Is anyone else having a wifi outage near me right now?
My home wifi suddenly went down and rebooting the router didn’t fix it. My phone data works, but all my smart devices and work-from-home setup are offline. Is this a local ISP outage near me or something on my end, and what should I check or ask my provider to restore service as quickly as possible?
First thing, check if it is an ISP issue or your gear.
Here is a quick checklist.
  1. Check outage info
    • Use your phone data and log into your ISP account.
    • Most ISPs have an outage map or status page.
    • Also try sites like downdetector and search your ISP name plus your city.
    If you see a spike of reports in your area, it is likely on their side.
  2. Look at your modem and router lights
    • If the modem “Online” or “Internet” light blinks or stays off, the line from the ISP has trouble.
    • If the modem looks normal but the router “WAN/Internet” light is off or red, the router has trouble.
    • If Wi Fi lights look fine and you get “connected, no internet” on multiple devices, the upstream link is bad.
  3. Bypass the router
    • Plug a laptop directly into the modem with Ethernet.
    • Power off the modem for 30 to 60 seconds, then power it on with the laptop connected.
    • If you get internet that way, your router or Wi Fi is the problem.
    • If you still have no internet, the ISP line or modem is bad.
  4. Check if it is Wi Fi only
    • If any wired device in your house works, the outage is your Wi Fi, not the ISP.
    • If all wired and wireless fail, focus on modem, router, and ISP.
  5. Quick config checks on your router
    • Log into the router from a device that is connected to it. Use the default gateway in your network settings.
    • Check that the WAN status shows a public IP. If it shows 0.0.0.0 or nothing, it is not getting a lease from the modem or ISP.
    • If you changed anything recently, such as DNS, VLAN, or MAC cloning, revert it.
  6. Try a second router or hotspot test
    • If you have an older router, plug it in and see if it works with the same modem.
    • Or set your phone as a hotspot and see if your devices connect fine to that. If they do, your smart devices and laptops work, so the issue is ISP or router, not the devices.
  7. When to call your ISP
    • Modem “Online” light off or blinking for more than 10 to 15 minutes after power cycle.
    • Direct wired test to modem fails.
    • Neighbors on same ISP report outages.
    Tell them you already power cycled modem and tried direct connection. That skips some of the script.
If the ISP says everything looks fine or the outage map shows nothing, then focus on Wi Fi quality and interference. Nearby networks, thick walls, or a bad channel can make it look like an outage.
For Wi Fi troubleshooting and planning, a tool like advanced Wi Fi analyzer NetSpot helps a lot. You run it on a laptop, walk around, and it shows signal strength, bad spots, and channel overlap. Then you adjust router placement, channels, and bands so your smart devices stay online more reliably.
Since your phone data works, that confirms the wider internet is fine. Once you test direct to the modem and check your ISP status, you will know if you are dealing with a local outage near you or a router and Wi Fi issue at home.
Short version: it might be an ISP outage near you, but sudden “everything died at once” can also be a flaky modem, bad cable, or a weird config glitch that a simple reboot won’t fix.
@sternenwanderer already covered the structured checklist pretty well, so I’ll skip repeating that whole flowchart. A few extra angles they didn’t lean on as much:
  1. Check what exactly died on your LAN
    • On a device that does connect to the Wi‑Fi, open a browser and try:
      • http://192.168.0.1 or http://192.168.1.1 (common router IPs).
    • If you can’t even reach the router page, that’s not “ISP outage,” that’s your own network freaking out.
    • If you can reach the router but websites time out, that points more to ISP / modem / WAN problem.
  2. Look for an IP address clue
    • In your router’s status/WAN page:
      • If WAN IP looks like 192.168.x.x, 10.x.x.x, or 172.16‑31.x.x, your modem might be in bridge/router limbo and handing you a private IP. That can break routing randomly.
      • If it shows 0.0.0.0 or blank, the ISP side really isn’t giving you anything.
    • I slightly disagree with the idea that “if the ISP says everything looks fine, focus only on Wi‑Fi.” ISPs say “looks fine” even when a node is half‑dead. If WAN IP won’t lease for multiple reboots, keep pushing them.
  3. Coax / fiber / ONT sanity check
    • If you’re on cable: check the coax going into the modem. Loose connectors or a splitter that got bumped can kill signal instantly.
    • Fiber: look at the ONT / fiber box. Any red/alarms or LOS light means upstream issue regardless of what phone support scripts say.
  4. Check if anything partially works
    • Try opening http://1.1.1.1 or http://8.8.8.8 from a connected device.
      • If IPs load but normal URLs don’t, DNS is borked, not raw connectivity.
      • Try setting DNS on one device to 1.1.1.1 / 8.8.8.8 and see if that magically brings things back.
    • This is a sneaky one that feels like “outage” but is just DNS failure, sometimes caused by the router or ISP.
  5. Smart devices specifically
    • Some IoT stuff is picky: 2.4 GHz only, no mixed WPA3, no random channel 13, etc.
    • If your phone and laptop work on Wi‑Fi but smart bulbs and plugs are dead, it’s probably Wi‑Fi config, not ISP.
    • If everything is dead, then yeah, you’re back to ISP vs router vs modem.
  6. Wi‑Fi environment scan
    • If this isn’t a full outage but more of an “it keeps dropping,” then interference is a real suspect.
    • A tool like NetSpot is actually useful here: install it on a laptop, walk around, and check signal strength and channel overlap. That helps you see if your neighbors’ routers are stomping on yours or if your office is just in a dead zone.
    • You can grab it here and use it to analyze and improve your home Wi‑Fi coverage pretty quickly.
  7. When it’s definitely an ISP / local outage
    • Modem lights show no “online” after multiple power cycles.
    • Direct Ethernet from laptop to modem fails.
    • You test a completely different router and it still has no WAN IP.
    • Neighbors in your building or street report the same issue on the same provider.
  8. When it’s probably on your end
    • Wi‑Fi network shows up but says “connected, no internet” only on some devices.
    • You can log into the router but WAN IP looks odd or keeps dropping.
    • A different router or your phone’s hotspot works perfectly with all your smart stuff.
So if you want a quick path instead of a full checklist:
  1. Use phone data to check ISP status / outage map.
  2. Try reaching your router admin page from a connected device.
  3. If that works, check WAN IP and DNS settings.
  4. If you can’t get a WAN IP through multiple modem power cycles and a direct laptop connection, start assuming ISP or outside line, no matter what first‑level support reads off their script.
If you post what your modem/router WAN lights look like and what IP your router is showing on the WAN side, ppl here can usually tell you in one reply whether it’s “call ISP now” or “fix your own gear.”
