How do I identify my CPU cooler?
I’m trying to find out what CPU cooler I have in my system. I bought my PC second-hand and don’t have any of the original parts’ documentation. I’m planning to upgrade my CPU and need to ensure the cooler is compatible. Any advice on steps to identify the cooler would be greatly appreciated.
First thing you can try, open up your case and take a good look at the cooler itself. Check for any branding or model numbers on the cooler. Most manufacturers like Cooler Master, Corsair, or Noctua usually slap their logo or name somewhere visible. You might need a flashlight and some patience, especially if it’s in a tight spot.
If the branding doesn’t give you enought info, there are a couple more things you can do. Measure the dimensions of the cooler. This might help you match it to online listings or reviews. Note the height, width, and depth. Compare these dimensions to listings on the manufacturer’s website or retailers like Newegg or Amazon. Sometimes a visual and dimensional match can help narrow it down.
Another way you could identify it is by checking your BIOS or using monitoring software like HWMonitor or Speccy. Some of these tools will show you fan speeds and sometimes the fan model numbers which might help you backtrack to the cooler model.
For compatibility, remember that the cooler must match the CPU socket type. If you’re planning to upgrade your CPU to something that’s still using the same socket (e.g., from an older Intel i5 to a newer i7 on LGA 1151), your cooler will probably fit. But be cautious—cooling performance might not be adequate if you’re going from a less power-hungry CPU to something that runs hotter.
If all else fails and you still can’t ID the cooler, but you know the socket type of your new CPU, you might be better off just purchasing a reputable cooler that you know will be compatible with your new CPU and socket. This also ensures you get fresh thermal paste and a guaranteed fit and performance.
I had a similar situation with a second-hand build. The cooler was an unknown entity. It turned out to be an old Cooler Master Hyper 212 just by comparing it to pics and measurements online. A good fallback is to replace with something like a Hyper 212 EVO anyway, especially since they’re very reasonably priced and compatible with a lot of different setups.
Last but not least, read some reviews and do a bit of research before buying a new cooler if it comes to that. You want to be sure it’s going to handle the thermal output of your new CPU!
I’ve been in a similar spot myself before, and while @codecrafter’s advice is solid, there are a couple more angles you could explore when identifying your CPU cooler.
First, I’d recommend taking a closer look at the fan itself. Fans often carry model numbers and brands which can be easier to spot compared to the heatsink. It’s a bit of a detective work, sure, but fans are simpler to identify and cross-reference. Say you spot a model number on the fan—punch that into Google, and more often than not, you’ll get a hit that ties it back to a particular cooler model.
Next thing, the mounting mechanism can also be a giveaway. Different brands have distinctive mounting styles. For example, Noctua uses specific spring-loaded screws on their coolers which are quite recognizable once you’ve seen them. Compare what you have with images in product listings and reviews. This could narrow down the list of potential coolers significantly.
Another useful tool in your arsenal is the community—the collective tech forums, to be precise. Post a clear photograph of your cooler on a tech forum like Tom’s Hardware or Reddit’s r/buildapc. The community is often quick and quite good at ID’ing even older or obscure models. Sometimes it is easier for someone who has been around the block a few times to recognize a particular design or feature.
And slightly disagreeing with the earlier comment, while measuring the cooler’s dimensions is indeed helpful, it can be quite tedious and sometimes inconclusive due to minor design variations among models. Instead, focus on unique structural aspects—like the shape of the heat pipes, the positioning of the fan brackets, or any proprietary design elements.
For your BIOS or monitoring software, note that not every tool will give you model numbers detailed enough to be of help. However, checking your temps and fan speeds can indirectly help. For instance, if your cooler keeps a high-end CPU cool with ease, you’re likely looking at a more robust or efficient model. Conversely, if it struggles, it may be worth considering an upgrade regardless of its identity.
Regarding cooler performance: The transition between CPUs of the same generation often means similar thermal outputs, but extending this to totally different architectures or TDPs can mislead. Even if the socket type matches, make sure to look at TDP (Thermal Design Power) requirements. If you are moving from a CPU with a 65W TDP to one 100W or higher, your current cooler might not cut it even if technically compatible.
If you opt for a new cooler, don’t just focus on well-known models like the Hyper 212 EVO (although it’s a great choice). Newer, compact air coolers and even entry-level AIOs offer similar performance at competitive prices. For instance, Arctic Freezer 34 eSports or some of the Be Quiet! models deliver excellent performance and are relatively straightforward to install.
In conclusion, persistence and leveraging the tech community can often surprise you with quick and accurate help. But when in doubt, prioritizing a new cooler that is proven to be compatible and efficient, like not just Hyper 212 EVO but also considering other brands and models, is a wise course of action.
Alright, I get what you’re saying, but let’s cut through the fluff here. Identifying your CPU cooler by eyeballing it or measuring it sounds like a lot of unnecessary work. You bought a second-hand PC—who knows what Frankenbuild you’ve inherited?
You’re probably better off just buying a new cooler that’s guaranteed to fit your new CPU and its socket type. Besides, even if you identify your existing cooler, who’s to say it’s still performing at optimal levels? Thermal paste ages, fans wear out, and heatsinks can get clogged with dust over time.
Seriously, don’t waste hours playing detective with flashlights and tape measures. Just grab a new cooler like the Cooler Master Hyper 212 EVO or something similar in its price range. Saves you the headache and guarantees compatibility.
Relying on the BIOS or software like HWMonitor to identify cooler parts is also kinda iffy—some tools won’t give you detailed enough info to be useful. Community forums? Maybe, but you’re putting a lot of faith in strangers on the internet who might misidentify the cooler, especially if it’s an older or obscure model.
And sure, there are other good models out there. Arctic Freezer 34 eSports is pretty solid too, and so are Be Quiet! coolers. Just get something new and reliable. Skip the hassle.
Skip the guesswork. Use reverse image search.
  • Power down, open the side panel. Clear dust.
  • Take clear photos of the cooler top, side, fan hub lable, and base.
  • Run the photos through Google Lens on your phone.
  • Match hits by heatpipe count, top plate shape, and fan model code.
This often finds the model fast. Example, Hyper 212 shows four direct contact pipes and a square top cap. No tape measure needed. If results look mixed, photo the backplate too. Brands use distinct brackets. Then check teh maker page for socket support and TDP limits.
