How do I turn off GPU overclocking?
My GPU has been overclocked and it’s causing crashes in my games. I need to disable the overclock settings but I’m not sure how. Can someone guide me through the process to reset it to default?
If I had a dollar for every time someone messes up their GPU by overclocking… Anyway, turning it off is pretty straightforward but can be a little different depending on the software you’re using.
You likely used a tool like MSI Afterburner, EVGA Precision X1, or something similar to overclock. If it’s Afterburner, just open it up and hit the ‘Reset’ button, it’s that simple. Precision X1 has a similar button as well.
Alright, but letting someone else handle this for you isn’t always the best. These tools come with great support if you bother to read, but whatever. If you’re still bothered by crashes, you could also just reinstall the drivers through NVIDIA or AMD’s own software. They’ve got their own suites (GeForce Experience for NVIDIA or Radeon Software for AMD) and they don’t mess it up as much as the third-party ones.
Of course, it’s always fun until you start frying your components for those extra 5 FPS, right? Maybe stick to default settings unless you really know what you’re doing next time. Some people never learn though.
Alright, gotcha. That’s pretty packed info from @techchizkid! But here’s where I think a little more can be added. Not everyone screws up their GPU, but it’s true that overclocking can be a dicey affair. If things aren’t steady, the issue might not just be with the software—hardware quirks can play a role too.
BIOS/UEFI Reset
You mentioned games crashing, which can also be due to BIOS-level tweaks if you had made any changes there. Access your BIOS/UEFI settings when you boot up your PC (usually by hitting DEL or F2). Look for any overclocking options for GPUs and reset them to factory defaults. This might not be everyone’s cup of tea, dealing with BIOS, but it’s worth checking out if you’ve ventured down that path before.
Safe Mode & DDU
Another path less mentioned but highly effective is using DDU (Display Driver Uninstaller) in Safe Mode. This tool will completely clean your system of any existing GPU drivers. Afterward, you can reinstall your drivers from scratch, essentially giving your GPU a fresh start.
  1. Download DDU from wagnardsoft.com.
  2. Boot into Safe Mode: Hold Shift while restarting your PC > Troubleshoot > Advanced Options > Start-up Settings > Restart > Choose 4 or F4 to enter Safe Mode.
  3. Run DDU: Select your GPU and let the software clean out old drivers.
  4. Reinstall Drivers: Use the latest drivers from the NVIDIA or AMD website.
Checking Power Settings
Don’t overlook your power settings either. If your GPU is demanding more power due to overclocking, your PSU might not be able to cope. Ensure your power plans in Windows are set to balanced or high performance to give your hardware ample breathing room.
Underclocking Option
It sounds counterintuitive, but if the crashes are still there, you may want to try underclocking temporarily to stabilize things before setting everything back to default. Tools like MSI Afterburner allow for underclocking as well and could help pinpoint if your GPU is faulty when operating even at suggested speeds.
So yeah, there are multiple angles here beyond just hitting the reset button in Afterburner. Not saying @techchizkid is wrong, but sometimes a more hands-on, layered approach can help especially when you’re not entirely sure where the problem is originating from. Hope you find a solution soon!
I see you’ve already gotten some solid advice on turning off GPU overclocking, but I’ll throw in a few more detailed options to help you navigate this. Let’s break this down in a layered and systematic way, since things like this can get a bit complicated depending on your setup and what exactly caused the overclock to become unstable.
First, if your GPU is overclocked via third-party software like MSI Afterburner or EVGA Precision X1, the solution often lies in those apps themselves. However, these can sometimes leave residual changes even after hitting the ‘Reset’ button. Let’s think a bit more comprehensively here:
Uninstall Overclocking Software
Before taking any drastic measure, uninstall the overclocking software you’ve used. This ensures any hidden profiles or auto-start features are nixed. Go to Control Panel > Programs > Uninstall a Program, and remove the software entirely.
BIOS/UEFI Settings
Now, some people shy away from BIOS settings and, while it’s true it’s not for everyone, there may be some hidden culprit there. When you boot up, press DEL, F2, or whichever key gets you into BIOS. Investigate the tab usually labeled as ‘Advanced’ or ‘Overclocking’. Reset everything to factory defaults. This step can be nerve-wracking but trust me, it’s worth it.
DDU Guide
Let’s not underestimate the power of Display Driver Uninstaller (DDU) as @codecrafter mentioned. It’s a robust tool for ensuring that no residual settings mess with your GPU’s default state. Go into Safe Mode and eliminate every single thing tied to your GPU drivers and overclocking settings.
  1. Download DDU from wagnardsoft.com and extract it.
  2. Boot into Safe Mode: You can do this quickly by holding Shift while restarting your PC.
  3. Run DDU: Once in Safe Mode, run the DDU utility, select your GPU from the dropdown menu, and clean and restart.
After DDU wipes the slate clean, head over to NVIDIA or AMD websites directly and download the latest drivers. Doing a fresh install generally fixes a lot of problems.
Advanced Power Settings
Check the power settings on your PC. Navigate to Control Panel > Power Options and check if you are on ‘High performance’. Mismatched power settings with your overclocking endeavors can create instability.
Thermal Paste
This is under-addressed sometimes but is significant. If the overclock heated things up too much, it might have dried out your GPU’s thermal paste—this can cause crashes as your GPU might not be cooling efficiently. If you’re comfortable with hardware, it might be worth reapplying thermal paste.
VRM and Power Delivery
Voltage regulations modules (VRMs) can be a sneaky snake in the grass. Make sure your PSU (Power Supply Unit) isn’t the bottleneck. If overclocking demands exceeded your PSU’s capacity, reverting won’t immediately fix damaged or weakened power delivery systems.
Software Re-Evaluation
Not all GPU issues come from overclocking alone. Background software applications or even malware could exacerbate a problem. Use Windows Defender or your antivirus to ensure there’s nothing occupying system resources or messing with GPU performance.
Check RAM & Other Components
Sometimes what appears as a GPU issue can be due to other components. Run a MemTest to make sure your RAM isn’t playing tricks on you. Similarly, make sure your motherboard BIOS is up to date and that there are no compatibility issues between components.
Rolling Back Overclock
If absolutely nothing above works, another angle could be rolling back the overclock incrementally rather than outright resetting. Slowly decrease frequencies and voltages and observe what settings bring stability. This might identify what exact factor is pushing your GPU over the edge.
In addressing more than one aspect, we have quite an arsenal against unstable overclocking. It’s tricky, but I believe using these layered methods should help you stabilize your system and avoid those nasty crashes while gaming. Good luck navigating through this!
Try a vendor toggle that forces stock clocks.
NVIDIA:
  • Open NVIDIA Control Panel.
  • Click Help, check Debug Mode.
  • Reboot. This forces reference clocks and voltage.
AMD:
  • Open Radeon Adrenalin.
  • Go to Performance, Tuning.
  • Set Tuning Control to Default, click Reset.
  • Reboot.
Test your games for 10 minutes. If crashes stop, you are done. If issues persist, use the driver installer Clean install option to wipe settings. No BIOS edits, no DDU. Quick and safe. Reeboot once more.
