife wearable, you can get more targeted tips, like which specific tiles are safe to ignore so Tlife turns into a simple, low‑maintenance tracker instead of a confusing dashboard.
