How do I find out what CPU cooler I have?
I need to upgrade my CPU cooler but I’m not sure what model I currently have. I don’t remember the details from when I built my PC and I can’t find the box. What’s the easiest way to check this?
You’re serious, right? You built your PC but somehow managed to forget what CPU cooler you installed? I’d call it a rookie mistake. Anyway, if you can’t find the box or remember the details, your best bet is to just open up your case and look. The model number or brand is usually stamped somewhere on the cooler itself. It’s not rocket science.
Also, while you’re in there, you might wanna consider upgrading if it’s some no-name brand. Go for something reputable like a Noctua or a Cooler Master. Those companies at least know how to design a proper cooler. ‘Speccy’ isn’t gonna tell you what cooler you have, but if you use something like HWMonitor, you can at least check your current temperatures to see if it’s even doing its job.
There, now you have some work to do. Either open up your case and take a look, or just guess and hope for the best.
Mate, I get it, not everyone’s a tech wizard with an eidetic memory recalling the model number of every single component in their rig. Don’t sweat it. Sure, opening up the case and peeking in is one way to go, but let’s not jump the gun right away.
First off, yes, @techchizkid, hardware monitoring tools like HWMonitor can tell you a lot about your current setup, but it won’t tell you the brand and model of your cooler. Still, it’s good to check your temps as a baseline before you start playing operation on your machine.
Okay, here’s a different angle. Before you grab a screwdriver, do you remember if the CPU cooler came with your CPU or did you buy it separately? If it’s the stock cooler from AMD or Intel, well, mystery solved. If you bought it when you built the PC, maybe check your purchase history—assuming you bought it online. Amazon, Newegg, or wherever you got your parts might store your order history.
Another neat trick could be to dig through your original build list if you saved it on a PC building site; if you used PCPartPicker, they keep a log of your builds if you have an account. You’d be surprised how often people overlook their digital footprints!
Now, a word of caution before you decide to just yank it out and replace it. If your current cooler is from a reputable brand—even one you don’t immediately recognize—you might simply need better thermal paste or dust cleanup rather than a whole replacement. Not all no-brand coolers are garbage, but yes, aiming for brands like Noctua or Cooler Master isn’t bad advice.
So, make it a step-by-step process:
  1. Try and recall how/where you bought it - online history might help.
  2. Check out your build plan if you kept one.
  3. If those fail, yeah, then grab the flashlight, open the case, and look for model info.
Overall, let’s upgrade smart, not just for the sake of upgrading. At the end of the day, your goal’s to keep that CPU chill, without burning through your wallet more than necessary.
Okay, while @codecrafter and @techchizkid both have solid points, there’s some more ground we can cover. First, don’t be too hard on yourself for not remembering the CPU cooler you installed. It happens.
Aside from opening up your case and looking for branding or model info stamped on the cooler, there’s another angle we can explore: tools like HWINFO. Unlike HWMonitor, which is more temperature-focused, HWINFO sometimes provides detailed readouts of your system’s hardware, including not just temps but also the actual components in more detail. It might not explicitly name the model of the cooler, but it can give more nuanced information about your setup.
That said, opening the case is probably inevitable if you’re planning an upgrade. Before diving in, though, let’s backtrack a bit more systematically.
  1. Check Online Retailer Accounts: If you bought your cooler from a site like Amazon or Newegg, your order history might have the exact model. Sometimes people overlook how thorough their digital trail can be. I’ve lost count of the number of times I’ve found old receipts showing exactly what I purchased.
  2. Dig Out Your Build Documentation: Assuming you used a site like PCPartPicker, they often keep logs of your build if you created an account. If you didn’t create an account, maybe you have a saved build list on your computer or even a piece of paper lying around from when you first built the rig.
  3. Number of Heatpipes & Design: Even if the branding isn’t clear, sometimes the design can give it away. Coolers often have distinct features like the number of heatpipes, fan blade design, or even the type of screws used. You can compare your cooler to images online to narrow it down.
If you’re going to open your case, which seems likely, here’s how you can proceed:
  • Power Down & Unplug: Common sense, but still. Unplug everything—power, peripherals, all of it.
  • Anti-Static Precautions: Use an anti-static wrist strap or at least touch metal (non-painted) parts of the case to discharge static electricity.
  • Inspect The Cooler: Look for any kind of labeling or model number. Brands like Cooler Master, Noctua, Corsair, etc., often have their logo or model number somewhere on the cooler. Sometimes it’s under the fan, so you might need to remove the fan to see it.
Now, let’s address upgrade choices:
  • Reputable Brands: If you’re going the upgrade route, yes, @codecrafter nailed it with brand recommendations. But depending on your system, even very specific coolers like the Noctua NH-D15 or the Cooler Master Hyper 212 EVO can make a huge difference. They’re popular for a reason.
  • Alternative Solutions: Before you spend money, check if reapplying thermal paste or clearing dust helps. Sometimes it’s not the cooler but poor thermal paste application or just loads of accumulated dust in the heatsink and fans causing the issues.
Disagreeing slightly with @techchizkid here: not all no-brand coolers are bad. Some perform surprisingly well; it’s just that they lack the branding and often the marketing.
Another Practical Approach:
If you’re still unsure after all this, measure the cooler. Height from the CPU base to the top of the cooler, width, fan size, etc. This could help you find the cooler online, as most reputable sites will have extensive specifications listed.
Lastly, not to belabor the point, but updating your build sheet on whatever platform you used (PCPartPicker, notebook, digital document) is a good habit. Save future you the hassle.
In summary, while opening your case seems unavoidable, make sure to exhaust all other avenues first. Ensuring you know what you have can save you a lot of headaches and possibly cash by avoiding unnecessary upgrades. Good luck!
Quick alternative, use visual ID with your phone. Power down, remove side panel, take a clear photo of the cooler, shroud, top cap, and the fan hub sticker. Open Google Lens or Bing Visual Search. Upload the photo. Tap Shopping or Images. Match shapes, heatpipe count, and logos. You often get the exact model in seconds. Example, a hub marked NF-F12 retuns Noctua matches. If blocked, pop the fan off and shoot the base and pipe layout. Save the result to your build sheet for next time.
