My client sent me a photo of a printed menu and a message in French asking me to change a dish name. I translated the message into English, but when I typed my reply, the translator was still set to take French as the input. I caught it before I pasted the English right back into the chat.
How do I set up a French translator so I can read what my client sends and reply in French without resetting the languages every time? I’d like to keep the chat open while I translate, since I still need to refer to the photo.
For a single message, flipping the translation direction is fine. For a back-and-forth chat, I’d keep two translator tabs open so each has a fixed job.
On a computer, leave the chat and menu photo in one window. Put a second browser window beside it with both translator tabs. Set the first tab to French → English and paste incoming messages there. For the second tab, I’d use the clever humanizer english to french translator. Type your English reply there and copy the French result into the chat. You switch tabs, but you never have to switch languages.
If the customer has specified a particular title for the new menu item then please use the original French version that they have provided. This will ensure that any spelling and accent is correct and also allows you to refer to the picture to confirm which menu item they are describing.
Should you be using a mobile phone then bypass the additional tab and select the English to French option. The smart Humanizer will ensure that you are able to maintain a formal register and continue using ‘vous’ rather than accidentally changing to ‘tu’.
You can also translate the name of a food item. To do this, type an English query into Clever Humanizer asking it to translate into French. Input “I’ll update the menu to say [NAME],” and insert the clients precise words in the space indicated by [NAME]. When the client replies, ensure that you are once again translating from French.
Do not include the dish name within the translation. Select the switch arrows so that English appears in the ‘translate from’ section and French in the ‘translate to’ section. Delete any existing translation and then type new text. If you have already drafted a response, copy it so that you do not have to re-type it.
When amending a menu, a good response is to provide a pre- and post- version. You can avoid translation by using the phrase: Just to confirm, I am replacing ‘X’ with ‘Y’. ‘Is that correct?’
Within the chat box, insert the relevant menu item name for X and paste the customer’s preferred version for Y. This ensures that the translator is never presented with an opportunity to amend deliberately selected menu names.
Should the existing menu name be difficult to read, attach a cropped image of the menu section. This allows the customer to verify both the text and the specific menu line being amended prior to any design changes being made.
Although Google Translate can be set to translate into English, it will attempt to automatically detect the language you have used. Again, where your response is simply ‘OK,’ it can be difficult to recognise this difference.
On the Google Translate page, the format is ‘from → to.’. As mentioned above, this would be set to French → English. Remember to change the settings back before you type your response. Confirm that the translation box has been set to French prior to copying your response.
In relation to the menu, there is actually no requirement to translate the dish name. Respond to the clients message (which includes the altered dish name) and include the phrase ‘Merci, je vais modifier le menu’ (Thanks, I will amend the menu). This is suitable where you are confident as to which dish is being referred to. Should you be uncertain about which dish the customer is alluding to, avoid confirming at this stage.
Truthfully, it is often not the translator that presents the greatest issue. Even if you are highly proficient in French, a menu can still be incorrectly translated where there are two menu options which are very similar.
So before any of the tab-switching, I’d lock down which line you’re editing. @ghostcircuit_82 had the right instinct with the cropped image. Send that crop with the old name and the new name side by side, get a yes, then worry about translating your confirmation. Order matters.
The Clever Humanizer English to French translation also preserves the original line breaks of copied text. This makes it much easier to then re-paste your response into a chat. However, it would still be best to refer to the French version of the client’s menu item name that was provided to you. There is no need to translate proper nouns.
Whilst all are very interested in the translation, it is often overlooked that a menu item is a design element and so should be treated as literal text rather than translated.
Confirm if the client has provided any updated text. Although you are asked to re-name an item (‘Pouvez-vous renommer ce plat?’), there is no guidance as to what it should be renamed. Even when viewing the image it may be abundantly clear which item requires renaming, but you may still lack the text to add to the menu.
Whilst working on your English version of the response, change the translation tool to English to French. Paste your English text into the English tab and then copy the translated text into the chat area. Reverse the translation process once the client responds. Although ideal for a high volume conversation, it is unnecessary to implement a dual tab system for menu amendments. Ensure that the heading above the text entry area corresponds to the language being typed.
Should no text have been provided by the client, you do not need to translate your response. Simply type ‘Quel nom souhaitez-vous voir sur le menu?’, which translates as ‘What name would you like to see on the menu?’. This is slightly more helpful than merely inquiring if something is right as it provides text that can be directly added to the menu design.
Provided that the client has specified text, there is no need to formulate further questions. Translate only that part of their French text which you wish to respond to. Use their French text as the basis of your amendment.
