How can I fully silence notifications on my iPhone?
I keep getting alerts and sounds on my iPhone even when I think I’ve turned everything off. I’ve tried Do Not Disturb and Silent mode, but some apps still buzz or light up the screen. Can someone walk me through the best way to completely silence notifications on an iPhone, including calls, texts, and app alerts, without missing anything important later?
This trips a lot of people up. iOS has like 5 different places that still let sound or alerts leak through.
Here is a full “nuke it” checklist. Do it in this order.
  1. Use a Focus instead of old “Do Not Disturb”
    • Settings > Focus > Do Not Disturb
    • Turn on “Do Not Disturb”
    • Tap “People”
      • Under “Allowed Notifications”, set to “None”
      • Turn off “Allow Repeated Calls”
    • Tap “Apps”
      • Make sure “Allowed Apps” is empty
    • Scroll down to “Options”
      • Turn OFF “Time Sensitive Notifications”
    • At top, turn on “Share Across Devices” only if you want the same on iPad/Mac. Otherwise leave off.
    • On main screen, tap your Focus, tap “Add Schedule” if you want it auto at night etc.
  2. Block notifications on Lock Screen so screen does not light up
    • Settings > Notifications
    • Under “Display As” pick “Count”
    • For each noisy app:
      • Tap the app
      • Turn off “Lock Screen”
      • Turn off “Banners”
      • Turn off “Sounds”
      • Turn off “Badges” if you want totally clean
    • Pay close attention to messaging apps, social media, email, delivery, calendar.
  3. Kill “Time Sensitive” and “Critical” stuff
    • Same place, Settings > Notifications
    • For any app that has “Time Sensitive Notifications”, turn that off.
    • Some emergency or health apps have “Critical Alerts” that bypass mute.
      • In each such app’s notification settings, turn off “Critical Alerts”.
  4. Check the physical mute switch and volume
    • Left side of iPhone, flip the Ring/Silent switch so orange shows.
    • Press Volume Down to zero while NOT in a call or media.
    • Settings > Sounds & Haptics
      • Turn off “Vibrate on Ring” and “Vibrate on Silent” if you want no buzzing at all.
      • Under “Ringtone” and “Text Tone” pick “None” for alerts if you want belt-and-suspenders silence.
  5. Turn off “Attention Aware” and Raise to Wake
    These wake the screen and make it feel like you got a notification.
    • Settings > Display & Brightness
      • Turn off “Raise to Wake”
    • Settings > Face ID & Passcode
      • Turn off “Attention Aware Features”
  6. Silence calls fully
    • Settings > Phone
      • “Silence Unknown Callers” to ON if spam calls bug you.
    • Settings > Phone > Announce Calls
      • Set to “Never”.
  7. Check each chat app’s internal settings
    Some apps ignore system defaults by design.
    • Open WhatsApp, Telegram, Messenger, etc
    • Go to Settings inside each app > Notifications
    • Turn off “In-App Sounds”, “Vibrate”, “Message Preview”, “Stories notifications”, “Group notifications”, etc.
    • Also check “Calls” in each app and disable sound and vibration.
  8. Disable Emergency Alerts if you really want total silence
    Warning: you might miss important alerts.
    • Scroll to the bottom
    • Turn off “AMBER Alerts”, “Emergency Alerts”, “Public Safety Alerts” and “Test Alerts” if listed.
  9. Stop apps from waking the screen with “Push” style behavior
    For some email apps:
    • Settings > Mail > Accounts > Fetch New Data
    • Turn off “Push”
    • Set “Fetch” to “Manually” or long intervals.
  10. Use “Silence” = Always in Focus
    This one leaks for a lot of people.
  • Settings > Focus > Do Not Disturb (or your custom Focus)
  • Tap “People” or “Apps”, then tap “Options” if shown.
  • Look for “Silence” and set to “Always”, not “While iPhone is locked”.
  1. Quick test routine
    After all that, test with another phone.
  • Keep your iPhone locked.
  • Make sure Focus is ON, mute switch orange, volume 0.
  • Send SMS, WhatsApp, email, call.
  • Phone should:
    • Not light up
    • Not buzz
    • Not play any sound.
If it still buzzes or lights up, write down which app did it and check that app again in:
Settings > Notifications > [App name]
plus its internal settings.
It is a lot of toggles, but once done you get a truely silent phone.
You’ve already got a pretty nuclear checklist from @cazadordeestrellas, so I’ll skip rehashing all of that. A few extra spots where iOS still leaks noise or screen wake that people miss:
  1. CarPlay & Bluetooth junk
    • If your phone connects to a car or speaker, it can “announce” stuff even when everything else is off.
    • Settings > Notifications > Announce Notifications
      • Turn it OFF completely.
    • Also check: Settings > Siri & Search > Announce Notifications and kill it there too if present.
  2. Siri / Voice feedback
    Sometimes Siri talks even when you think the phone is muted.
    • Settings > Siri & Search
      • Siri Responses > set to “Prefer Silent Responses”
      • Turn off “Always Show Siri Captions” if you don’t want screen lighting up unnecessarily.
  3. Widgets & Live Activities
    A Focus can be silent but your screen still keeps “doing stuff.”
    • Long press the Lock Screen > Customize
      • Remove widgets that constantly refresh: weather, fitness, delivery trackers.
      • Under “Allow Access When Locked,” turn off “Live Activities” and “Today View and Search” so the lock screen doesn’t become a distraction hub.
  4. Calendar & Reminder alerts that ignore your vibes
    • Settings > Calendar > Alternate Calendars off, Time Zone Override off.
    • Settings > Reminders > turn off “Today Notification” if you see it.
      Then in Notifications for both apps, set style to “None” or at least kill Sounds, Badges, Lock Screen. Recurring events are sneaky.
  5. Sleep Focus vs DND conflict
    If you set up Sleep in the Health app, that Focus can override your manual Do Not Disturb and re-open some “allowed” people or apps.
    • Settings > Focus > Sleep
      • Check People and Apps, clear them out.
      • If you don’t actually use Sleep tracking, just delete the Sleep Focus.
  6. Screen mirroring / casting
    When you AirPlay or screen mirror, some notifications behave differently.
    • Control Center > Screen Mirroring
      • Make sure it is OFF when you’re expecting true silence.
    • If mirroring a lot, use a dedicated Focus for that and set Silence > Always.
  7. Background sounds & accessibility stuff
    Sometimes the “noise” isn’t notifications, it is accessibility or system audio.
    • Settings > Accessibility > Audio/Visual
      • Make sure “Background Sounds” is off.
    • Also in Accessibility > Touch
      • Turn off “Vibration” entirely if you want the phone to be a dead brick.
  8. App refresh that wakes things indirectly
    This will not stop notifications, but it will reduce random activity that looks like them.
    • Settings > General > Background App Refresh
      • Set to “Wi-Fi” or “Off” and selectively enable only the apps you truly need.
  9. Focus filters that re-enable things
    On newer iOS you can add Filters to a Focus (Mail accounts, Messages accounts, etc.). Some people accidentally allow a work account to always break through.
    • Settings > Focus > [Your Focus] > Filters
      • Remove all filters unless you actually know why you need them.
  10. When you really need 100% silence for a few hours
    Slight disagreement with the “do it all with Focus only” approach: if you want a guaranteed brick for a meeting or flight, I still recommend:
  • Turn on Airplane Mode
  • Turn Wi‑Fi off too if it auto turns on
  • Turn on your stricter Focus on top of that
    That way even misconfigured apps cannot ping you because they never reach the phone.
If after all that you still get a buzz or flash, note exactly:
  • Which app
  • Whether screen was locked or unlocked
  • Whether Focus icon showed in the status bar
Then go to Settings > Notifications > [that app] and also its in‑app settings. Most of the time the final “leak” is some chat app with its own “in-app notifications” or “alerts while open” toggle that ignores system behavior.
You already have two “scorched earth” checklists from @byteguru and @cazadordeestrellas, so I’ll come at this from a different angle: making silence usable without turning your iPhone into a brick forever.
1. Build two Focus modes, not one
Instead of a single mega‑Do Not Disturb, create:
  • “Work Focus”
    • Only allow work apps and a couple of key contacts.
    • Silence: set to Always.
    • Schedule it for work hours.
    • This keeps real life quiet while still letting through what you actually need.
  • “Hard Mute Focus”
    • No people, no apps allowed.
    • Time Sensitive off.
    • Silence: Always.
    • No schedule; you toggle this manually for meetings, sleep, flights.
Why: Their checklists are great, but if you follow them literally you end up permanently over‑tuned and constantly digging through Settings. Two separate Focuses means you just tap the one that matches the situation.
2. Use widgets & lock screens as “non‑alert dashboards”
Instead of chasing every single app toggle, repurpose your lock screen:
  • Make a “Quiet Lock Screen” paired with Hard Mute Focus.
    • No widgets that pull your eye into new info (no mail, social, news).
    • If you must see something, pick static stuff like a calendar for the day.
  • Make another lock screen for Work Focus with the widgets you actually want.
That way the screen can light if you choose but it never screams for attention.
3. Replace noisy apps instead of fighting them
Some apps simply do not behave well, even with all the toggles off.
  • Messaging: if an app keeps leaking sounds or vibrations, consider using the system Messages app as your “quiet” channel and relegate the noisy one to work hours only in Work Focus.
  • Email: prefer Apple Mail with manual fetch over a hyper‑push client that fights Focus rules.
Sometimes app choice gives more peace than any settings maze.
4. Decide what must never be silenced
This part is where I slightly disagree with the total “nuke it” approach:
  • Most people should keep at least Emergency Alerts or a single contact (family, partner, etc.) that can always get through in one Focus mode.
  • In Hard Mute Focus, sure, black‑hole everything.
  • In Work Focus or a “Daily” Focus, let that one contact and emergency alerts stay on.
You get a spectrum: daily quiet vs rare total blackout.
5. Make Airplane Mode your “final boss”
When you absolutely cannot risk a leak:
  • Turn on Airplane Mode.
  • Then enable Hard Mute Focus on top of that.
Even if one app is misconfigured, there is nothing coming in to alert you.
6. When something leaks, treat it like a bug report
Instead of redoing all settings every time:
  1. Note the exact app and what happened: sound, vibration, or just screen wake.
  2. Check:
    • Settings > Notifications > that app
    • The app’s own notification / sound settings
  3. Decide if that app should be:
    • Silenced only under Hard Mute Focus
    • Restricted to Work Focus
    • Or replaced entirely
This is faster than continually revisiting every setting they listed.
Quick comparison with what you already got:
  • @byteguru focused on hidden places like CarPlay, Siri, and accessibility sounds. Excellent for hunting weird leaks.
  • @cazadordeestrellas went full nuclear with a highly detailed switch‑by‑switch guide. Great if you want a one‑time deep clean.
Combining those with a “two Focus” strategy and a few app swaps gives you both real silence and a phone that is still practical to live with.
You covered two Focus modes, quiet lock screens, app swaps, emergency exceptions, Airplane Mode, and a bug-report process. Strong balance of silence and control. Simpler alternative: run Screen Time Downtime full time. Settings > Screen Time > Downtime > Turn On. Every Day. All Day. In Allowed Apps pick none or Phone. In Always Allowed contacts pick Favorites only. Notifcations from other apps route to Notification Center, no sound, no vibrate, no screen wake. Add Silence Unknown Callers for extra quiet. Example, meeting at 2 pm, you recieve calls from Favorites only, everything else stays dark.
