I’ve been training a few AI models for a personal project, but performance and accuracy drop whenever I scale up the data or tweak the architecture. I’ve tried basic hyperparameter tuning and regularization, yet I’m not getting consistent improvements. Can anyone share practical strategies, tools, or workflows for effectively optimizing AI models for both speed and accuracy?
This usually means something is off in data, optimization, or scaling strategy, not only in hyperparams.
Here is a practical checklist.
- Data issues
- Check label noise. Take 100 random samples, verify labels by hand. If more than ~5 to 10 percent are wrong, fix that first.
- Check train vs val distribution. Plot simple stats. For text, look at length histograms. For images, resolutions and classes per set.
- If performance drops when adding data, your new data might come from a different distribution or have messier labels. Try training on:
a) old data only
b) new data only
c) mixed data
Compare. That tells you where the drop comes from.
- Overfitting vs underfitting
- Plot training and validation loss over epochs.
- Train ↓, Val ↑ means overfitting.
- Both high and flat means underfitting.
- If overfitting when model scales up, increase:
- Weight decay a bit, e.g. from 0.0001 to 0.001
- Dropout, but not too much. Move from 0.1 to 0.3 and check.
- Data augmentation for images or simple text noise for NLP.
- If underfitting, reduce regularization and maybe simplify augmentation.
- Optimization details
- Learning rate usually breaks things more than anything.
- Use LR range test (like in fastai) or try a simple grid: [1e-5, 3e-5, 1e-4, 3e-4, 1e-3].
- For bigger models, lower LR often works better.
- Use a scheduler. Cosine or step scheduler with warmup for transformers.
- Batch size. If you increase batch size, decrease LR or use linear scaling rule (double batch, double LR) and see which direction helps. Sometimes smaller batches generalize better.
- Gradient clipping around 1.0 if you see unstable loss spikes.
- Architecture changes
- Only change one thing at a time.
- More layers or width often need LR adjustment and sometimes more training steps.
- For transformers, depth is usually better than width, but deeper gets harder to train, so use:
- Residual connections
- LayerNorm in the right spots
- For CNNs, use standard backbones first. ResNet18 or 34 before inventing your own stack.
- Training protocol
- Fix a baseline setup that you know works on a small subset, like 5k samples.
- Get a stable training curve and reasonable accuracy there first.
- Then scale data size while keeping everything else fixed.
- If performance drops only after many epochs, try early stopping using validation loss or F1.
- Evaluation clarity
- Use the metric that matters for your task. Accuracy is misleading on imbalanced data.
- Try F1, AUC, or per class metrics.
- Plot confusion matrix. This shows if one class collapses when you scale.
- Practical debug recipe
If I were you, I would do this sequence:
- Step 1: Fix architecture to something known, like a standard ResNet or a small transformer from a library.
- Step 2: Take 10 percent of your data, clean labels, train until overfit, make sure the model can reach near 100 percent train accuracy. If not, there is an optimization or capacity issue.
- Step 3: Add back the full dataset, same hyperparams, then only tune LR and weight decay.
- Step 4: If performance still drops when adding data, inspect the new data distribution and labels.
Share some details and logs if you want more targeted advice:
- Task type and data size
- Model type and size
- LR, batch size, scheduler
- Train vs val curves over epochs
The answer usually hides in those plots.
Performance dropping when you add data or tweak the arch usually screams “your process is unstable,” not “try one more random hyperparam.” @voyageurdubois covered a ton of the standard checklist, so I’ll avoid just rehashing those knobs.
A couple of different angles that often get ignored:
1. Lock down everything and treat it like a scientific experiment
If every run changes multiple things, you’ll never know what broke what.
- Fix:
- Random seeds
- Data split
- Preprocessing pipeline
- Logging setup
- Change exactly one variable per run: either LR, or batch size, or model depth, etc.
- Keep a simple table or spreadsheet: run id, config, final metrics. It’s dull, but you’ll suddenly see patterns like “every time I turn on X augment, recall implodes.”
This sounds basic but most “why is my scaling broken” threads come from hidden config drift.
2. Check your input pipeline is not silently sabotaging you
People obsess about the model and ignore the fact that their dataloader is quietly wrecking everything.
Things I’d explicitly verify:
- Shuffling actually on for training and off for validation.
- No data leakage:
- Same sample appearing in both train and val (common with naive split by row instead of by user/id).
- Normalization stats computed on the full dataset including val/test.
- Preprocessing consistent:
- Same tokenization / normalization for train and val in NLP.
- Same resize / crop / normalization pipeline for images.
- When you “scale up data,” confirm you didn’t:
- Change class balance drastically without adjusting the loss or sampler.
- Accidentally include near-duplicates in train and much “cleaner” data in val.
Quick tests:
- Train on a tiny deterministic subset (like 1k samples), run multiple times, make sure results are stable within a narrow range.
- Turn off all fancy augmentations and see if performance becomes more predictable. If yes, your augment config might be trashing the signal.
3. Loss function and objective sanity check
This is a surprisingly common failure point.
- Class imbalance:
- Accuracy looks fine until you scale data, then the model learns to predict the majority class even harder.
- Try weighted loss, focal loss, or at least per class metrics.
- Wrong or misconfigured loss:
- CrossEntropy vs BCEWithLogits vs softmax + MSE monstrosities.
- Are you accidentally applying softmax twice? Or using
from_logits=Falsewith logits?
Small trick:
- Train a stupidly small model to convergence. If your loss doesn’t behave sensibly or you get weird gradients, you might have a loss mismatch, not a capacity issue.
4. Check that your model actually uses the extra capacity
Larger model not helping is sometimes a sign you’re saturating the signal.
Things to try that are different from the usual “more layers, more dropout”:
- Add a small bottleneck or projection before the head, especially for classification. Big models feeding directly into a tiny linear head can behave oddly when scaling.
- Watch gradient norms per layer (if you’re up for it). If deeper layers have near-zero gradients, you’re pseudo-training only the final layers. That’s not just LR, sometimes init or norm placement is off.
If you’re using something custom-ish:
- Compare against a “known good” stock model from a library with your dataset and pipeline.
- If stock model scales fine and yours collapses, your architecture or initialization choices are suspect.
- If even the stock model collapses with extra data, problem is elsewhere (data or training protocol).
5. Systematic scaling experiment
Different from what @voyageurdubois outlined, try this very rigid protocol:
- Fix a single model and hyperparam set that is “okay” on a small dataset.
- Train on:
- 5% of data
- 10%
- 25%
- 50%
- 100%
- Keep everything identical aside from dataset size and number of steps scaled proportionally.
Plot metric vs log(data size). You might see:
- Metric improves then drops after a certain size:
- That usually means the added portion of the data is from a different distribution or systematically mislabeled.
- Metric plateaus:
- Model might be capped in capacity or you’re regularizing too hard.
If it only breaks past a certain point, isolate “new” data beyond that point and inspect it separately.
6. Don’t overfit to hyperparam voodoo
I’m going to slightly disagree with the instinct to immediately reach for elaborate schedulers, fancy LRs, and a zoo of tricks. That can hide root causes.
Try a brutally simple baseline:
- Plain optimizer (Adam or SGD)
- Fixed learning rate
- No exotic scheduler
- Basic regularization only (weight decay, minimal dropout)
If that simple thing cannot scale, a clever scheduler is not going to save it. Once simple works reasonably, then add complexity.
7. “Can it memorize?” test
Pick ~500 to 1k samples. Train the model on only those, with the goal of overfitting:
- If it can’t overfit that tiny set:
- Optimization issue, architecture bug, or loss mismatch.
- If it overfits easily on the small set but fails on full data:
- Data quality, distribution shift, or evaluation setup is off.
This test saves days of guessing.
If you can share specific stuff like:
- Task (image / text / tabular)
- Rough dataset size
- Example train/val curves for small vs full dataset
you’ll probably get way more targeted pointers. Right now it smells like a mix of pipeline + experimental discipline issues rather than “you picked the wrong dropout rate.”
