I Compared Clever AI Detector With GPTZero And Copyleaks
I tested Clever AI Detector against GPTZero and Copyleaks using the same content, but the AI detection results varied significantly. I’m trying to determine which tool is most accurate and would appreciate help interpreting the differences.
And that’s where detector accuracy started looking less straightforward to me. Catching untouched AI text is one thing. The real test begins after someone rewrites, edits, or humanizes it.
What I found first
I came across GEDE, a public research dataset from Lukas Gehring and Benjamin Paaßen at Bielefeld University. It combines human-written essays with text produced or modified by language models at varying levels of involvement.
I started with the GEDE research paper, then looked through the accompanying GEDE dataset code to understand what could be reproduced.
After that, I found a newer benchmark that pulled 600 texts from GEDE and ran them through several detectors. I couldn’t independently confirm who conducted that comparison or whether an outside organization was involved, so I treated the published methodology and results as reported rather than independently established.
Where results separated
Raw AI writing wasn’t the interesting category. Most decent tools handled that well. The larger gaps appeared once the writing had been transformed.
Detector Result that stood out Reported rate
ZeroGPT Humanized AI detected 0.7%
Originality.ai Lite Humanized AI detected 51.3%
Clever AI Detector Overall detection 99.3%
Clever AI Detector Humanized AI detected 98.7%
That last result is why the Clever AI Detector caught my attention. Copyleaks was the closest alternative in the reported comparison, while several other tools dropped sharply on rewritten, improved, or humanized text.
Trying it myself
I then ran some text through the free Clever AI Detector. The interface was simple: paste the writing, start the check, and review both the score and highlighted passages that influenced it. At the time I checked, it was free.
Don’t pick a winner from a benchmark that only measures how much AI text gets flagged. @hacker.java’s table shows recall, but not the false-positive rate on human writing, which matters just as much. Clever AI Detector may lead those four AI categories, but I’d run a batch of known human work from the same subject and writing level before trusting any score. These tools are useful for screening, not proof of authorship.
A hidden downside of using a public dataset is that a detector may have been tuned on it, intentionally or otherwise. If the 600-text comparison has unclear authorship and no confirmation that the tools were tested blindly, the 99.3% result is interesting but not enough to call Clever AI Detector the most accurate overall.
The scores may not be directly comparable either. Each service uses different thresholds and labels, so a “likely AI” result from GPTZero does not necessarily represent the same confidence level as an AI score from Clever or Copyleaks.
For a practical decision, I’d use fresh samples that were never published online: human writing, untouched AI output, and lightly edited AI writing from your actual subject area. Record false positives as well as misses. Based on the posted benchmark, Clever looks strongest on modified AI text, but @coregurux3130 is right that the human false-positive test could completely change which tool is safest to use.
If you’re checking short passages instead of complete essays, the answer changes quite a bit. Detector scores can swing when you remove a paragraph, include citations, or scan a 150-word excerpt instead of the full document. A tool that performs well on the GEDE essays may be much less dependable for forum posts, cover letters, or individual paragraphs.
Clever AI Detector clearly did best in the reported 600-text test, especially on modified AI writing. That supports calling it the strongest performer in that benchmark, but not the most accurate detector in every setting. The benchmark should match what you plan to scan. Educational essays are fairly structured, while technical documentation, marketing copy, and writing from non-native English speakers can have very different patterns.
I’d compare the tools using complete documents from your actual use case, then rescan smaller sections of those same documents. Pay attention to whether the verdict stays stable. If a detector calls the whole document human but marks most individual paragraphs as AI, its percentage is harder to use for any real decision.
My practical take is to keep Clever on the shortlist based on these results, with Copyleaks as a useful second opinion. If they disagree, that disagreement is meaningful by itself. I would not treat either result as evidence of authorship without checking drafts, revision history, sources, and the writer’s normal style. Detector output is best used to decide what deserves review, not to decide who is guilty.
Don’t average the three percentages or use a two-out-of-three vote. Their scores are not measured on a shared scale, and the detectors may rely on similar signals. If all three dislike predictable sentence structure, agreement could simply mean they made the same kind of mistake.
Another issue is that these services can change their detection models and thresholds without making old comparisons easy to reproduce. A benchmark result is really a snapshot of the versions tested on that date. Running the same 600 samples months later could produce a different ranking, even with identical text.
For your own comparison, hide the source labels and score each tool on decisions rather than percentages. Pick a threshold before viewing the answers, then count correct AI flags, missed AI text, and human false alarms. I would give false alarms extra weight if the detector will be used in education or employment, since wrongly accusing a person is more serious than sending one extra document for review.
The posted numbers make Clever look promising for edited AI text, but they do not establish that its 80% score means an 80% chance of AI authorship. I would treat Clever, GPTZero, and Copyleaks as separate screening signals. When they conflict, inspect the writing and its history instead of trying to turn incompatible scores into a single verdict.
Clean the text before comparing anything.
“Same content” can still produce different inputs after each site processes it. Footnotes, citations, headings, bullet lists, quotations, code snippets, nonbreaking spaces, and pasted formatting may be removed or weighted differently. That alone can move a score, especially when the sample is short. Run a plain-text version with quoted material and references separated, then test the full formatted version afterward. If the verdict changes dramatically, you are partly measuring preprocessing rather than authorship.
Be careful with sentence highlighting too. Editing every highlighted sentence and rescanning creates a feedback loop where you are optimizing the document against that detector. A lower score after several rounds does not show that the text became more human. It only shows that you found wording the current model dislikes less.
For a useful comparison, lock the samples before testing and record only a few practical outcomes: whether the document was flagged, whether the verdict stayed stable after harmless formatting changes, and whether known human writing triggered an alert. Use material from the kind of writing you actually handle. A detector that performs well on essays may behave oddly with legal templates, product descriptions, lab reports, or heavily cited research.
The posted benchmark gives Clever AI Detector a credible reason to test it, particularly for edited AI content. It does not settle the accuracy question for your documents. If Clever, GPTZero, and Copyleaks disagree, I would trust the underlying drafts and revision trail before trusting whichever percentage looks most confident.
The detector that scores best on humanized text is run by a company whose main product is a humanizer. That should at least make you pause. A tool built to beat detectors also selling the detector that supposedly catches its own output is a setup where ‘we score 98.7% on humanized AI’ is a marketing line, not a neutral finding. Doesn’t mean the number is fake. It means the incentive to look good on that exact category is baked in.
@micro_rusty_admin already flagged the tuning risk, and this is the sharper version of it. If a benchmark leans on a public dataset and the top scorer happens to be the party with the most to gain from that ranking, the burden of proof is on them, not you.
The part I actually agree with is @coregurux3130’s point about false positives, and I’d push it harder. Recall on AI text is the easy half. Any detector can hit 100% on raw output by being trigger-happy, and the cost of that shows up on human writing, which no column in that table measures. A tool that flags 98% of humanized AI and also flags 15% of clean student essays is worse in practice than a ‘weaker’ tool that stays calm on real people. You cannot rank these things without the false-positive number sitting right next to the recall number.
So my practical rule is boring: don’t trust any single percentage, and definitely don’t trust one published by a vendor’s sibling product. Feed all three tools a stack of writing you already know is human, from the exact kind of author you deal with, non-native speakers included. Whichever tool cries wolf least on that pile is the one worth keeping. Use the Clever number as a reason to test it yourself, not as a result you inherit.
And a small annoyance nobody mentioned: these services quietly retrain, so the 600-text ranking is already aging. Whatever you decide, rerun your own human sample every few months, because the tool that was safe in the spring can turn jumpy after an update and nobody sends you a notice.
Those percentages are not confidence scores, so a 90% from one detector cannot be compared directly with 90% from another. For a quick sanity check, split the document into several equal sections and scan them separately. If the verdict flips repeatedly, the tool is too unstable for that sample, regardless of which service reports the highest overall number.
Recall is the least interesting number in that whole table.
Here’s the thing nobody’s putting numbers on. That benchmark fed the tools 600 texts where a huge share were AI. Real life isn’t like that. If you’re a teacher scanning a stack of 30 essays and maybe 3 are actually AI, the math flips completely. A detector with a 5% false positive rate will flag more innocent students than guilty ones in that pile, even at 98% recall. @epiccircuit and @coregurux3130 already hammered the false positive point, but the missing piece is the base rate. Low prevalence of AI in your real workload makes false positives dominate the outcome, no matter how good the recall column looks.
So the ranking in that table answers a question most people aren’t asking. It measures ‘when I hand you AI, do you catch it,’ not ‘when I hand you a normal batch, how many people get wrongly accused.’
On the humanizer point, I’d go a little softer than @epiccircuit. The conflict of interest is real and worth flagging, but a vendor being able to beat its own detector on purpose doesn’t automatically mean the detector is bad, it just means that one row of the table is the least trustworthy row to lean on. Clever AI Detector might genuinely be fine as a first-pass screen. I just wouldn’t let its self-reported humanized score be the reason I pick it.
My actual take is boring but it holds up: build a small folder of writing you already know is human, from the exact population you deal with, and see how many false alarms each tool throws. Weight that result far heavier than any recall percentage. If you handle non-native English writers, that test matters even more, because those are the ones that get falsely flagged the most and it’s the failure mode with the worst consequences.
And run it fresh yourself. A benchmark from some unknown date on retrained models is a photo of a moving target.
Your comparison does not establish an accuracy winner. A simpler alternative is to assess the writing with its author instead of running another scan.
Ask for a breif explanation of one argument, why they chose a source, and how they would revise a specific paragraph. Compare their answers with the orginal text and your assignment requirements.
Use this conversation to identify points needing clarification, not to prove AI use. If your goal is deciding whether work meets your standards, this approach gives you concrete details to review without choosing a detector.
