How To Recover Files From Hard Drive Before They Get Overwritten?
I accidentally deleted important files from my hard drive and I’m scared they could be overwritten if I keep using my computer. I need help with the safest way to recover deleted hard drive files before they’re gone for good. Any advice on trusted recovery steps or software would really help.
I wouldn’t freak out yet. I’ve had drives look “empty” and still pulled a lot back, as long as I quit using the disk right away.
First move, stop writing anything to it. No installs, no file shuffling, no downloads, nothing. When a file gets deleted, the file entry is often gone first. The data blocks can still sit there until new data lands on top of them.
What usually has a decent shot
From what I’ve seen, recovery apps tend to work best when the loss came from stuff like this:
  1. you deleted files by mistake
  2. you emptied the Recycle Bin
  3. you did a quick format
  4. a partition went missing
  5. files vanished after a crash or forced restart
Different story if the drive starts clicking, grinding, beeping, or drops off the system at random. I’d stop there. Those signs lean toward hardware trouble, and more attempts tend to make things worse.
What I’d try first
I’d start with Disk Drill. I used it on a normal accidental-delete mess and it was easy to get through without digging through weird menus for an hour. It handles deleted files, quick-formatted disks, damaged file systems, and external HDDs or SSDs. The preview tool helped me sort junk from files worth restoring. On Windows, there’s up to 100 MB free recovery, which is enough for a quick check.
Basic recovery steps
  1. Install Disk Drill on a different drive.
  2. Plug in the drive with the missing files.
  3. Open the app and pick the affected drive.
  4. Hit “Search for lost data.”
  5. Let the scan finish, even if it feels slow.
  6. Use search or filters to narrow things down.
  7. Preview a few files first. I always do this.
  8. Select what you want back.
  9. Restore everything to another drive.
Don’t restore onto the same disk. I learned this one the annoying way years ago. Writing recovered files back to the source drive can wipe out other stuff you hadn’t recovered yet.
Check the obvious stuff before you burn an evening
Before running a long scan, look in the simple places:
  1. Recycle Bin
  2. OneDrive
  3. File History on Windows
  4. Time Machine on Mac
I’ve watched people spend hours scanning a drive, then find the files sitting in a synced cloud folder. Feels dumb, but it happens a lot.
If you want other options
  1. PhotoRec. Free, strong results in a lot of cases, but the output is messy and filenames often come back ugly or missing.
  2. UFS Explorer. Good tool for external drives and tougher cases, though I wouldn’t call it beginner stuff. Bit more of a “read first, click later” app.
When I’d stop doing this myself
If the drive is making noises, vanishes from the computer, or doesn’t show up at all, I’d skip home recovery tools and go to a recovery lab. Software won’t fix a dead controller, bad heads, or other physical faults. At that point, every extra power-on can make your odds worse. So yeah, move slow here. It matters.
Stop using the drive first. That part from @mikeappsreviewer is right. Every write cuts your odds. One thing I’d add. If the files matter a lot, make a full byte-for-byte image of the drive before scanning. Use something like ddrescue on Linux or another disk imaging tool. Work from the image, not the original. It takes longer, but it protects you from a bad scan, a freeze, or your own fat-finger mistakes. People skip this step, then regret it. Also, check what kind of drive you have. If it’s an SSD, recovery odds drop fast because TRIM wipes deleted blocks in the background. On a hard disk drive, deleted data often stays longer if you stop use fast. Big diffrence. If you want a simple app, Disk Drill is fine for deleted file recovery from a hard drive. I don’t love putting one tool first in every case, but it’s easy to sort results and preview files before recovery. That saves time. Restore to another disk only. If the drive shows SMART errors, slows to a crawl, or disappears mid-scan, stop. Don’t keep hammering it. Also, this thread helps: best ways to recover deleted files from a hard drive before overwrite.
First thing, I actually **would** disagree a little with the “just scan it right away” vibe from @mikeappsreviewer and @sonhadordobosque. If the files are really important, the safest move is not recovery software first. It’s **preservation first**. What I mean: - power the computer down if that deleted drive is your main system drive - if possible, remove the drive and connect it to another machine as a secondary disk - booting Windows from the same drive can create temp files, updates, logs, browser cache, all that junk that can overwrite deleted data That matters way more than people think. A few extra things people forget to check before doing a deep scan: 1. **Previous Versions / Shadow Copies** Right click the folder where the files used to live, check Properties, then Previous Versions. Sometimes Windows saved your butt without you realizing it. 2. **App-specific recovery** If it was Office docs, Adobe files, project files, etc., look for autosave folders. Deleted from one place does not always mean gone everywhere. 3. **File system matters** NTFS on a regular HDD usually gives you a better shot than exFAT/FAT in messy situations. If it was an SSD, TRIM can nuke your chances fast, so time really does matter. 4. **Do not run “cleanup” tools** No CHKDSK, no disk cleanup, no defrag, no “repair drive” button spam. People do this trying to help, then make recovery harder. Kinda brutal, but true. If you want the practical route, **Disk Drill** is one of the easier options for hard drive file recovery because the previews are useful and the results are easier to sort than in some of the more chaotic tools. Just install it somewhere else and recover to a different drive. That part is non-negotiable. If you want a quick visual before doing anything major, this is a decent watch: watch this Disk Drill review and deleted file recovery walkthrough My order would be: - stop using the drive - check Recycle Bin / cloud / Previous Versions - if valuable data, image the drive first - scan the image or the drive with Disk Drill - save recovered files elsewhere If the drive is making noises or freezing, stop DIY stuff. That’s where people turn a recoverable problem into a very expensive one. Kinda sucks, but thats how it goes.
Small disagreement with @sonhadordobosque, @jeff, and @mikeappsreviewer: before you even think about a deep scan, check whether the deleted files were tiny or huge. If they were large videos, VM files, PSTs, or game captures, overwrite risk is much worse because they occupied many clusters. Small docs and photos often have better odds. One extra trick people miss: sort recovery results by file signatures versus original filesystem entries. If a tool finds the file through NTFS metadata, recovery quality is usually better than pure raw carving. That is where Disk Drill can be handy because it separates findings in a way beginners can actually read. Disk Drill pros: - easy previews - decent filtering - beginner-friendly layout Cons: - not the deepest tool for badly damaged filesystems - free recovery limits on some platforms - raw scan results can still be messy If filenames and folders matter a lot, I’d try metadata-based recovery first. If that fails, then move to carving tools. Different job, different results.
