I’m trying to enable cookies on my Mac so certain websites will remember my logins and shopping carts, but I’m not sure which settings to change in Safari or Chrome. I’m worried about breaking something or making my Mac less secure. Can someone walk me through the safest way to turn cookies on and what options I should choose?
Safari first, since that is the default on Mac.
Safari on macOS (Monterey, Ventura, Sonoma etc):
- Open Safari.
- In the menu bar, click Safari → Settings (or Preferences on older macOS).
- Go to the Privacy tab.
- Make sure:
• “Block all cookies” is unchecked.
• “Prevent cross-site tracking” is ON for more privacy. This still lets normal login and cart cookies work on most sites. - Click “Manage Website Data” if you want to remove old stuff from specific sites without nuking everything.
That setup keeps normal site cookies for logins and carts, while limiting creepy tracking across sites.
If some site still does not remember you:
- In Safari, open that site.
- Menu bar: Safari → Settings for This Website.
- Check there is no weird content blocking set, like disabling pop-ups or using strict content blockers that break login popups.
Now Chrome on Mac:
- Open Chrome.
- Click the three dots in the top right.
- Go to Settings.
- On the left, click “Privacy and security”.
- Click “Third-party cookies”.
Here are the useful options:
• “Allow third-party cookies”
Easiest for compatability. Least private.
• “Block third-party cookies”
Better privacy. Most login and cart stuff still works because those use first-party cookies.
• “Block third-party cookies in Incognito”
Most permissive for normal browsing.
If you want a good middle ground:
- Pick “Block third-party cookies”.
- Scroll down to “Sites that can always use cookies”.
- Click “Add”.
- Enter the sites you trust, like
https://www.your-store.com
Check “Including third-party cookies on this site” if the site uses external login or embedded payment widgets.
You will not “break” your Mac with these settings. Worst case, a site fails to log you in or forgets your cart. Then you:
• Loosen cookies for that one site.
• Or clear cookies for that site and log in again.
Extra quick checks:
• If you run any ad blocker or privacy extension, check its settings. Some block cookies or scripts that handle login and carts. Try disabling the extension for one test site.
• If you use Private Browsing in Safari or Incognito in Chrome, your logins and carts will not persist after closing the window. Use normal windows for stuff you want saved.
If you want higher privacy without constant nudging:
Safari:
• Keep “Prevent cross-site tracking” ON.
• Leave “Block all cookies” OFF.
Chrome:
• Use “Block third-party cookies”.
• Whitelist only the sites where you do banking, shopping, and work logins.
That gives you saved logins and carts on your chosen sites, while cutting down on random trackers watching your browsing.
And no, you are not going to break anything by flipping these toggles. Worst thing, a site whines, you relax settings for that single domain, and move on.
You’re not going to “break” your Mac with cookie settings, promise. Worst case, a site logs you out or forgets a cart, then you tweak and move on.
@viajeroceleste already nailed the basic toggles, so I’ll add the “why” and some checks that usually get missed.
1. Think in 3 layers instead of just flipping “allow cookies”
For both Safari and Chrome, what really matters is:
- First‑party cookies
- Set by the site you’re on.
- Needed for “stay logged in,” carts, preferences.
- You do want these for sites you use often.
- Third‑party cookies
- Set by stuff embedded on the page (ad networks, trackers, some payment widgets).
- Not required for most logins/carts, but some badly-built sites rely on them.
- Private / Incognito windows
- Even with cookies “allowed,” anything in these windows gets wiped when you close them.
- If your logins and carts vanish every time, check that you’re not living in Private/Incognito.
You can keep privacy and still have your cart survive more than 5 minutes by allowing first‑party cookies globally, then being picky with third‑party ones.
2. Safari: what actually affects your logins
I slightly disagree with the idea that “Prevent cross‑site tracking” is always harmless. On some weird older shopping or banking setups, that option can mess with SSO or embedded payment flows. So:
- If a specific site keeps forgetting you in Safari:
- Temporarily turn off “Prevent cross‑site tracking,” reload and test.
- If it starts working, you’ve found the culprit.
- Then decide: is this site important enough to justify that tradeoff, or just use Chrome for that one?
Also, check these two easy‑to‑miss things:
Content blockers / extensions
Ad blockers and “privacy” extensions sometimes nuke the scripts that set cookies.
Turn them off for a single problem site and test before you start tearing up your settings.
Website-specific settings (as mentioned by @viajeroceleste)
If one site is broken and others are fine, the bug is almost always in “Settings for This Website” or an extension, not your global cookie toggle.
3. Chrome: treat it as your “compatibility mode” browser
If Safari still gives you drama:
- Use Chrome for the picky sites like banking, old corporate portals, or strange third‑party login systems.
- In Chrome:
- “Block third‑party cookies” is a solid default.
- Then add exceptions only for sites that actually misbehave.
- I’d avoid “Allow all third‑party cookies” as your everyday setting. It fixes stuff, but you basically invite every tracker in the universe to watch you shop for socks.
4. Quick sanity checklist when sites don’t remember you
If you’re still getting randomly logged out or carts disappearing, run through this:
- Are you using Private Browsing / Incognito all the time?
- If yes, stop using that for anything you want remembered.
- Do you clean history/cookies on browser quit?
- Some cleaners, antivirus, or “privacy” apps auto-wipe cookies.
- Disable that or exclude your main browser.
- Mac system time & date correct?
- Sounds dumb, but if your clock is wildly off, cookie expiration can misbehave.
- Using multiple browsers for the same site?
- Your login cookie in Safari will not magically appear in Chrome. Pick one browser per site for stuff like email, banking, etc.
- Using VPNs or “secure” browser profiles?
- Some corporate VPNs and security tools inject extra rules that break session cookies.
5. A simple, safe setup that won’t make your Mac a tracking disaster
Safari as daily driver:
Allow cookies, keep “Block all cookies” off.
Keep “Prevent cross‑site tracking” on unless a specific important site refuses to behave.
Use content blockers, but whitelist problem sites.
Chrome as backup:
“Block third‑party cookies.”
Whitelist only the sites where something actually fails.
That combo keeps your logins and carts working without turning your Mac into a surveillance theme park. If a particular site still acts like it has amnesia, it’s almost always a site‑specific or extension issue, not you “breaking” macOS.
One angle that often gets missed in these “how to enable cookies on Mac” threads is what happens outside Safari and Chrome.
@viajeroceleste covered the browser switches nicely, and the follow‑up about first‑party vs third‑party cookies is solid. I slightly disagree with the idea that you should always treat Chrome as your “compatibility browser” though. For a lot of people, Safari is actually the more fragile one because of extensions and system‑level privacy tools, so it is worth checking the Mac itself before you assume the browser is at fault.
Here’s what I’d focus on that is different from what’s already been said:
Check for “cleaner” apps on macOS
- Tools that sound nice like “Mac cleaner,” “privacy booster,” or aggressive antivirus often wipe browser data on a schedule.
- If those are deleting cookies every time you log out or every night, your settings in Safari or Chrome will never stick.
- Fix: open that app and either turn off automatic cleaning or exclude Safari and Chrome’s data folders.
Look at user profiles instead of just browser profiles
- If you jump between multiple macOS accounts, each account has its own browser cookies.
- Log into your main Mac account for sites you want remembered and stay consistent. Switching accounts will feel like “cookies got cleared” even though they did not.
System‑wide DNS / security tools
- Some DNS filters or network security apps block the domains that serve login scripts or cookie notices.
- That can make it look like cookies are disabled when, in reality, the page that sets them never fully loads.
- Quick test: Temporarily disable any “safe browsing / parental control / DNS filter” app and see if carts and logins start sticking.
Keychain vs cookies confusion
- Staying logged in is cookie based.
- Remembering usernames/passwords is Keychain / Chrome Password Manager.
- People sometimes think “cookies are broken” when what is really happening is that auto‑fill is turned off or disabled for a site.
Treat “How To Enable Cookies On Mac” as a workflow, not just a toggle
- Pick one main browser (say Safari) for important sites.
- Use the second browser (Chrome) for testing whether the problem is site‑specific, account‑specific, or extension related.
- If a site fails in both with default settings and no extensions, the site is almost always the problem.
You mentioned worrying about breaking your Mac. Short version: cookie settings are safe territory. The bigger risk is over‑installing “protection” tools that silently nuke cookies behind your back. So if something still feels off after applying what @viajeroceleste and others suggested, I’d suspect a cleaner, VPN, or security app long before I’d blame Safari or Chrome.
