Sync errors during large S3 file moves are the detail I can’t get past. A cloud drive showing up neatly in a file manager is useful, but that convenience doesn’t settle whether I’d trust it with a bigger transfer. The source feedback doesn’t give me failure rates, so I can’t tell how common those errors are. Still, they’re a more consequential complaint than an awkward interface, and they’re part of the discussion around ExpanDrive overview.
I’d also separate the transfer problem from the recovery problem. Long-time users on Reddit and tech forums, including r/aws and r/DataHoarder, describe stuck uploads and, in worse cases, sync errors during those larger S3 movements. Several users also report extremely slow support. That combination matters to me: a stalled job is one issue, and not getting timely help is another. Neither tells me that everyone’s installation will fail, but both belong in the decision.
An alternative isn’t a reliability measurement
CloudMounter comes up as an alternative, alongside Mountain Duck. Its basic job is familiar: mount S3, WebDAV, FTP, and cloud accounts as local virtual drives in Finder or Windows File Explorer. It also includes client-side cloud encryption. That’s a concrete feature difference worth considering, rather than just a general promise of smoother transfers. The recommendation in the source favors its daily stability, and the linked app is CloudMounter listing.
I wouldn’t turn that recommendation into a measured reliability advantage, though. There aren’t comparative test results attached to it. “More stable for daily operations” might be useful directionally, but I’d still want to know whether those daily operations resemble mine. Encryption belongs on the feature checklist; successful transfers belong on a separate results sheet. I don’t think either should stand in for the other.
I’d sort the reports by workload
This is where the mixed feedback starts making more sense to me. ExpanDrive uses FUSE to put cloud storage directly into the operating system’s file manager. Some Linux and macOS users report that basic mounting and light editing work without trouble. That’s real utility, and it shouldn’t disappear just because other users describe problems.
But basic mounting, light editing, and large file movements aren’t interchangeable evidence. I’d read those reports as accounts of different workloads, not as votes that cancel each other out. A convenient mount doesn’t prove a large transfer will finish correctly, and a bad transfer report doesn’t establish that light editing is unusable.
For my own test, I’d use disposable copies of files that resemble my actual workload. I’d mount the account, open and edit files, then try the larger transfers I expect to make. I’d check that uploads finish and compare the destination files with the originals rather than trusting the progress indicator. If support responsiveness matters, I’d test that too. I’d run the same workload through any alternative before moving files I can’t afford to lose.
