How can I check my CPU model?
I was trying to install new software on my computer and it asked for the CPU type, but I have no idea how to check that. Could someone guide me through the steps to find out what CPU I have? Thanks!
Alright, sounds like you’re trying to install software that needs to know your CPU type. There are several ways to find out what CPU you have. Here are a few methods you can use depending on what operating system you have:
Windows
Option 1: Using Task Manager
  1. Press Ctrl + Shift + Esc to open the Task Manager.
  2. Go to the Performance tab.
  3. Click on CPU in the left sidebar.
  4. On the right side, you’ll see details about your CPU including its model, speed, and number of cores.
Option 2: Using System Information
  1. Press Windows + R to open the Run dialog box.
  2. Type msinfo32 and hit Enter.
  3. In the System Information window that appears, look for the Processor entry in the right-hand pane. It will display information about your CPU.
Option 3: Using Command Prompt
  1. Press Windows + R, type cmd, and press Enter to open Command Prompt.
  2. Type wmic cpu get name and press Enter.
  3. Your CPU model will be displayed below.
macOS
Option 1: About This Mac
  1. Click on the Apple icon in the upper-left corner of your screen.
  2. Select About This Mac.
  3. You’ll see the basic information about your Mac, including the CPU type and speed.
Option 2: System Information
  1. Click on the Apple icon and select About This Mac.
  2. Click on System Report.
  3. In the window that appears, click on Hardware.
  4. You’ll see details about the CPU under Hardware Overview.
Linux
Option 1: Using lscpu Command
  1. Open a terminal window.
  2. Type lscpu and press Enter.
  3. This command will display a lot of information about your CPU.
Option 2: Reading from /proc/cpuinfo
  2. Type cat /proc/cpuinfo and press Enter.
  3. You’ll see a lot of information about your CPU. Look for the lines that say model name which will give you the CPU model.
BIOS/UEFI
If you can’t boot into your OS for some reason, you can also check your CPU model in the BIOS/UEFI settings:
  1. Restart your computer.
  2. As it boots up, press the BIOS key (commonly Del, F2, F10, Esc, or F12). The key varies by manufacturer.
  3. Navigate to the information tab or similar section in the BIOS/UEFI menu. Usually, you can find CPU-related information there.
Third-Party Tools
There are also several third-party tools that can give you detailed information about your CPU and other hardware components. Some popular ones include:
  • CPU-Z: Available for Windows. It gives detailed information about your CPU, including its model, speed, and other technical details.
  • Speccy: Another tool for Windows that shows detailed information about your system, including the CPU.
  • Hardinfo: Available for Linux. It provides detailed system information and benchmarking results.
Some Technical Terms to Be Aware Of
Just for your info, here’s some jargon you might encounter when looking up CPU specs:
  • Cores: The number of independent central processing units in a single CPU chip. More cores generally mean better performance, especially for multi-threaded tasks.
  • Threads: Often double the number of cores, they allow for parallel task processing.
  • Clock Speed: Measured in GHz, it indicates the speed at which the CPU operates.
  • TDP (Thermal Design Power): The maximum amount of heat a CPU cooler needs to dissipate.
Sometimes CPU models can be a bit confusing because they include letters and numbers that indicate their specific features. For instance, an Intel i7-9700K versus an i7-9700F. The ‘K’ indicates it’s unlocked for overclocking, while the ‘F’ means it doesn’t have integrated graphics.
If you find navigating these details a bit too overwhelming, stick with the Task Manager or ‘About This Mac’ methods—they’re straightforward and give you the basic info you need.
Good luck with your software installation! :raising_hands:
Why go through all the fuss of using Task Manager, terminal commands, or third-party tools when it’s super simple?
For Windows, forget Task Manager – it’s slow and cluttered. Just use the cmd method: open Command Prompt and type wmic cpu get name. Fast and easy! I don’t understand why byteguru gave so many confusing steps.
For macOS, yeah, About This Mac is a no-brainer. No need to go deeper into System Report unless you’re a tech geek who lives for specs and details. Let’s keep it simple, Apple!
Linux users, if you’re comfortable with terminal, “lscpu” works but I find it verbose. Instead, try cat /proc/cpuinfo | grep "model name" – it spits out just the CPU model, much cleaner.
Seriously tho, BIOS/UEFI? Only refereeing to that if your OS won’t boot. It’s outdated info central and clunky as hell. AVOID unless you have no other choice.
Third-party tools like CPU-Z on Windows or Hardinfo on Linux give tons of unnecessary details. Fine if you’re building a gaming rig, unnecessary for simply everday uses.
Simple methods are way better. Keep it short and straight to the point.
Oh boy, here we go with the plethora of ways to find your CPU model. Honestly, for most users, simpler is better. Sure, @techchizkid and @byteguru gave a ton of methods which might be useful in various situations, but let’s add a bit more spice to this mix without going through the same old rigmarole again.
If you’re on Windows and need something even quicker, you might try using the System Settings. Here’s a simple way:
Windows Settings Method:
  1. Press Windows + I to open the Settings.
  2. Go to System.
  3. Click on About at the bottom of the left sidebar.
  4. Under Device specifications, you’ll see the Processor information.
No need for Task Manager clutter or CMD trickery if you just want a straight answer right from the settings. Tasks managing my CPU? More like surfing through jargon and numbers there!
For macOS users, totally agree that “About This Mac” is probably all you need. But hey, if you STILL want an easier ride without the need to dive into System Reports:
Spotlight Search:
  1. Just hit Cmd + Space to open Spotlight Search.
  2. Type “About This Mac”.
  3. Boom! Everything you need is right there without the extra clicks.
Seems like these steps are often taken for more clicks than necessary.
On Linux, the lscpu command gives more detail than most people care to read. K.I.S.S. it, man (keep it super simple):
Inxi Tool (for detail-freaks but still simpler):
  1. Open terminal.
  2. Type sudo apt-get install inxi -y to install it (if you don’t have it yet).
  3. Run inxi -C, and there it is, right to the point. C for CPU, see?
And, for crying out loud, BIOS/UEFI? Only when computers refuse to boot! That’s way too retro-techie. Who’s really got the time?
Third-Party Tools:
Alright though, if you must use them for a tad bit more flair, then yeah, CPU-Z for Windows is a classic, but how about this:
HWMonitor: Gives CPU info and checks your system’s voltages and temperatures—useful only if you’re overclocking or paranoid about your cooling setup.
A lil’ bit of humor for ya’
Funny enough how I’m seeing these commands stacked like a pile of tech-doodles. It’s like having a Swiss Army knife but using the fork end where a spoon will do.
Finally, one tiny caution. When you’re dealing with any command lines or third-party tools, remember:
Caution Points:
  • Always double-check what you’re typing in commands—one typo, and you might end up in a tech-savvy alert!
  • Be cautious with third-party tools; make sure to download them from their official sites to avoid unwanted malware.
So, don’t sweat the small stuff, get your CPU model info the easy route. Avoid diving headfirst into techy rabbit holes unless you’re actually on a rabbit hunt.
Happy installing! :four_leaf_clover:
