How To Rotate Screen On Mac
I accidentally changed my Mac display orientation while trying to adjust resolution, and now everything is sideways. I can’t seem to find a clear way to rotate the screen back or set a custom rotation. Can someone walk me through the correct steps to rotate the screen on a Mac, including any shortcuts or hidden settings I should know about?
Happened to me once during a late-night “let me tweak one tiny thing” session. Here is how you fix it and how rotation works on macOS.
First, quick reset to normal:
  1. On macOS Ventura or Sonoma
    • Click Apple menu.
    • System Settings.
    • Go to Displays.
    • On the right side, look for “Rotation.”
    • Set it to “Standard.”
  2. On macOS Monterey or older
    • Apple menu.
    • System Preferences.
    • Displays.
    • If you do not see “Rotation,” hold Option and then click the “Displays” icon in System Preferences again, or click the “Scaled” radio button while holding Option.
    • A “Rotation” dropdown should appear.
    • Set it to “Standard” or “0°.”
  3. If the screen is sideways and hard to use
    • Turn your head or your display so you can read things for a minute.
    • Use keyboard only where possible:
    • Press Cmd + Space, type “displays”, press Return.
    • Arrow keys and Tab to reach the Rotation field and change it.
Custom rotation info:
macOS only supports preset rotation values. Usually: 0°, 90°, 180°, 270°. No fine-grain rotation like 10° or 23°. If you need custom angles for design or photo work, you need to rotate inside an app such as Preview, Photoshop, Affinity, or similar.
If rotation does not show at all:
  1. Check the display type
    • Internal MacBook screens often support rotation.
    • Some external monitors do not report rotation support, so macOS hides the option.
    • Try a different cable or port, or try a different monitor to see if the option appears.
  2. Reset display settings
    • Shut down the Mac.
    • Unplug external monitors.
    • Start the Mac.
    • Plug the monitor back in.
    • Open Displays again.
  3. Reset NVRAM (for Intel Macs only, not Apple silicon)
    • Shut down.
    • Turn on and immediately hold Option + Command + P + R.
    • Keep holding for about 20 seconds.
    • Then check Displays again.
Short version if you want the quickest path:
Ventura / Sonoma: Apple menu → System Settings → Displays → Rotation → Standard.
Monterey or older: Apple menu → System Preferences → Displays → hold Option if needed → Rotation → Standard.
Once you flip it back, avoid mashing the Option key near display settings unless you really want that menu to appear.
Turn the monitor, not your brain. :sweat_smile: Since @boswandelaar already covered the normal “go to Displays and pick Standard” route, here are a few different tricks and edge cases that might be what you actually ran into:
  1. Use the mirrored display as a “rescue”
    • If you have a second monitor or TV, plug it in.
    • Go to Apple menu → System Settings / System Preferences → Displays.
    • Temporarily turn on mirroring.
    • One of the mirrored displays will be upright, so you can use that to change the rotation on the sideways one without twisting your neck.
  2. Change the wrong display by accident
    • macOS loves to apply settings to the “active” display.
    • In Displays, make sure you’re actually editing the correct screen.
      Look at the little layout diagram at the top:
      • Click the rectangle that corresponds to the rotated screen.
      • Then adjust the Rotation for that one specifically.
    • People often keep rotating the laptop screen while their external remains normal or vice versa.
  3. Display arrangement looks broken after rotation
    • When you rotate an external monitor 90°, macOS sometimes stacks the displays weirdly.
    • In the Displays layout, drag the screens around so their edges line up roughly where they are on your desk.
    • Also drag the white menu bar rectangle to the display you actually want as “main.” That can fix some cursor and window confusion when everything is sideways.
  4. Apple silicon quirk
    • On Apple silicon Macs, you can’t use NVRAM reset the old way, so if rotation seems stuck or glitchy:
      • Shut down.
      • Unplug externals.
      • Turn it back on.
      • Log in, then plug in the display again.
    • If rotation options randomly disappear, check for a macOS update. Apple has quietly fixed a few display bugs in Ventura/Sonoma point releases.
  5. If you rotated while using DisplayPort vs HDMI
    • Some monitors behave differently depending on the port:
      • Try swapping from HDMI to DisplayPort or vice versa.
      • Then reopen Displays. Sometimes the Rotation dropdown only appears with certain EDID data from the monitor.
    • Also try a different cable. A flaky adapter can make macOS “forget” that rotation is supported.
  6. Custom rotation reality check
    • You mentioned “custom” rotation. macOS itself basically says “nope” to anything that is not 0 / 90 / 180 / 270.
    • Workarounds:
      • Rotate individual content in apps (Preview, Photoshop, Figma, etc.).
      • Use a window manager / overlay app for visual guides instead of physically tilting your whole display a weird angle.
    • There used to be hacks and 3rd‑party kext tricks for arbitrary rotation, but on modern macOS with SIP and Apple silicon, that’s pretty much dead and not worth the instability.
  7. When nothing changes, but the menu says it did
    • If you change Rotation and the screen doesn’t actually rotate:
      • Turn off any “pivot/rotation lock” setting on the monitor’s own on‑screen menu, if it has one.
      • Some displays handle rotation internally and ignore what the computer says.
    • Also disconnect and reconnect with the monitor already physically upright, then open Displays again. Occasionally macOS “negotiates” a different rotation support list on reconnect.
Once you get it back to “Standard,” consider this: leave Rotation alone unless you’re physically rotating a portrait monitor. Most folks hit it while messing with resolution or scaled settings, exactly like you did.
If the usual Displays panel tricks (like @boswandelaar described) are not fixing your sideways Mac screen, try attacking it from a few less obvious angles:
1. Reset per‑user display prefs (without nuking your whole system)
Sometimes rotation sticks because your user’s display plist is corrupted.
  1. Log into the affected account.
  2. Open Finder → Go menu → Go to Folder…
  3. Paste: ~/Library/Preferences/
  4. Find files like:
    • com.apple.windowserver.plist
    • com.apple.preference.displays.plist (if present)
  5. Move them to a temp folder on your Desktop (do not delete yet).
  6. Log out and back in.
  7. Check System Settings → Displays again and set rotation back to Standard.
If it fixes the problem, you can delete those old plist files. If not, move them back.
2. Test in a fresh user account
This quickly tells you if it’s a system problem or just your profile.
  1. Apple menu → System Settings → Users & Groups.
  2. Create a new user.
  3. Log into that new account and check Displays.
  4. If rotation works normally there, your main account’s prefs are the issue, not the Mac itself.
3. Safe Mode to flush display caches
On Intel and Apple silicon this behaves differently, but the idea is the same: Safe Mode clears caches and reloads display drivers.
  • Turn it on and immediately:
    • Apple silicon: hold the power button until you see “Loading startup options,” pick your disk, then hold Shift and click “Continue in Safe Mode.”
    • Intel: hold Shift right after the chime until you see the login window.
  • Log in, open Displays, try to set rotation back.
  • Restart normally.
4. Check for per‑app “smart rotation” or accessibility helpers
Some third‑party tools can ask macOS to rotate or transform the display for accessibility reasons or presentations. If you installed anything like:
  • Screen magnifiers
  • Presentation assistants
  • Color calibration / screen filter utilities
Try disabling or uninstalling them, then reboot. A background helper can reapply a rotation even after you change it.
5. External monitor firmware & OSD quirks
@boswandelaar mentioned ports and cables. I half agree, but in practice the monitor’s own firmware/settings are often the hidden villain.
  • Open the monitor’s OSD menu with its physical buttons.
  • Look for any Rotation / Pivot / Orientation settings and set those back to default.
  • If the monitor vendor has a firmware updater app, run that. Some older displays misreport their supported rotations to the Mac.
6. “Custom rotation” reality check & alternatives
macOS really is locked to 0 / 90 / 180 / 270. If you want something in‑between:
  • Rotate content in apps (Preview, Photoshop, etc.) instead of the whole system.
  • Use a window manager that can snap or tilt windows visually rather than relying on real display rotation.
  • Hardware solutions like physically tilting the monitor at a nonstandard angle and keeping macOS at Standard are less glitchy than any hack.
Since you mentioned “How To Rotate Screen On Mac,” here are quick pros & cons of staying with macOS’ built‑in rotation instead of hunting for obscure utilities:
Pros
  • Stable, supported across system updates
  • Simple: tied directly into System Settings → Displays
  • Works with Apple silicon and modern security features
Cons
  • Only 4 rotation angles
  • Some monitors hide the Rotation dropdown entirely if they misreport capabilities
  • No per‑app rotation, it is always system‑wide
In short:
  1. Make sure you are tweaking the correct display.
  2. If that fails, reset user display prefs, test a new user, and try Safe Mode.
  3. Double check your monitor’s OSD and firmware.
Once you get it back to “Standard,” I’d leave rotation alone unless your monitor is actually mounted in portrait. That setting is annoyingly easy to hit while changing resolution.
Recap: You reset display prefs, tested a new user, used Safe Mode, checked third‑party helpers, and inspected the monitor OSD. You noted macOS supports only 0, 90, 180, 270.
Simpler fix, force a mirroring reset.
  1. System Settings, Displays.
  2. Turn on Mirror Displays.
  3. Wait 5 seconds, orientation returns to Standard.
  4. Turn mirroring off.
If the UI is sideways, press Command F1 to toggle mirroring. On notebooks press Fn Command F1. This works fast on Ventura and Sonoma in my tests. If it fails, power cycle teh monitor adn repeat.
