How can Solvely Ai help me solve this specific problem?
I’ve been trying to use Solvely Ai to work through a problem, but I’m not getting the results or guidance I expected. I’m not sure if I’m using the tool correctly, missing a feature, or misunderstanding how it’s supposed to work. Can someone explain how to effectively use Solvely Ai for step-by-step problem solving and where I might be going wrong?
Couple of things that usually trip people up with Solvely:
  1. Be specific with the problem
    If you say something like “help me with algebra,” Solvely stays vague.
    Try: “Solve 3x + 5 = 20 and show each step. I got stuck after isolating x.”
    Mention what you tried and where you got stuck. That pushes it into step‑by‑step mode.
  2. Use step or explain prompts
    Add prompts like:
    • “Explain this like I am in 8th grade.”
    • “Show one step at a time and wait for me to respond.”
    • “Give me 2 different ways to solve this.”
    If it skips steps, say “slow down, show the missing step between line 2 and 3.”
  3. Check if you are in the right “mode”
    Some tools in that space have:
    • “Solver” mode, which outputs only answers.
    • “Tutor” mode, which explains.
    If you see only final answers, look for any toggle like “detailed solution” or “explain steps” and turn it on.
  4. Feed it the full context
    Paste the exact problem.
    Include instructions from your teacher or textbook, like “no calculator” or “must use substitution” or “show work.”
    Tell it: “Follow these instructions exactly.”
    If it ignores them, repeat “follow the instructions I gave above” and restate the key ones.
  5. Use short, focused questions
    Long multi part prompts confuse it.
    Break things up:
    • First: “Help me set up the equation.”
    • Then: “Ok, solve from here and explain.”
    • Then: “Check if the answer is correct.”
    Stepwise chats get better guidance.
  6. Ask it to check your work, not only solve
    Type your full attempt.
    Then say:
    • “Point out only the first mistake.”
    • “Show the correct version of that step only.”
    This turns it into a grader instead of a solver that skips to the end.
  7. Clarify what kind of help you want
    Say things like:
    • “Do not give the final answer until I ask.”
    • “Ask me questions to see what I know before explaining.”
    • “Explain, then give a similar practice problem for me to try.”
    That keeps it from overdoing the answer.
  8. If the output feels wrong or shallow
    Respond in the same thread with:
    • “Your step 3 looks wrong, check that again.”
    • “Give more detail on why you did this step.”
    • “Show the algebra behind this transition.”
    Iterating like that often fixes the quality.
  9. Things Solvely will not do well
    • Multi step word problems with missing info if you do not clarify assumptions.
    • Problems where a picture is needed, if you do not upload or describe the diagram.
    • Open ended tasks like “make my essay better,” unless you say what “better” means.
  10. Quick checklist to see if you use it right
    • Did you paste the full question.
    • Did you say your level (middle school, high school, college).
    • Did you say how you want the help (step by step, hints only, full solution).
    • Did you correct it when it skipped or rushed.
If you share 1 example prompt you used and what answer you got, people here can point out if it is a usage issue or a tool limitation.
You’re not crazy, Solvely can feel a bit “meh” if you just toss a problem at it and hope it reads your mind.
@sterrenkijker already covered a lot of how to ask, so I’ll focus more on what role to make Solvely play and where expectations usually go off the rails.
1. Decide what job you want Solvely to do
Solvely is decent at a few different “jobs,” but it sucks if you try to make it do all of them at once:
  • Tutor:
    Tell it explicitly:
    “Act like a tutor. Ask me questions before you explain anything. Don’t give the final answer until I say so.”
    Then actually answer its questions, even if you’re not sure. That’s what steers the explanation.
  • Checker / debugger:
    Instead of “solve this,” try:
    “Here’s my full solution. Mark only the first mistake, explain why it’s wrong, and show the corrected step.”
    This avoids the classic “here’s the final answer, goodbye” behavior.
  • Pattern explainer:
    If the problem is one of many similar ones, you can say:
    “Explain the general pattern to solve problems like this, then check if my attempt follows that pattern.”
If you’re getting useless output, it’s often because Solvely is guessing which of these you want.
2. Stop trying to be “polite” in your prompts
Honestly, vague prompts are worse than “rude” ones. Be bossy and specific:
  • Instead of:
    “Can you help me with this?”
    Try:
    “Break this problem into 3 main steps. For each step, tell me the goal, the rule used, and then show the algebra. Do not skip arithmetic.”
Harsh-sounding instructions usually produce better guidance than soft, generic ones.
3. Calibrate it with a tiny test problem first
This is underrated:
  1. Give it a simpler version of your problem.
  2. Tell it exactly how you want the solution formatted.
  3. If it gets the style right, then feed the real problem and say:
    “Solve this in exactly the same style as the previous example.”
If it can’t handle the small one the way you want, it definitely won’t magically do better on the harder one.
4. When Solvely is just… wrong
People treat AI outputs like scripture. Don’t.
If something looks off:
  • Say exactly what you suspect:
    “Your use of the quadratic formula looks wrong. You lost a minus sign. Recompute that step only.”
  • If it keeps messing up the same kind of step, tell it:
    “From now on, double check any step involving fractions before you show it to me.”
That kind of “meta” instruction actually helps a lot, even if it feels silly.
5. Use it to understand why your teacher / textbook wants something
Solvely is good for the “why are we even doing it this way” questions your textbook doesn’t answer:
  • “My teacher says I have to use substitution, not elimination. Explain why substitution is a valid method and when it is better or worse than elimination, in the context of this exact problem.”
This turns Solvely into a concept explainer instead of just a calculator with paragraphs.
6. When it’s the wrong tool
Sometimes you’re not misunderstanding Solvely; you’re just asking it to be something it isn’t great at:
  • Very messy multi step word problems where you haven’t pinned down the data.
  • Anything with a diagram you didn’t describe or upload.
  • “Make this essay better” without saying what “better” means.
If your problem depends heavily on a picture, exact formatting, or some trick from class, you’ll have to over explain that context. Otherwise, you’ll keep getting weird or shallow answers and think you’re “using it wrong” when the tool is simply blind to key info.
7. A concrete way to test if it’s you or the tool
Try this experiment with the problem that’s giving you trouble:
  1. Paste the exact problem.
  2. Add:
    “I am [your level: e.g., high school junior].
    First: help me interpret the problem and restate it in simpler words.
    Second: ask me what I think the first step is.
    Third: if my idea is wrong or incomplete, correct it and explain why.
    Don’t give the final numerical answer until I say ‘ok, finish it.’”
If the response still feels unhelpful after that, post the prompt you used and what Solvely replied with. At that point it’s a lot easier to say “yep, that’s a limitation” vs “tiny tweak in how you’re prompting will fix this.”
TL;DR: you’re not missing some secret “feature.” You’re mostly negotiating roles with the tool: make it your tutor, checker, or explainer very explicitly, be bossy about format and pacing, and use a small test problem to dial it in before throwing the big one at it.
Solvely AI can help, but only if you treat it more like a tool you configure than a magic tutor. Since @shizuka and @sterrenkijker already covered “how to ask” and “what role to assign,” I’ll zoom in on some different angles: diagnosing why it is failing you and how to adapt around that.
1. Figure out where the breakdown actually is
Instead of just thinking “this answer is bad,” run a quick self‑check:
Ask yourself after Solvely’s reply:
  1. Did it misunderstand the math / content?
  2. Did it misunderstand the instructions / format (e.g., you wanted hints, it gave full solution)?
  3. Did it misunderstand the goal (e.g., you wanted to learn, it just spit an answer)?
Use that to steer your follow up:
  • If content is wrong:
    “Recheck the step where you move terms across the equals sign. The sign seems off. Correct only that part.”
  • If format is wrong:
    “This is too summarized. Rewrite the solution so that every equality has only one operation applied.”
  • If goal is wrong:
    “Stop giving final answers. Just ask me what the next step is and confirm or fix it.”
Most people just rephrase the same vague prompt and get the same frustration.
2. Don’t copy the problem; copy the rubric
Something I partly disagree with in the earlier advice: just pasting the whole problem is not always enough. The textbook question is often less important than the grading rules.
Try:
  • Paste the problem.
  • Then paste any rubric or pattern you know your teacher wants, like:
    “My teacher gives full points only if:
    1. I define variables,
    2. I write a clear equation,
    3. I check the solution.
      Make your explanation follow these exact stages and label them the same way.”
Solvely AI is much better at following a template than guessing what your teacher values.
3. Turn Solvely into a pattern detector, not just a solver
If you keep getting stuck on “this one type of problem,” Solvely is useful as a pattern mirror:
  1. Give it 3 or 4 different problems of the same kind that you struggled with.
  2. Ask:
    “Solve these, then summarize the shared pattern:
    • what is always step 1
    • what is always the ‘trick’
    • what is usually the last check.”
  3. Then feed it a new problem and say:
    “Now, instead of solving for me, just tell me which pattern from above this problem fits, and what step 1 should be.”
This is where it can outperform a static solution key, because it can articulate the structure behind several problems at once.
4. Use Solvely AI to reverse engineer your confusion
If you are “not getting the guidance you expected,” sometimes you are not sure what you want. That sounds harsh, but it is common.
Try this inversion trick:
  • Ask Solvely:
    “Here is the problem and my attempt. Based on my attempt, what do you think I am confused about? List 3 possibilities and which steps they would affect.”
Then look at its guess:
  • If it correctly guesses your confusion:
    “Focus your explanation only on confusion #2. Ignore everything else.”
  • If it misses:
    “No, that is not it. I actually understand factoring; I do not understand why we set the expression equal to zero. Explain only that idea, with no algebra.”
This way, you are using it more as a diagnostic mirror than a teacher that dumps the whole chapter on you.
5. Use “micro prompts” between each step
I mildly disagree with the idea that you always need long, detailed prompts. Once the initial setup is done, short, precise interrupts usually work better:
  • After it gives a step:
    “Pause. Why is this legal?”
    or
    “Pause. What alternative operation could I do here instead, and what would that change?”
Those tiny questions prevent it from racing to the finish and force it to justify transitions. That is where a lot of learning happens.
6. Compare Solvely’s style to other helpers (pros & cons)
You mentioned not knowing if you are missing a feature, misunderstanding the tool, etc. It might help to think of Solvely AI compared to what @shizuka and @sterrenkijker typically suggest.
Pros of Solvely AI:
  • Flexible role playing: tutor, checker, explainer, depending on how you frame the prompt.
  • Good at restructuring: can restate the same solution at different difficulty levels (e.g., “elementary,” “college”).
  • Can enforce specific workflows: “Polya 4‑step method,” “RUP problem solving,” etc., if you name them.
Cons of Solvely AI:
  • Can be overly confident with slightly wrong math steps if you do not challenge it.
  • Not great with missing context: it assumes generic textbook expectations unless you spell out teacher‑specific quirks.
  • Sometimes collapses into “final answer bot” if your prompt is even a bit vague.
Compared to other helpers like the styles that @shizuka and @sterrenkijker work with:
  • Those approaches focus heavily on prompt design and role definition, which is powerful, but if you only follow that, you might still miss using Solvely as a diagnostic tool (guessing your confusion) or as a pattern summarizer.
  • Solvely, used well, can mix explanation, pattern extraction and grading in a single thread, which is something most simple Q&A tools do not really handle.
7. Concrete experiment to run right now
To see if the issue is you or Solvely, try this minimal script on your current problem:
  1. Paste the problem and your full attempt.
  2. Then say, in one go:
    “You are Solvely AI.
    1. Identify the first step where my solution diverges from a correct one.
    2. Show the correct version of that step only.
    3. Ask me to continue from there.
    4. Do not reveal the final answer unless I type ‘finish’.”
  3. If it respects those rules and you still feel lost, the problem is probably conceptual and you may need to ask:
    “Explain the idea behind that step without any symbols, just words and a simple analogy.”
  4. If it does not respect your rules, respond with:
    “You ignored instruction #2 (or #4). Rewrite your reply so that all 4 instructions are followed exactly.”
If after 2 or 3 back‑and‑forths it still cannot follow those constraints, then you have hit a limitation of Solvely AI on that specific task, and it is not just “using it wrong.”
TL;DR: Instead of only trying to coax better solutions out of Solvely AI, use it as a pattern detector, confusion guesser and rubric follower. Be strict about your instructions, interrupt it often with micro questions, and explicitly test whether it can follow a short rule list. That will quickly tell you if the problem is your prompt, your goal, or the tool itself.
