How to screen mirror iPhone to Philips TV if it doesn't show up?
My Philips TV never appears in the Screen Mirroring list on my iPhone, even though both show the same Wi-Fi network name. I was trying to display a photo from my camera roll on the living room TV, with the phone sitting on the coffee table.
I’ve restarted both devices and checked the TV’s network settings, but the list on the phone stays empty. I also looked through the TV menus for a mirroring option without finding anything clearly labeled for iPhone. What should I check next to establish whether this TV supports screen mirroring from an iPhone in the first place?
“No lag” is the claim I’d be most careful with here. An HDMI adapter can connect an iPhone to a Philips TV without Wi-Fi, but I don’t have measurements that justify promising zero delay. That distinction matters: I want a connection that fits what I’m doing, not a fix sold with more certainty than the details support.
I’d separate watching a video from sharing my screen
If I’m only sending a video to the television, I’d start with the cast button in YouTube or another streaming app that offers one. That’s different from mirroring everything on the iPhone, and it might make a separate mirroring app unnecessary.
For a wired connection, the options described are Apple’s Lightning Digital AV Adapter or a USB-C to HDMI adapter, depending on the phone’s connector. Connect the adapter and HDMI cable, then select that HDMI input on the TV. The lack of a Wi-Fi requirement is useful enough without adding an unverified latency promise.
Wireless is where I’d stop treating “Philips TV” as a complete model description. Philips sets come with Google TV, Android TV, Roku TV, or Titan OS. Those names aren’t interchangeable, and I can’t confirm an individual set’s capabilities from the Philips badge alone.
Some newer models, including certain Philips Roku TVs, support AirPlay 2. I’d check the TV settings for AirPlay and enable it if available. With the phone and TV on the same Wi-Fi network, the iPhone route is Control Center, Screen Mirroring, then the TV’s name and any code shown onscreen.
I wouldn’t treat a missing TV in that list as conclusive proof that AirPlay isn’t supported. I’d check the model’s support information before ruling it out.
The app route needs a closer look at the limits
For a set without AirPlay, the DoCast app is another option. Its stated compatibility includes Chromecast-equipped Philips TVs, plus Roku, Fire TV, and DLNA smart TVs. I can’t verify that every Philips model running Google TV or Android TV will work, so I’d check the actual set rather than assume.
The described setup is straightforward: put both devices on the same Wi-Fi network, open the app, select the television, and choose screen mirroring or a video, photo, or song.
The payment distinction is what I’d examine before getting comfortable. Photo casting is described as free and unlimited, while full screen mirroring and longer video or music streaming require Premium. I’d compare those limits with the DoCast details; I can’t confirm that the same terms apply to every version.
An Apple TV or Roku stick is also presented as a way to add AirPlay, but I’d confirm support on the device before buying.
My verdict: I wouldn’t install or buy anything until I’d checked the TV’s exact capabilities. DoCast looks like an option, not an automatic first choice.
Don’t factory reset your TV because the Wi-Fi names are the same. This doesn’t necessarily mean that the TV can communicate with your phone via Wi-Fi. Your phone may be on a different network. Also, features like ‘AP Isolation’ and ‘Client Isolation’ on some routers prevent communication between devices on the same network. It might be a good idea to check that before flashing anything.
I agree with @alphapulse1128 about checking the model, but if yours supports AirPlay and it’s enabled, I’d investigate the network next. As a quick test, connect both devices to your main home network rather than a guest network. On your own router, check whether device isolation is enabled for that network. AirPlay discovery relies on local network traffic that can get blocked between network segments, even when both devices have working internet. Don’t disable the router’s whole firewall to troubleshoot this.
Before spending money, post the Philips model number and if you are using your own router or building Wi-Fi. I would use that info to decide if I’d keep looking into Airplay support or device discovery. The matching network name alone would not convince me to rule out the router.
Don’t start cycling through casting apps without checking their permissions. There’s a catch with @alphapulse1128’s app route: on your iPhone, go to Settings > Privacy & Security > Local Network and enable access for the casting app you’re trying. Without it, the app may be unable to find your TV despite having internet access. That’s a separate troubleshooting step, though, not a fix for the empty Screen Mirroring list. Apple’s built-in AirPlay doesn’t depend on that app permission.
A “Screen Mirroring” option on a TV is not necessarily a sign that it will work with the identically-named iPhone button. Philips has used “Wireless Screencasting” for Miracast, which iPhones don’t support. If that is the receiving screen you have open, waiting there will not make the TV appear in Apple’s list. The similar labels are genuinely unhelpful.
Before following @swiftserver8529 into router settings, I’d check what that particular TV menu actually says. Look for an explicit reference to AirPlay rather than treating “wireless display” as confirmation. If the feature is Miracast-only, that explains why this route fails without needing to blame your Wi-Fi. It doesn’t establish whether the television has a separate AirPlay feature, though.
For your photo, an AirPlay receiver capable of receiving AirPlay streams is probably available, so to display the photo on it, you’d simply open the picture in Photos, tap Share, then AirPlay, then pick the receiver. You wouldn’t need to mirror your phone’s screen just to display that one picture. This isn’t a workaround for the lack of support for AirPlay in iOS or the inability to discover AirPlay devices, but rather how I’d likely go about sharing a picture from my camera roll and not my phone’s screen.
The router is not the sole reason why local connections can be interrupted. Some virtual private networks or network-filtering apps on the iPhone can interrupt AirPlay as well. Assuming you made sure that your TV supports AirPlay, I would double-check your phone before attempting to change any router settings.
On your local network, turn off any VPN of your own accord that you can and re-open Screen Mirroring as a test, not a permanent solution. If you have a security application that utilizes network filtering, check that one out separately instead of turning everything off. Apple even suggests that you test communication between devices while disabling such features if you plan on doing so. If the TV only shows up when your VPN is off, the issue is likely in its settings. I suggest reporting that to their support team instead of purchasing a casting app. If none of that works, abandon the idea. If it is your work phone, leave their profiles untouched and ask your IT department to do it.
Copy the photo to a USB and then plug the USB into the Television. Any Philips TV that I’ve tried has a media player that reads from USBs which saves the hassle of having to guess the Wi-Fi password. If the sole purpose is to project one photo onto the TV in the living room, then that task would be achieved in about two minutes without needing to download any apps and without being bombarded by codes to enter.
I say that because the thread has drifted into router filtering, local network permissions, and VPN checks, and all of that is valid troubleshooting, but it’s a lot of work for a single photo. @bytehackerpoint nailed the part most people trip on, which is the Miracast vs AirPlay label mess. Philips loves calling things ‘Wireless Screencasting,’ and sitting on that screen waiting for your iPhone to appear is a dead end because iOS doesn’t speak Miracast. That alone explains a good chunk of ‘it never shows up’ complaints before anyone touches the router.
Where I’d slow down is the assumption that enabling AirPlay in the menu is the finish line. On some Philips models AirPlay only landed after a firmware update, and if the set hasn’t checked in for a while, the option can be missing or flaky until you let it update. So if you confirm the model supports AirPlay but it still won’t show, run the system update first before you start blaming network isolation.
The casting app route is fine as a fallback, but honestly for photos it’s overkill since @bytehackerpoint already pointed out you can AirPlay a single image straight from the Photos share sheet without mirroring anything. Mirroring is the heavy option. You only really need it if you’re showing something that lives inside an app with no cast or share support.
My rough order, if I were you: USB stick for immediate use, then perhaps an update for the model number and AirPlay firmware if you want to do wireless for the long term. Don’t buy anything before you know which OS your particular Philips uses, because that defines the rest.
Do not adjust too many settings at once if you do not want the solution to stay elusive. Assuming you have ruled out the possibility that your TV does not support AirPlay, try your second iPhone on the same network and see if it shows up on the Screen Mirroring list. If it does, I would advise looking into your iPhone rather than fiddling with the settings on the television or the router.
Avoid treating the second-phone test as a definitive diagnosis. @redfalcon1441’s suggestion helps narrow things down if the TV appears on the other iPhone, but an empty list on both phones doesn’t identify the cause. That result still fits several possibilities, including missing AirPlay support or a discovery problem. It’s a comparison test, not a verdict that the router needs changing.
