Dividing GPT-Dot Work on a Small Team Without Duplicating Effort
I’m using GPT-Dot with a seven-person team on a shared project, and we’re having trouble keeping ownership clear once someone else picks up an unfinished task. We started by assigning work by deliverable, but we’ve already had overlapping revisions and uncertainty about which result was ready for review.
How do you divide GPT-Dot work on a small team: by deliverable, by stage, or with someone coordinating handoffs? I’m especially interested in what you record when passing work to another person. We can keep a separate task log, but I’d rather not require everyone to document every interaction just to make a handoff understandable.
Make ownership transfers explicit. I’d keep an owner for each deliverable, use stages as status labels, and name a reviewer. Someone helping with revisions shouldn’t automatically become the owner. If they’re taking over, have them acknowledge the handoff in the task log before editing. I wouldn’t appoint a coordinator unless tasks keep sitting unclaimed.
For the handoff, I’d record only what the next person needs to continue: the current owner, the exact working file or saved result, its status, the next action, and any decision they shouldn’t accidentally undo. Something like: “Draft complete, not ready for review. Use the saved draft attached here. Check the unsupported claims in the opening section. Keep the agreed scope. Return to the assigned reviewer after those checks.” Include a prompt or conversation excerpt only when it contains a constraint that isn’t captured elsewhere. No need for an interaction diary.
I’d make “ready for review” apply to a specific saved version, rather than the task in general. Once that version goes to the reviewer, keep further experiments separate until review finishes. That gives you a clear answer to “which result am I reviewing?” without asking anyone to reconstruct the whole conversation.
People will step away mid-task, so your handoff process needs to work without both people online. I’d keep @nina_x’s task log, but agree in advance on when someone can take over an unattended task without waiting for permission. The returning owner needs to check that log before resuming, or you’ll still get duplicate work despite documenting the transfer.
Put the exact remaining work in each handoff, not just the new owner’s name. @nina_x’s takeover rule handles who can step in, but “check the totals; leave the approved draft alone” gives the next person a much clearer boundary than “finish the report.”
Be wary of duplicated work and its potential concealment beneath different deliverable names. A presentation and a written report can both have their own owners while two people work independently on the same comparison table. Explicit handoffs will miss this kind of duplication as nobody is aware that they are taking over somebody else’s work.
@nina_x’s distinction between helping and owning makes sense. I’d keep that, but check whether your deliverables share unfinished inputs. If they do, assigning ownership only at the deliverable level leaves a gap. Someone needs responsibility for the shared input, while the deliverable owners remain responsible for how they use it. That’s a different boundary from deciding who edits next.
For example, if a proposal and an internal briefing both need to make the same set of assumptions, turn this into a shared task rather than concealing the work to generate and capture these assumptions inside both deliverables. The owner of the proposal can request a change or flag a problem with the assumptions without initiating a competing set, and taking over the assumptions task does not make whoever does so the owner of either document.
There is no need to capture every relationship in the project. I would factor out a shared task only for an output that is used in more than one deliverable and requires judgment or substantial work to generate. A common heading style probably does not need an assignment, but a comparison that all users of the document must agree on likely does. Indicate the relationship on each dependent task with a short note such as ‘Uses the assumptions task; waiting on the cost basis.’
This also affects the interpretation of ‘pick up an unfinished work’. Before continuing an unfinished deliverable, determine whether the missing work should have been part of the task or generated inside the document. If the former, contribute or take over the shared task and follow the agreed upon handoff rule; do not make changes that complete the task as if they belong inside your private deliverable just to unblock your own process. If you require a temporary assumption to continue working, make it clear that this is a provisional addition that should not be adopted as an official answer.
The most annoying edge case of this pattern is a shared input that is changed without the knowledge of those who used it. I would make the notification of change part of the dependent task, letting those who used the output decide whether they need to make changes of their own. This way, the manager of the shared task does not need to examine every document that uses its output, and users are not allowed to assume that they can see every change as they would if the shared task was part of their own document.
Before adding a new coordination role, scan the existing assignment list for opportunities to factor out common research, calculation, or decision tasks. These are often present even in well-structured assignments, and will produce benefits even if every ownership transfer is captured in assignments.
Don’t let an inactivity rule turn a blocked task into an abandoned one. I’d be cautious about @turbogurux9720’s suggestion unless your team distinguishes “nobody is working on this” from “the owner is waiting for an answer.” Otherwise, someone can take over, repeat the same investigation, and hit the same obstacle with a different name on the assignment.
Before taking over, I’d want a short note explaining why work stopped. “Waiting for a decision on which customer group we’re targeting” calls for a different response than “I’m out this week and haven’t started.” For the blocked task, name whoever needs to answer and write down the question. A teammate can help get that answer without inheriting the deliverable or producing an alternative draft based on a guess.
That leaves a useful middle option between waiting and taking ownership: help remove the blocker. If the reason for the pause is missing, I’d make checking that the first action, rather than immediately continuing the draft. Explicit transfers still matter, but I’d reserve them for cases where changing the person doing the work will actually let it move forward.
Every rule here adds a note someone has to read before touching a task, and in a seven-person group those notes quietly stop getting read. @datapilot5049’s shared-input idea is the one I’d actually keep, since catching duplicated work saves more than any handoff log does. Just don’t pile on so much logging that checking it becomes the thing people skip.
“Unfinished” is too vague. As someone picking up the task, I’d be confused if I could see who owned it and where the draft was, but not what would make it complete. Am I filling a gap, or am I supposed to keep improving everything until I’m happy with it? That could send me back through work the previous person considered settled, even with a clear handoff.
I get @just_raven’s concern about extra notes, so I’d put a short completion condition in the original assignment rather than ask everyone to write more history. Something like “Compare the options against the agreed requirements and explain the recommendation.” Then the person taking over can check what’s missing against that target. If they think the target itself needs changing, that’s a question for the team, not an automatic reason to start over. I’d find that more useful than a detailed account of how the draft got there.
