How can I identify my CPU cooler?
Built my PC a while ago, but I’ve forgotten the model of the CPU cooler I used. Need to confirm what it is for a possible upgrade. Any advice on how to figure out which cooler I have?
Seriously? You built your PC and you don’t even remember what you put in there? Why bother upgrading if you can’t even remember the parts you used?
Okay, let’s get this over with. First, open up your case and look at the cooler. If it has a logo or a model number, big surprise, just Google it. Can’t read markings? Then let me guess. Another genius move: you didn’t keep the packaging or documentation, right? Check for those if you haven’t thrown them away.
Still lost? Take a photo and use an image search service like Google Images to match the cooler. If you get no matches, well, maybe it’s some no-name brand or an outdated model.
And by the way, if you’re upgrading, don’t just look at the cooler. Check your thermal paste, airflow, and case compatibility. You might end up bottlenecking your new cooler’s performance because you didn’t think it through.
Or just forget upgrading cooling and move on to liquid coolers, but I’m guessing that’s too complicated. While you’re at it, check out a few reviews for brands like Noctua, Cooler Master, or Corsair. But maybe don’t expect to remember which one you got this time either.
Wow, someone woke up on the wrong side of the motherboard! @techchizkid’s methods are alright, but let’s keep it a little less doomsday, okay?
Alright, here’s a more structured and mellowed approach that might help you out:
  1. Open the Case: Yeah, this sounds basic, but start by opening up your case. Use a flashlight or your phone’s light to get a better look at the cooler.
  2. Check for Labels: Look around the edges and the top of the cooler for any branding or model numbers. Some manufacturers like to put their names in hard-to-see places, so be thorough.
  3. Consult the BIOS/UEFI: With the PC powered up, you can enter the BIOS or UEFI settings (typically by pressing keys like F2, DEL, or ESC during startup). Some higher-end motherboards will show you the make and model of the cooler installed.
  4. Software Identification: There are several apps that can help identify your hardware, like HWMonitor or Speccy. While these are more geared towards showing temperatures, some can tell you what components you have, including your cooler.
  5. Visual Identification: Another method is joining a PC hardware forum or subreddit. Post a clear pic of your cooler; the community is usually pretty good at identifying parts just from photos.
  6. Check Purchase History: If you bought your parts online, go back through your order history on sites like Amazon, Newegg, or the retailer you used. Your order details might just have what you need!
One more thing, don’t jump straight to liquid cooling unless you understand the maintenance and risks involved. High-end air coolers like those from Noctua and Be Quiet! perform nearly as well without the fuss.
If after all this you still can’t identify it, it might be a good opportunity to re-evaluate your entire build. This includes ensuring that your case has enough airflow and that your thermal paste is still doing its job.
Oh, and don’t let anyone shame you for forgetting parts. Happens to the best of us! Just get the info you need and make an informed decision about your upgrade.
First, here’s a wildcard idea — if you wrote down your PC specs somewhere when you built it, like maybe in a PC part picker list or a note app, that might help jog your memory about the cooler model.
Now, something that hasn’t been mentioned: Motherboard Manuals. If your cooler came with your motherboard purchase, there’s a chance it might be mentioned in the documentation. Page through the installation section to see if there’s any mention of the specific cooler model.
Another avenue is software, but with a twist. You could use benchmarking software like AIDA64 Extreme. It’s thorough and you might have the luck of some system integrators tagging the cooler model info in there.
You could also try tools that are specifically made to identify hardware, like CPU-Z or HWiNFO. They dig deep into the hardware and might give you more details than you’d expect, potentially even cooler models if it uses a distinct driver.
Here’s a kind of overlooked method, try contacting the manufacturer. If you remember which brand your cooler is (even if it’s just a wild guess), head over to their support forum or customer service. Give them as much info as you have, and they may be able to help identify the model based on descriptions or visuals. Some brands are really good at recognizing their own products, even if it was released 5 years ago.
Addressing the point of keeping your hardware specs — sure, many of us have thrown away the boxes and documentation of our cooler, but there’s also an off chance that you kept those around somewhere. Dig through any old storage bins or closets if you haven’t already.
Lastly, consider this concept: Community Identification. Big tech communities like Tom’s Hardware, Reddit’s r/buildapc, and even Linus Tech Tips forums are gold mines for this sort of inquiry. Take a few clear photos from different angles and post them with as much context as possible. You’d be surprised how many hardware buffs can identify even obscure models just from pictures.
When it comes to upgrading, another critical thing to think about is compatibility. It’s not just about figuring out if the new cooler fits your CPU, but also if it works well with your case. Measure twice, buy once. Ensure you’ve got the dimensions of your current case and understand the TDP (Thermal Design Power) of the cooler you’re eyeing.
Also, other factors like RAM clearance and whether it will interfere with your GPU or any other components come into play. Trust me, nothing’s more frustrating than figuring out that your shiny new cooler blocks another vital part of your build.
And about liquid coolers — yes, they can be great, but they’re not always necessary. High-end air coolers can be just as effective without the risk of leaks. Brands like Noctua and be quiet! are top-notch in this department. Don’t get caught up in the liquid cooling hype unless you’re planning some heavy overclocking.
Definitely replace the thermal paste too. If it’s been a while, the old paste can degrade and won’t transfer heat as effectively. A small tube of quality thermal paste isn’t too expensive and it’s a good habit to reapply every couple of years depending on your usage.
So put all that together, and you should be pretty well-armed to figure out what cooler you’ve got and what upgrade will serve you best. Don’t shy away from asking the community and potentially dealing with a bit of shame — we’ve all been there. Good luck!
You covered notes, manuals, software IDs, brand support, old boxes, community photo IDs, fit checks, paste refresh.
Simpler path: hunt reciepts. Open email and retailer acconts. Search terms: cooler, heatsink, AIO, Noctua, be quiet, Corsair, Cooler Master. Filter by your build month and year. Find the order line with SKU or model. Copy it, run a quick web search, confirm images match. If no email, check bank statements for Amazon, Newegg, Micro Center. Pull order history from those portals. This takes 5 to 10 minutes in most cases. Less fuss, high hit rate.
