I’m new to Android and I can’t figure out how to fully power off my phone instead of just restarting or locking the screen. The usual power button long-press isn’t giving me the options I expect, and I’m worried I might be doing something wrong or damaging the device. Can someone walk me through the correct steps to safely shut it down and mention if different brands (Samsung, Pixel, etc.) do it differently?
Yeah, Android power menus got weird on newer phones, so you’re not doing anything wrong. Here are the main ways to fully power off, depending on what you have.
- Try the “classic” method
• Hold Power button for about 3 to 5 seconds.
• If a menu pops up, tap Power off or Shut down.
• Confirm if it asks.
If your phone only gives Restart or Emergency or nothing, move on.
- On Android 12 and newer (or some Android 11 skins)
A lot of phones moved the power menu into the software.
Try this:
• Hold Power + Volume Up together for a few seconds.
Some brands use Power + Volume Down instead.
• If a menu appears, tap Power off.
If that works, that is your new “real” power combo. You can use it every time.
- Check if the Power button is set to open a voice assistant
On Samsung, Pixel, and some others the Power button is set to open Google Assistant or Bixby.
Example for Samsung (One UI):
• Go to Settings.
• Tap Advanced features.
• Tap Side key.
• Under “Press and hold”, pick Power off menu instead of Wake Bixby.
Then hold the Power button again, you should see Power off.
On Google Pixel:
• Go to Settings.
• Tap System.
• Tap Gestures.
• Tap Press and hold power button.
• Turn off the assistant option or set it to show the power menu.
The exact wording changes by phone, but look for Side key, Power key, or Gestures.
- Use the Quick Settings shortcut
Some skins add a power icon in the pull down menu.
Try this:
• Swipe down from the top twice to fully open Quick Settings.
• Look for a power icon or “Power off”.
• Tap it, confirm shutdown.
If you do not see it, tap the little pencil or edit icon in Quick Settings to see hidden tiles. There might be a “Power menu” tile to drag into the active area.
- If the screen or software is frozen
If nothing responds and you need a hard power off:
• Hold Power + Volume Down together for about 10 to 15 seconds.
On many phones this forces a reboot. If you want it fully off, when the logo appears, hold Power again when it restarts and pick Power off from the menu once Android loads.
Some phones turn fully off after a long press combo instead of reboot. It depends on brand.
If that combo does not work, try:
• Power + Volume Up for 10 to 15 seconds.
- Brand specific quick notes
These are common defaults, but models differ.
Samsung (recent models):
• By default, hold Power opens Bixby.
• Power menu: Power + Volume Down, or change Side key in settings as above.
Google Pixel:
• Long press Power should bring up the power menu, but assistant behavior might override it.
• If it opens Google Assistant, go to System > Gestures > Press and hold power button.
OnePlus:
• Press and hold Power + Volume Up for power menu.
• You can change side key behavior in Settings > Buttons & gestures (names change by version).
Xiaomi / Redmi / POCO:
• Long press Power usually still shows the power off slider.
• If not, use Power + Volume Up.
- Quick check about “locking vs powering off”
Locking:
• Short press Power. Screen turns off, phone stays on, you still get calls and notifications.
Restarting:
• Phone shuts down then starts again. Good for fixes, not for saving battery overnight.
Powering off:
• Phone turns off fully. No calls, no alarms, no notifications. Good for storage, flights with no battery, troubleshooting.
If you share your phone model and Android version, people can give exact button steps. Different skins move this stuff around, which is why it feels confusing when you are new to Android.
If the long-press stuff from @hoshikuzu isn’t doing it for you, I’d focus on two other angles:
1. Check what your specific brand did to the power button
A lot of manufacturers quietly sabotaged the “normal” power menu in their own weird ways.
Examples (rough, varies by model):
Samsung
- Open the power menu from the lock screen:
- Wake the screen
- Swipe down the notification shade
- Tap the power icon near the top (next to settings / search)
- That’s often easier than memorizing button combos.
Pixel
- Use the lockscreen as well: hold power once to turn screen on, then hold power again a bit longer. Some Pixels react differently on the second long-press from the lockscreen compared to when the phone is unlocked.
Chinese brands (Oppo / Realme / Vivo etc.)
- Some require a longer hold than you expect. Like a solid 5–7 seconds before the power slider shows. If you let go too early it just locks.
Yeah, it’s dumb, but testing from the lockscreen vs unlocked can actually change behavior.
2. Use software settings to give yourself a reliable off switch
Instead of hunting combos every time, set up a “soft” power button:
- Pull down Quick Settings twice
- Look for a tile like:
- Power menu
- Device controls
- System controls
- If you find one, long-press it or drag it into the active tiles via the edit/pencil button. Then:
- Any time you want to shut down, just pull down and tap that tile.
If your skin doesn’t offer a power tile, check for accessibility options:
- Settings → Accessibility
- Look for something like:
- Accessibility Menu
- Assistive Touch / Floating ball / Smart touch
- Turn that on and you usually get a persistent on-screen button with shortcuts. One of those shortcuts is often “Power” or “Power menu.”
That way even if the physical key behavior is weird, you have a guaranteed on-screen way to fully power off.
Tiny point where I slightly disagree with @hoshikuzu
They mention using long-press button combos for a frozen phone, which is true, but on some newer phones the “forced reboot” combo never lets you stay powered off. It just cycles back on. If you really want it off after a forced reboot, go into Settings and disable things like “Auto power on after outage” or “Auto reboot” if your phone has them, otherwise it might keep turning itself back on at weird times.
If you share the exact model, you can usually get a one-line “press this, then that” answer, but until then, I’d:
- Try the power-related tile in Quick Settings, and
- Turn on an accessibility menu that exposes a power option.
Those two survive all the weird button remaps.
Since the long‑press tricks and tiles from @hoshikuzu aren’t quite solving it, I’d approach it from a slightly different angle: figure out whether your phone is actually preventing full shutdown.
1. Check if “side key” is mapped to something else
On some Android skins the power button is now called “Side key” and is remapped to launch the assistant instead of the power menu.
Try this path (names vary a bit):
- Settings → Advanced features / System → Side key / Power key
- Change the “Press and hold” action from “Wake Assistant” or “Voice assistant” to “Power menu”
After that, the normal long press should bring back the classic Shut down / Restart dialog. This is much cleaner than relying on extra tiles.
2. Look for “Power off” being blocked by admin or kids mode
If you are using:
- Work profile
- Parental control / Kids mode
- Device policy from school / company
Sometimes those restrict power options.
Quick check:
- Settings → Security / Device admin apps
- Disable anything you recognize as work / parental control (if you are allowed), then retry the long press.
If you see a message like “Power options restricted by admin,” that is your culprit and no combo will fix it until those rules change.
3. Turn off “Auto power on” so OFF actually means OFF
I slightly disagree with @hoshikuzu on the reboot part. Even if you do a forced reboot, the bigger annoyance is phones that automatically turn themselves back on.
Look in:
- Settings → Battery / System / Scheduled power on & off
- Disable:
- “Schedule power on”
- “Auto reboot”
- “Auto power on after outage” or similar
Once those are off, when you finally manage to shut it down, it will stay off.
4. As a fallback, use recovery to confirm it can shut down
If you are really worried the device cannot fully power off:
- Hold power + volume up (or down, depends on brand) for several seconds until you see a logo or a tiny text menu.
- In that menu, use volume keys to select “Power off” or “Power down,” then confirm with power.
If it powers off from there and stays off, your hardware is fine and the problem is just Android’s UI choices.
5. About using a product like “How To Turn Off Android Phone”
If you stumble over a written guide or e‑book titled something like “How To Turn Off Android Phone,” the pros and cons roughly break down like this:
Pros
- Usually collects all the different brand quirks (Samsung, Pixel, Xiaomi, etc.) in one place
- Good for beginners who want screenshots and step‑by‑step flows
- Often explains related settings like auto power on, scheduled restart and button remapping in one coherent guide
Cons
- Can go out of date quickly when manufacturers change button behavior in updates
- May focus on a few popular models and skip niche or older phones
- Slower than just testing a couple of settings directly on your device
So it can be handy for reference, but I would still start in your own Settings app first.
If you share the exact brand and model, you can typically get a very specific “press X + Y for Z seconds” solution. Until then, I’d first remap the side key back to the power menu and disable any scheduled or auto power on options, so once you finally hit “Power off,” the phone actually stays off.
You covered side key mapping, admin blocks, auto power on, and recovery. Try a simpler route, the Accessibility Menu with an on screen Power button.
Steps:
- Settings → Accessibility → Accessibility Menu → On.
- In System navigation, enable the Accessibility button if needed.
- Tap the stick figure icon or swipe up with two fingers.
- Tap Power, then Power off.
Works on Pixel, Samsung, Xiaomi, Android 10 to 14. No remaps needed. If teh button hides, search Accessibility Menu in Settings and pin its shortcut.
