How do I enable my motherboard's HDMI port?
I recently installed a new GPU, but I want to use my motherboard’s HDMI port for a second display. When I plug my monitor into the motherboard HDMI, it doesn’t show anything. Do I need to change some settings in the BIOS or install specific drivers? I’m unsure what to do and would appreciate any help.
You really want to use your motherboard’s HDMI port after installing a new GPU? That’s like buying a Ferrari and driving it on a gravel road. Anyway, here’s the deal: Most motherboards disable the onboard video when you plug in a GPU. It’s supposed to be a feature, not a bug.
First, get ready for a BIOS adventure. Restart your PC and keep spamming the BIOS key (usually F2, DEL or ESC depending on your motherboard). In the BIOS, find the setting for integrated graphics. It’s probably under something like “Advanced” or “Chipset Configuration.” Look for “iGPU Multi-Monitor” or “Integrated Graphics” and enable it. But guess what? Your motherboard might not even have this option. Not all BIOS/UEFI setups support dual outputs like this.
Even if you do get it working, you’re gonna split your resources between the GPU and the integrated graphics. Meaning your performance will likely suffer. Why not just get a DisplayPort to HDMI adapter for your GPU? Pretty cheap and way less hassle.
Plus, some OSes treat the two different graphic sources differently. So, prepare for potential driver headaches and inconsistent display behavior if you manage to get past the BIOS hurdle.
You could’ve skipped all of this by just using your GPU’s multi-display capabilities. Most modern GPUs from NVIDEA and AMD support at least two, if not three or four displays. If you’re that keen on using multiple monitors, it’s the much better route to go.
@techchizkid offers some great points about the potential pitfalls of using the motherboard’s HDMI port after installing a new GPU. Tbh, I wouldn’t recommend it either unless you’ve got a compelling reason. But, if you’re set on this course, here’s a more nuanced view on the topic.
First off, while it’s true that many motherboards disable onboard graphics when a dedicated GPU is detected, newer mobo BIOS/UEFI versions are becoming more flexible. Assuming you’re dead set on using the motherboard’s HDMI port (for example, a specialized monitor setup or a specific need to separate GPU resources), here’s a detailed guide to try and achieve it. Unlike @techchizkid, I’m gonna dig a bit more into specific configurations and scenarios.
BIOS Settings: iGPU Multi-Monitor
1. Enter the BIOS:
  • Reboot your PC and press the BIOS setup key (usually F2, DEL or ESC). You might need to spam it a bit until you get in.
2. Find Integrated Graphics Settings:
  • Look for a section labeled “Advanced” or “Chipset Configuration.” This varies by manufacturer, so you might need to explore a bit. ASUS, Gigabyte, and MSI usually have it somewhere in the “Peripherals” or “North Bridge” settings.
3. Enable iGPU Multi-Monitor:
  • Locate an option like “iGPU Multi-Monitor” or “Integrated Graphics” and enable it. If you can’t find it, check for an option to enable the internal GPU. Not every motherboard has this option, as @techchizkid mentioned.
Windows Settings
Assuming you’ve enabled the integrated graphics from BIOS:
  • Right-click on the desktop and select “Display settings.”
  • Scroll down to “Multiple displays” and check if Windows detects the second monitor. Sometimes, you might need to manually detect the display for it to show up.
Potential Issues:
  • Drivers:
    While Windows will handle most cases automatically (Windows 10 is pretty good at this), you may need to install separate drivers for the integrated graphics. This adds another layer of complexity and potential driver conflicts.
  • Performance:
    Sharing resources between your GPU and iGPU might sound like a good idea, but it can hit your system performance. Integrated graphics are typically weaker than dedicated GPUs, and you’ll essentially be creating a bottleneck.
Alternative Solution: DisplayPort to HDMI Adapter
Before you roll your eyes, hear me out. DisplayPort to HDMI adapters are not only cheap but also versatile. You can connect multiple monitors to your GPU, which is designed to handle multiple outputs efficiently. It saves you the headache of BIOS and driver configurations.
Interoperability and OS Issues
Depending on your OS, you might face varying levels of success. Windows has fairly good support for dual graphic outputs, but the same can’t be said for some Linux distributions. And macOS? Forget it if you’re on a Hackintosh attempt.
Driver inconsistency: Using two different graphics sources might cause windows to treat them differently, leading to stuttery performance, or worse, crashes. Also, keep in mind that GPU drivers from NVIDIA and AMD sometimes behave weirdly when they detect conflicting graphic sources.
If you’re using a Windows setup: Remember to periodically check if both the integrated and the dedicated GPU drivers are up to date to avoid performance hitches. Sometimes, a BIOS update can also solve such issues.
Final Thoughts:
While enabling the motherboard’s HDMI port for a second display is technically feasible and @techchizkid makes a valid point about using the GPU’s outputs, the decision largely depends on your specific needs. Weighing the pros and cons, the cons like potential performance issues and the hassle of troubleshooting definitely overshadow the potential simple convenience.
If you’ve got the time and willingness to tinker, go for it. If you value your time and system performance, spend a few bucks on a DisplayPort to HDMI adapter. It’s ultimately a question of what you prioritize more: convenience or performance.
Certainly, most of the folks here are pointing out that using your GPU for multiple displays is usually the better route, and I second that, but let’s dive into a different angle for a moment.
Look into Your Use Case
What exactly is your usage case that demands the motherboard’s HDMI port specifically? If you’re trying to segregate tasks where the iGPU handles regular desktop work and the discrete GPU is dedicated to gaming or heavy workloads, it might make sense in some specific scenarios. However, be prepared for the potential hassle.
BIOS Tweaks
As already mentioned:
  • Restart your PC and enter the BIOS (usually F2, DEL or ESC)
  • Navigate to “Advanced” or “Chipset Configuration”
  • Enable something like “iGPU Multi-Monitor”
If you don’t see this option, your BIOS might not support it, and there’s not much you can do short of a BIOS update (if available) from the motherboard manufacturer’s site. But, watch out—BIOS updates can be risky.
Windows & Driver Conflicts
Here’s where it can get fun (and by “fun,” I mean frustrating):
Drivers
Mixing integrated graphics drivers with those for your discrete GPU can cause software conflicts. While modern versions of Windows are pretty good at handling this automatically, you may find yourself knee-deep in driver issues, resulting in display inconsistencies.
Performance
Splitting tasks between two different graphic outputs can cause a performance hiccup. Your discrete GPU should be more than capable of handling multiple monitors without stuttering your performance. You’re probably better off avoiding any unnecessary load on your CPU’s integrated graphics, which typically aren’t designed for heavy lifting.
Alternative Hardware Solutions
You might want to consider investing in a monitor with multiple input options or, even better:
  • HDMI Switch: If you’ve got multiple HDMI inputs on your discrete GPU, use an HDMI switch to easily swap between different displays.
  • Multi-Output GPU: If your GPU has a DisplayPort, just grab an inexpensive DisplayPort to HDMI adapter. This is probably the most straightforward and headache-free approach.
Try an Experimental Route
While I deeply respect the opinions above, let’s entertain an offbeat but potentially illuminating experiment: Using hardware like a USB-to-HDMI adapter. This approach won’t meddle with your internal graphics or GPU, offering a clean partition of your onboard and dedicated graphics resources.
Real-World Case Study:
An acquaintance decided to use their motherboard’s HDMI port for a third monitor dedicated solely to displaying chat windows and system stats during gaming. Despite enabling the iGPU in the BIOS and ensuring the drivers were up to date, they faced intermittent flickering and eventually reverted back to using a USB-to-HDMI adapter.
Final Thoughts:
Engaging your iGPU alongside a powerful discrete GPU isn’t merely about enabling a BIOS setting—it’s a complex balancing act that skirts the edge of diminishing returns. If you must use the motherboard HDMI port, ensure you have good reasons and are prepared for potential issues. For ease of setup and maximum performance, a DisplayPort to HDMI adapter is your best friend. If you’re curious or tech-savvy, by all means, experiment—just be prepared to dive deep into troubleshooting.
Try Windows Wireless Display. It extends your desktop over Wi Fi, no BIOS or adapters.
Steps:
  1. On the PC, Settings, Apps, Optional features, Add a feature, install Wireless Display.
  2. On the TV or Miracast dongle, enable screen mirroring.
  3. Press Win+K, pick the device, choose Extend.
Expect 30 to 60 ms latency on Wi Fi 5, fine for email, docs, chat. I run a 1080p seond screen this way at 15 Mbps. Works on RTX and Radeon systems with Miracast support. If stability drops, switch to 5 GHz, keep under 20 feet, update drivers.
