I just got a pair of AirPods and I can’t figure out how to turn on noise cancellation or tell if it’s working. I’ve tried changing settings on my iPhone, but outside noise still comes through, and I need this feature for commuting and work calls. Looking for simple steps to set up AirPods noise cancellation correctly.
If noise canceling isn’t doing much, first make sure your AirPods even support it. Only AirPods Pro, AirPods Pro 2, AirPods 4 with ANC, and AirPods Max have Active Noise Cancellation. Regular AirPods 1, 2, 3 do not.
How to turn it on:
- Put both AirPods in your ears.
- On iPhone, open Control Center.
- Press and hold the volume slider.
- Tap Noise Control.
- Pick Noise Cancellation.
Faster way:
Press and hold the force sensor on the AirPod stem until you hear a chime. It switches between modes.
How to check if it’s working:
- You should hear a soft change in background noise, like fans, AC, road hum.
- Voices and sudden sounds still come through some. ANC cuts steady low noise best.
- Try it near a fan or airplane-style hum. That’s where it works best.
If it still seems weak:
- Check fit. Wrong ear tips ruin ANC. On iPhone, go to Settings, Bluetooth, tap your AirPods, Ear Tip Fit Test.
- Clean the mics and speaker grilles.
- Make sure both AirPods are in. ANC is worse with one out.
- Turn off Adaptive Audio or Transparency if those are on.
- Update firmware. Put AirPods in case, plugged in, near your iPhone on Wi-Fi for 30 mins.
- Reset them if needed.
One more thing, ANC does not mute the world. It reduces noise. It won’t erase people talking next to you. If outside sound is pouring in, it’s often a fit issue or you’ve got regular AirPods by mistake. Kinda dumb naming by Apple tbh.
One thing I’d add to what @suenodelbosque said: try toggling Off, Transparency, and Noise Cancellation back to back while standing near a constant noise source, like a bathroom fan or car AC. That makes the difference way more obvious. If you’re testing with talking or TV, ANC can feel kinda underwhelming becuase it’s just not magic for voices.
Also, I slightly disagree on firmware being the first thing to worry about. Usually if ANC feels nonexistent right away, it’s more often one of these:
- You only have one bud in
- The seal is bad even if the tips feel “comfortable”
- Personalized Spatial Audio / Adaptive stuff is making it seem less clear what mode you’re in
- You accidentally bought standard AirPods and Apple’s naming made this dumb lol
Another check: go to Settings > your AirPods and see whether Noise Cancellation with One AirPod is enabled or disabled. Sometimes weird mode behavior happens there and people don’t realize it.
And if you want to be really sure it’s on, use one finger to lightly tap the outer part of the AirPod while switching modes. You can often feel the pressure change in your ear a little. Sounds weird, but it helped me figure out mine werent broken.
Before chasing settings, make sure your AirPods model actually supports ANC. Regular AirPods do not. Only AirPods Pro, AirPods Pro 2, AirPods 4 with ANC, and AirPods Max have it. That’s honestly the first thing I’d verify, and I’d put that ahead of some of the deeper troubleshooting.
A couple checks I haven’t seen stressed enough, even with @suenodelbosque covering the basics:
Clean the microphones and speaker mesh
Earwax or pocket lint can wreck ANC fast. Even a partial blockage makes outside sound leak in more than you’d expect. -
Disable Adaptive Audio temporarily
If your model supports it, Adaptive can make it seem like ANC is weak or inconsistent because it blends modes. Set it specifically to Noise Cancellation while testing. -
Check ear tip size again
Not just comfort. Try every size for 30 seconds each in a noisy place. The “wrong but snug” tip can outperform the “comfortable” one. -
Test with low steady noise
Plane cabin hum, fan noise, bus rumble, HVAC. ANC shines there. It will not erase voices completely. -
Reset the AirPods
If modes seem glitchy, forget them in Bluetooth settings, put them back in the case, hold the setup button until the light changes, then pair again.
Pros of AirPods ANC: great for droning background noise, easy mode switching, strong iPhone integration.
Cons of AirPods ANC: weaker against voices, fit-dependent, can feel subtle if you’re new to ANC.
If none of that changes anything, there’s a real chance you got a non-ANC model or a defective pair.
For a simpler check, skip teh settings menus and use your AirPods’ controls.
On AirPods Pro or AirPods 4 with ANC, wear both earbuds, then press and hold either stem until you hear a chime. On AirPods Max, press the listening mode button on the right ear cup. These controls switch listening modes.
Pause your music and compare the sound before and after switching. Listen for a differnce rather than complete silence. If you still hear no change, ask Apple Support to walk you through a live check before trying more resets.
Testing ANC in a silent bedroom versus testing it on a bus tells you two completely different things. In the quiet room you might swear the feature is dead, because there’s almost nothing steady to cancel and all you notice is a faint plugged-up pressure feeling. On the bus, the low rumble drops out and suddenly it clicks. So before anyone resets or reflashes firmware, figure out which of those two situations you were actually in when you decided it ‘wasn’t working.’
That’s my main gripe with a lot of the advice here. It’s all technically correct, but people keep testing against the wrong kind of noise. @suenodelbosque and @viajanteodoceu both nailed that voices leak through, and honestly that’s where most new users get fooled. You put them in, someone’s talking near you, you still hear them, and you assume the feature is broken. It isn’t. It was never going to erase a human voice a few feet away.
Where I’d gently disagree with @viajeroceleste is the back-to-back toggling near a fan. It works, but it can also trick you, because your brain adapts fast and by the third switch you stop noticing the gap. If you want a cleaner read, sit with Noise Cancellation on for a solid minute in a noisy spot, then yank one bud out. That contrast is way harder to fool yourself on than rapid switching.
The seal point deserves more weight than the settings stuff, though. If outside sound is genuinely pouring in, nine times out of ten it’s fit, not software. And the Ear Tip Fit Test is not the final word here. It can pass you and the seal can still be mediocre if your ears aren’t symmetrical or you talk and shift the buds around. Try going up a tip size even if it feels slightly too big at first. A snug tip that feels a touch aggressive usually seals better than the ‘comfy’ one that lets air sneak past.
One thing nobody flagged: if you feel zero ear pressure at all when switching to Noise Cancellation, that’s a real signal. Working ANC creates a slight sensation like your ears are being sealed. No pressure change plus outside noise leaking usually means either a bad seal or you’ve got a non-ANC model, which the naming makes way too easy to buy by accident.
