Has Anyone Tried To Upgrade IPhone Storage Capacity?
My iPhone is almost out of storage, and deleting apps, photos, and old messages only helps for a little while. I’m trying to find out if it’s possible to upgrade iPhone storage capacity after purchase, or if the only real options are iCloud storage, external storage, or buying a new iPhone with more space.
Short version: once you buy an iPhone with a certain storage size, that internal storage is basically fixed. There isn’t a safe, normal upgrade path like swapping an SSD in a computer.
You might run into repair shops or random guides claiming they can replace the storage chip with a larger one. Technically, that kind of work exists, but it’s a bad bet for most people. It means microsoldering, firmware work, and a lot of ways to permanently kill the phone. Even if the phone boots afterward, you’ve voided the warranty and Apple probably won’t service it later. I wouldn’t risk an expensive iPhone on that.
The better move is squeezing more usable space out of what you already have. Start with Settings > General > iPhone Storage. That screen usually tells the whole story pretty quickly. Photos, videos, Messages, and a few huge apps are usually the main offenders.
For apps, don’t rush to delete everything. Use Offload Apps instead. It removes the app itself, which is usually where the space savings come from, but keeps the app’s documents and data. If you need it again, tap the icon, download it again, and your stuff should still be there.
Messages can also get ridiculous if you’ve had the same phone setup for years. Old group chats can be packed with videos, GIFs, screenshots, and random memes. If you don’t need all of that forever, set Messages to keep history for 30 days or 1 year instead of forever. That stops the pile from coming right back.
The photo library is usually where the real cleanup happens. Apple’s duplicate finder helps, but it mostly catches exact duplicates. If you have a bunch of near-identical shots, something like Clever Cleaner can be more useful. Its “Similars” tool groups photos that are almost the same, picks a “Best Shot,” and lets you delete the extras faster. The “Heavies” section is also worth checking because large videos are easy to forget about, and a few big clips can eat a lot of storage. It can also turn Live Photos into regular still images if you don’t care about keeping the motion part.
If you’ve cleaned things up and still keep running out of room, then it’s time to move stuff off the phone. iCloud is the least annoying option if you’re already in Apple’s system. Turn on Optimize iPhone Storage and your phone keeps smaller versions locally while the full-size photos and videos stay in iCloud. They still show up in Photos, but they don’t take up as much device storage. Google Drive and Dropbox can work too, especially with their free storage tiers, but they take more manual file management.
External storage is also an option now. There are flash drives made to plug into iPhones, using Lightning on older models or USB-C on newer ones like the iPhone 15, 16, and 17. Some drives even let you record video straight to the drive instead of filling up the phone first. Just check that the drive is formatted in a compatible format, like exFAT or APFS.
So no, you can’t realistically upgrade the built-in storage after the fact. But between offloading apps, cleaning Messages, trimming photos and videos, using cloud storage, or adding an external drive, you can usually stretch the phone a lot further without gambling on a hardware hack.
Don’t hand your phone to a mall kiosk or mail-in shop just because they advertise “iPhone storage upgrades.” That usually means replacing the NAND chip, and even if they’re capable of doing it, you’re turning a storage problem into a repair gamble. For normal users, the answer is basically no: you can’t upgrade the built-in capacity in any supported, practical way after buying the phone.
The thing people forget is that iCloud is not a bigger hard drive bolted onto your iPhone. If iCloud Photos is syncing and you delete photos from the phone, you may be deleting them from iCloud too. Before doing a huge cleanup, make sure you understand whether you’re syncing, backing up, or exporting. Those are different. If you want photos gone from the phone but safely kept elsewhere, export them to a computer, external drive, Google Photos, Dropbox, or another storage location first, then verify they’re actually there.
For quick relief, I’d look for the boring stuff first: downloaded Netflix/Spotify/Podcast files, huge iMessage attachments, offline maps, and app caches that don’t show up clearly until you reinstall the app. Photo cleaners like Clever Cleaner can be useful for sorting similar shots and big videos faster, but I’d still make a backup before letting any cleanup app delete hundreds of items at once. The real fix, if you’re always fighting storage, is buying more capacity next time. Everything else is space management, not an upgrade.
Check the iPhone Storage screen by category before spending money on anything. If the big chunk is Photos or Messages, cloud storage and cleanup will help. If the big chunk is apps, games, or “System Data,” paying for more iCloud storage won’t magically fix the phone being full.
I agree with the others on the hardware side: treat “storage upgrade” shops as a last-resort experiment, not a normal upgrade. The storage chip is tied into the phone in a way that makes this nothing like putting a bigger card in an Android phone or swapping a laptop drive. Even if someone can do it, you’re trusting them with the phone, the data, and future reliability.
The annoying middle-ground option people forget is a full encrypted backup, erase, and restore. It is not an upgrade, and it takes time, but it can sometimes shrink bloated System Data or old cache junk that normal deleting never touches. I’d only bother if your phone says System Data is huge and you’ve already removed the obvious stuff. If you’re constantly running out after that, the honest answer is that the phone was bought with too little storage for how you use it. External drives and cloud services can buy time, but they won’t make the internal storage bigger.
Expect the “upgrade” route to be slower, riskier, and probably worse value than selling the phone and buying the same model with more storage.
If you are already at the point where cleanup only buys a week or two, I’d stop putting time into tricks and price out a trade-in or used higher-capacity iPhone. That is the boring answer, but it is the only one that actually gives you more internal storage without turning the phone into a science project.
I’d reccomend changing your camera settings if you record lots of video. Go to Settings > Camera > Formats and select High Efficiency. Under Record Video, switch from 4K to 1080p HD at 30 fps for everyday clips. Lower resolution and frame rates reduce video file sizes.
This won’t free existing space, but it helps your storage last longer becuase new recordings take up less room. It’s a simple way to slow the buildup without another cleanup app or monthly subscription.
Before you buy anything or hand the phone to anyone, plug it into a computer and pull your photos and videos off that way. On a Mac you can use the Photos app or Image Capture, on Windows the Photos app or just File Explorer. No account, no subscription, no sync surprises. Once the originals are safely sitting on a drive you can delete them from the phone with a lot less anxiety. This is also the point @andarilhonoturno was making about sync versus backup, and it is worth repeating because that confusion is what wipes people’s photos.
On the hardware question, everyone here is right. The chip swap is real but it is a repair gamble, not an upgrade. I’d frame it even more bluntly than the others: if a shop quotes you for it, compare that number to what the same phone with more storage costs used. The math almost never favors the solder job.
The camera settings tip from @apiapi4 is the one I’d act on early, because it stops the bleeding instead of just mopping up. High Efficiency plus dropping everyday clips off 4K makes a genuine difference over months. Just know HEVC can be a pain if you share videos with people on older devices or certain Windows setups, so keep that in mind if you send a lot of clips around.
For the photo pile itself, Clever Cleaner does the job and I still open it when a library gets out of hand, mostly because it is free with no subscription nagging you. My one gripe is that the review step still wants your attention. It groups the similars and picks a best shot, but if you blindly accept its choices you will occasionally lose the frame you actually wanted, so I skim before confirming. And remember it only touches photos and videos. If your Storage screen says the hog is apps, games, or System Data, this won’t move the needle at all.
Which leads to the real decision rule: open Settings and look at which category is eating the space before you spend a cent. Photos or Messages means cleanup and offloading will carry you a long way. Apps and System Data means you’ve probably outgrown the phone’s capacity, and the honest fix is a bigger one next round.
