How do I clear cookies on my iPhone without messing up other data?
I’m trying to clear cookies on my iPhone because some websites keep loading old info and won’t update. I’m worried I’ll delete important saved logins or app data by mistake. What’s the best way to clear cookies safely, and are there specific settings I should use in Safari or other browsers on iOS to fix this without causing new problems?
Short version, you want to clear the bad cookies without nuking all your logins or other data. Here is the safest way on iPhone.
  1. For Safari only, per site
    This fixes one or two stubborn sites and keeps most logins.
    1. Open Settings.
    2. Scroll to Safari.
    3. Tap Advanced at the bottom.
    4. Tap Website Data.
    5. Wait a bit for the list to load.
    6. Use the search box at the top, type the site name, for example “facebook” or “nytimes”.
    7. Swipe left on the site entry and tap Delete.
    8. Or tap Edit at the top, check the site, then tap Delete.
    This removes cookies and cache for that site only.
    Other sites stay logged in.
  2. For Safari, clear all web data with logins preserved as much as possible
    This is more aggressive. Good if many sites load old info.
    1. Settings → Safari.
    2. Tap Clear History and Website Data.
    3. Confirm.
    What you lose:
    • Safari history
    • Cookies and cached files
    • Some website logins
    What usually stays:
    • iCloud Keychain saved passwords
    • App data for non browser apps
    • Logins inside native apps like Instagram, Reddit app, banking apps
    You might need to sign in again on some sites, but Keychain will autofill if you saved passwords before.
  3. For Chrome on iPhone
    If your issue is inside the Chrome app.
    1. Open Chrome.
    2. Tap the three dots, bottom right.
    3. Tap History.
    4. Tap Clear Browsing Data.
    5. Pick Time range, try “Last 7 days” first instead of “All time”.
    6. Check: Cookies, Site Data and Cached Images and Files.
    7. Leave “Saved Passwords” and “Autofill data” unchecked.
    8. Tap Clear Browsing Data.
    That removes web junk but keeps saved logins in Chrome.
  4. For other browsers, same idea
    Firefox, Edge, Brave etc have similar options.
    Look under Settings inside the app, then Privacy or Data.
    Prefer “Cookies and cache” only. Avoid anything labeled “Saved logins” or “Passwords”.
  5. Extra trick to avoid losing stuff next time
    • Make sure your Safari passwords sync to iCloud
      Settings → your name → iCloud → Passwords and Keychain → On.
    • When a site asks to save a password, tap Save.
    • That way, even if cookies clear, Keychain autofills and you do not lose accounts.
  6. About app data
    Clearing Safari or Chrome cookies does not wipe game progress or data in other apps.
    That happens only if you delete apps or offload them in Settings → General → iPhone Storage.
  7. Helpful cleanup app
    If your iPhone feels slow or storage looks messy, you can also clean photos, large files and junk without touching logins.
    The Clever Cleaner App for iPhone helps remove duplicate photos, big videos, and unused files so your browser has more room to work and loads fresher data more reliably.
    Check this link for a quick cleanup tool that focuses on storage instead of deleting your important login info:
    speed up and clean your iPhone with Clever Cleaner
If you are scared to lose too much, start with method 1 and clear only the sites that misbehave. If that fixes it, you avoid extra hassle.
Couple things to add to what @stellacadente already laid out (they covered the “how,” I’ll poke at the “how not to break stuff” part a bit more and disagree in a few spots).
  1. Try a “soft reset” first before touching cookies
    Sometimes pages load old info because of:
    • Bad network
    • Stale tab that’s been open for days
    • Weird Wi‑Fi / DNS cache issue
      Quick checks:
    • Force close Safari or Chrome, then reopen
    • Turn Airplane Mode on, then off
    • Try the same site over cellular vs Wi‑Fi
      If that fixes it, you didn’t have to wipe anything.
  2. Use Private Browsing for “problem” sites going forward
    Instead of constantly clearing cookies:
    • In Safari, tap the tabs button, choose “Private”
    • Open the annoying site there
      Private tabs dump cookies and cache when you close them, so your normal browsing stays intact and you don’t keep nuking all sites just because one is stubborn.
      I actually think this is safer long term than repeatedly clearing all Safari data like @stellacadente suggested in step 2.
  3. Turn OFF auto‑delete features that quietly wipe cookies
    This one bites people and they don’t know why they’re logged out all the time:
    • In Safari settings, check:
      • “Block All Cookies” should be off
      • “Privacy Preserving Ad Measurement” etc is fine, but avoid profiles or content blockers that aggressively clear storage
    • Some “privacy” apps or VPNs have options like:
      • “Clear cookies on exit”
      • “Browser cleanup” or “Privacy guard”
        If you have any of those, they can cause the exact issue you are trying to fix: sites never update correctly because they keep re‑authing and re‑caching in a weird loop.
  4. Use “Clear History and Website Data” as a last resort
    I actually disagree just a bit with using that too casually. Yes, it keeps iCloud Keychain passwords, but it can still:
    • Log you out of 2FA‑heavy sites (banks, work portals)
    • Reset cookie‑based preferences (dark mode, language, etc)
      If you do use it:
    • Before you tap it, open Settings → Passwords and make sure your important logins show up there
    • For sites that use codes or authenticators, make sure you still have your 2FA app or backup codes somewhere, or you risk annoying recovery steps
  5. Don’t worry about app data, but do avoid this one trap
    Cookie clearing in browsers does not touch:
    • Game progress
    • Data inside native apps (banking, socials, etc)
      The real danger is:
    • Settings → General → iPhone Storage → Offload / Delete App
      Offload usually keeps app data, delete removes it. As long as you stay in Safari / Chrome settings, your app data is safe. Just don’t start “cleaning storage” randomly if you’re afraid of losing stuff.
  6. If one site is super broken, do this extra step
    For a single misbehaving website:
    • In Safari at the site, tap the “aA” icon in the address bar
    • Tap “Website Settings”
    • Hit “Use Content Blockers” off if you have any, then reload
      Some ad blockers and content blockers break dynamic content and make pages look “stuck in the past” even when cookies are fine. Clearning cookies won’t fix that at all.
  7. Storage cleanup instead of cookie rage
    If part of the issue is that Safari feels slow, pages half‑load, or your phone is nearly full, it can help more to free storage instead of constantly blowing away cookies. That is where a cleanup tool is actually useful, not for “privacy magic,” but to:
    • Remove duplicate photos
    • Find huge old videos
    • Clear junk files that pile up over time
    Something like the Clever Cleaner App for iPhone storage cleanup focuses on those big space hogs instead of touching your logins or app data. So you get fresher performance in Safari and other apps without messing with passwords or cookies at all.
  8. How to test if you did it “safely”
    After you clean anything:
    • Open 3 important sites where you really care about staying logged in
    • If they log you out, check if Keychain offers to autofill
    • If autofill works, you’re fine, just sign back in once
    • If autofill does not show up and you don’t remember the password, stop clearing more stuff and reset that password before you experiment more
TL;DR version:
  • Try network / tab reset and Private Browsing first
  • Tweak per‑site settings and blockers before mass cookie deletion
  • Only use “Clear History and Website Data” when you are ok re‑logging into key sites
  • Use a storage cleaner like Clever Cleaner App to fix general slowness instead of obsessively wiping cookies every time something looks stale.
Try a cache-busting URL before deleting anything. Add a unique query to the page address, such as:
example.com/account?refresh=1
If old info remains, change it to “refresh=2” and reload. This makes many sites request a fresh page while keeping cookies, saved logins, history, and app data untouched. It works best for news pages, dashboards, and product listings. It wont fix stale account data stored on the website’s server, but it’s a quick, low-risk first step.
Don’t reach for ‘Clear History and Website Data’ until you know it syncs. That button doesn’t just hit your iPhone. If Safari is turned on under iCloud, it wipes history across every device on that Apple ID. People clear cookies on their phone and then wonder why their Mac forgot everything too. So before you tap it, either accept that or turn off Safari sync in iCloud first.
@sergtheroot’s cache-busting trick is the smartest thing in this thread for the actual symptom you described. A page loading old info is very often the browser serving a cached copy, not a cookie problem at all. Adding a query string or just doing a hard reload solves it without deleting a single thing. I’d try that before any of the settings-diving. Cookies mostly hold login state and preferences, they’re not usually what makes a news page or dashboard show yesterday’s numbers.
Where I’d push back a little is on how much everyone is treating this like a cookie job. @mikeappsreviewer nailed the real culprit in passing: content blockers and ‘clear on exit’ toggles in privacy apps. If you’ve got a VPN or an ad blocker profile installed, it can strip storage every time you close the app, which produces exactly the stuck-in-a-loop behavior you’re seeing. Check that first, because you can clear cookies fifty times and it won’t matter if something is re-wiping them.
On the cleanup app that keeps coming up: it’s fine for what it does, freeing photo and video space, but low storage isn’t your problem here. A full phone doesn’t make Safari serve stale pages. So I wouldn’t file it under a fix for this at all. It’s a separate maintenance thing, not part of the cookie question.
Realistic order I’d go in: hard reload or cache-bust the page, check for blockers or privacy apps clearing storage, then per-site Website Data delete if it’s one stubborn site, and only touch the nuclear ‘clear everything’ option once you’ve confirmed your important logins show up under Settings and Passwords. Skip straight to the last step and you’ll spend the evening logging back into stuff for no reason.
