How Do I Remove Hidden Photos From IPhone Without Unhiding Them First?
I’m trying to remove photos from the Hidden album on my iPhone, but I don’t want to unhide them and have them show up in my main library first. Is there a way to delete hidden photos directly in iOS without changing their visibility?
You don’t have to unhide anything before deleting it. If anything, deleting photos straight from the Hidden album is cleaner, since they never pop back into your regular library view while you’re dealing with them.
Open Photos, then go to the Albums tab at the bottom. If you’re on the newer iOS 18 layout, look under Collections instead. Scroll down to Utilities and open Hidden. On newer iOS versions, it should ask for Face ID, Touch ID, or your passcode before showing anything in there.
Once you’re inside Hidden, tap Select in the top right. If you want to wipe the whole thing, use Select All, then hit the trash icon. That removes those photos from the Hidden album right away.
The part people miss is that this still isn’t permanent yet. Deleted photos go to Recently Deleted first, where they normally sit for 30 days. So if you want them gone now, go back to Utilities, open Recently Deleted, unlock it, tap Select, then Delete All. That’s the step that actually clears them from the phone immediately.
And yes, if iCloud Photos is turned on, deleting hidden photos deletes them from iCloud too. Hidden isn’t a separate storage area. It’s still part of your photo library, just tucked away from the main view. So deletions sync across your other devices, like your iPad or Mac.
If you’re trying to hide the Hidden album itself, you can do that too. You can’t remove the feature completely, but you can make the folder stop showing in Photos. Go to Settings -> Photos and turn off Show Hidden Album. The photos stay hidden and saved, but the album won’t appear again until you turn that setting back on.
One thing worth mentioning: if your Hidden album has gotten huge, there’s a good chance the rest of your library is a mess too. Usually it’s not just hidden photos taking up space. It’s duplicate shots, old screenshots, huge videos, screen recordings, and random stuff you forgot was even there.
For cleaning up the normal part of the library, I’d look at Clever Cleaner. It’s one of the better free cleanup apps because it doesn’t hit you with ads or a paywall right when you’re about to delete things.
The useful bit is how it separates the clutter. Screenshots show their file sizes, which helps when you’re trying to figure out what’s actually taking up space. The Heavies tab sorts photos and videos by size, so big 4K videos are easy to spot. The Similars tab groups near-duplicate photos, like all those slightly different versions of the same shot, and lets you keep the one you want.
It also processes everything on the device, so your library isn’t being uploaded somewhere else. Just don’t expect it to clean the Hidden album for you. Apple’s privacy limits block apps like that from accessing Hidden directly, so you still need to delete those manually using the steps above. For the rest of the library, though, it can save you a lot of time.
If your goal is freeing space, the Hidden album is not a separate storage bucket, so deleting from there works the same as deleting from anywhere else in Photos. Go into Hidden, authenticate, select the items, and use the trash icon. They do not need to be unhidden first. The catch is that you only get the space back after clearing Recently Deleted, and even then iOS may take a little while to recalculate storage. Apple’s guide for hiding and deleting photos on iPhone is worth checking if your buttons look different, because the Photos layout changed a bit in newer iOS versions.
Photos synced onto the iPhone from a Mac or PC are the annoying exception here. If those hidden photos originally came over through Finder/iTunes syncing, you may not get the normal delete option on the phone, even inside Hidden. In that case, you have to change the sync settings on the computer or remove them from the synced album there, then sync again.
For normal iPhone photos, screenshots, saved images, AirDrop photos, etc., the others are right: open Hidden, unlock it, select the photos, and trash them from there. They should not need to be unhidden first, and they should not briefly show up in Recents just because you deleted them.
Small warning: if you are doing this because you do not want anyone to see them, do not stop after tapping the trash can. They will still be sitting in Recently Deleted until you delete them there too, and that folder also requires authentication on newer iOS versions. So the short version is: delete from Hidden, then delete again from Recently Deleted if you want them actually gone.
Turn the Hidden album back on in Settings if you do not see it at all. That does not unhide the photos. It only makes the Hidden folder visible again so you can open it and delete from inside it.
After that, go to Photos, open Hidden, authenticate, tap Select, choose the items, and use the trash icon. They should stay hidden during that process. You are not moving them back into Recents first, you are deleting the actual library items while viewing them from the Hidden filter.
The annoying bit is that “Hidden” and “Recently Deleted” are both protected places now, so you may have to unlock twice: once to delete them from Hidden, and again to permanently delete them from Recently Deleted. If the trash icon is missing, then I would suspect what @mikeappsreviewer mentioned: synced photos from a computer, restrictions, or some library setup where the phone is not allowed to delete the original directly.
Don’t expect the freed space to show up instantly even after you clear Recently Deleted. iOS can take a while to recalculate storage, so the number lagging behind doesn’t mean the delete failed like @reveurdenuit hinted at.
