How do I permanently delete stickers from my iPhone messages?
I accidentally added a bunch of stickers to my iPhone Messages and now they keep popping up in my sticker drawer. I can’t figure out how to fully remove or hide them, not just disable them temporarily. Can someone walk me through the steps to delete these stickers from my iPhone for good?
This trips a lot of people up because Messages treats stickers like “apps” in the Messages App Drawer, not like simple images.
Here is how you hide or remove them as much as iOS allows:
  1. Hide sticker packs from the Messages app drawer
    1. Open Messages.
    2. Open any conversation.
    3. Tap the plus button near the text field.
    4. Tap “More” or “More Apps” if you see it.
    5. Tap “Edit” in the top right.
    6. Turn off (toggle off) the sticker apps you do not want to see.
    7. You can also tap “Edit” again and remove them from “Favorites” so they do not stay pinned at the top.
This hides them from your drawer so they stop popping up every time.
  1. Delete third‑party sticker apps from your iPhone
    If the stickers came from apps you installed from the App Store:
    1. Go to the Home Screen.
    2. Find the sticker app icon.
    3. Tap and hold it.
    4. Tap “Remove App”, then “Delete App”.
Once you delete the app, its stickers disappear from Messages after a moment.
If the sticker pack does not show up as a separate app, open the App Store, go to your profile icon, then “Purchased”, look for the sticker app, and remove it from there if it still exists as an app.
  1. Built‑in Apple sticker packs, Memojis, emojis
    Those do not fully delete. Apple keeps them in the system. You can only push them out of the way:
    1. In the Messages “More” or “More Apps” list, unpin them from Favorites.
    2. Turn off any toggles that allow it.
They still exist, but they stop cluttering the main part of the drawer.
  1. Sticker packs from specific apps like Telegram, WhatsApp, etc.
    Those stay inside those apps. They do not have a system‑wide delete in iOS Messages. You manage them only in the app where you added them.
So, short version.
If it is a third‑party sticker app, delete the app.
If it is a Messages app, toggle it off in the Messages “More / Edit” screen.
If it is built‑in, you hide and unpin it, you do not fully remove it.
Apple loves keeping “fun” stuff in front of your face. You spend ten minutes cleaning it all up, then the next iOS update adds another random sticker thing back into the drawer.
You’ve basically discovered Apple’s little secret: “delete” for stickers often just means “go sit in the corner and pretend you’re gone.”
@cacadordeestrelas covered the normal app-drawer / delete-app approach pretty well, so I’ll skip rehashing all those taps. A few extra angles you might want to try:
1. Figure out what kind of sticker it is first
This actually matters:
  • If you can see it as an app icon on the Home Screen or App Library → it’s a full app with a sticker extension.
  • If you only ever see it inside Messages, in that new iOS 17 sticker sheet (where Live Stickers, emoji, etc. live) → it’s probably a “Saved” sticker or Live Sticker.
  • If it’s some ancient iMessage sticker pack from the old App Store-in-Messages days and doesn’t show on the Home Screen → it’s buried under Messages apps.
The reason you feel like you can’t “fully remove” some is because some categories literally cannot be wiped, only hidden.
2. For Live Stickers / Saved stickers (iOS 17+): actually delete the sticker itself
This is the bit most people miss, and it sounds closer to what you want than just hiding apps:
  1. Open Messages.
  2. In a conversation, tap the plus button next to the text box.
  3. Tap Stickers (the sticker icon).
  4. Go to Recents or the specific sticker pack section where you keep seeing those custom stickers.
  5. Long-press on the offending sticker until a menu pops up.
  6. Look for something like Delete, Remove, or a little info / “i” button → from there delete the custom sticker.
If the stickers came from you long-pressing photos and creating Live Stickers, you can nuke them from the Photos app too:
  1. Open Photos.
  2. Find the original photo you used to make the sticker.
  3. Long-press the subject again.
  4. Tap Sticker or Add Sticker options, then manage/remove from the sticker set from there, depending on your iOS version.
This is closer to “permanent” than just turning off a Messages app, because you’re deleting the actual sticker asset.
3. For old iMessage sticker packs that don’t show as apps
Sometimes you have sticker packs that:
  • Don’t appear on the Home Screen
  • Don’t show clearly in the normal App Store as apps
You can dig a bit deeper:
  1. Open App Store.
  2. Tap your profile picture top right.
  3. Go to Purchased → My Purchases.
  4. Scroll through and look for any “Sticker Pack” or “for iMessage” type entries.
  5. If they’re still installed, you might see an Open button or they might show as part of a container app you forgot you installed.
  6. Open that container app and check its settings. Some let you disable or even remove their Messages extension from inside the app.
If you can actually delete the container app, that’s the only real way to get “true” removal for those.
4. Sync issues: make sure iCloud isn’t re-adding stuff
This is a fun one: you hide / delete an app on one device, but it keeps reappearing on another and syncing back.
If you use multiple Apple devices:
  1. On each device, open Messages and repeat the “More / Edit / toggle off” routine that @cacadordeestrelas mentioned.
  2. Make sure the associated app is removed on all devices logged into your Apple ID.
  3. In Settings → App Store, check Automatic Downloads. If Apps is on, it can reinstall apps (and therefore their stickers) from other devices.
Not exactly “permanent delete,” but it stops the zombie-respawn effect.
5. Reality check: what you cannot truly delete
You can’t permanently erase:
  • Emoji
  • Standard Apple stickers / Memojis / Live emoji stuff
  • Some system sticker collections tied to the OS
You can only:
  • Unpin them
  • Push them out of the main view
  • Turn off what limited toggles Apple exposes
So if some of what’s annoying you is Apple’s own cute garbage, you’re stuck with “get it out of my face” rather than “burn it with fire.”
TL;DR with the “more permanent” angle
  • Third‑party sticker apps → uninstall the actual app and check all your devices.
  • Custom / Live Stickers → long-press inside the sticker picker and delete the sticker itself.
  • Old iMessage-only packs → hunt them down in App Store → Purchased and kill the container app if it exists.
  • Apple’s built-ins → you cannot permanently delete, only hide/unpin, no matter what any setting pretends to say.
So if by “permanently” you mean “never see them again, ever, under any menu,” Apple basically said “nope” for their own stuff. For third‑party and custom stickers, though, you can actually remove the assets, not just toggle visibility.
Try the fastest fix: hide stickers from your keyboard entirely.
Open Settings, tap General, then Keyboard. Scroll down and switch off Stickers.
This removes Memoji and sticker suggestions from the emoji keyboard, so they stop poping up while you type. Your saved stickers stay stored, but they remain out of sight. If the drawer still appears, close Messages and restart your iPhone. This takes under a minute and avoids deleting each sticker one by one.
Deleting stickers one at a time from the Recents row is a trap, because that row rebuilds itself the moment you use a sticker again. So you can sit there long-pressing and hitting Remove, feel like you cleaned it up, then send one sticker later and half of them are back. If the clutter you’re seeing is in Recents specifically, no amount of deleting fixes it. It’s a usage history, not a folder.
The actual custom stickers live in your sticker pack, and @mike34 is right that long-pressing and deleting those removes the real asset. Worth knowing the split though: Recents = temporary, your pack = permanent. Delete from the pack and it’s gone for good. The Live Stickers you made from photos are the ones that genuinely count as saved, and those sync through iCloud, so if you only wipe them on one phone they’ll drift back from another device. That part matches what was said about zombie respawns, and it’s real.
On @retro_hawk225’s keyboard toggle, that one’s fine as a quick mute, but be aware it also kills the sticker suggestions from the emoji keyboard entirely. If you ever use Memoji or emoji stickers on purpose, you’re turning those off too. It’s a blunt switch, not a filter. Good if you never want any of it, annoying if you only wanted the junk gone.
My honest take: sort out what you’re actually dealing with before you touch anything. If it’s a handful of Live Stickers you made from photos, open the sticker drawer, delete them from the pack, and check your other devices signed into the same Apple ID. That’s the only thing that sticks. Everything else in this thread is a hide, not a delete, and Apple isn’t going to give you a clean wipe for their built-in stuff no matter how many menus you dig through.
