Best AI Tools — What Would You Recommend?
I’m trying to choose an AI tool for a small side project where I need to summarize a 37-page PDF, turn notes into clear emails, and occasionally organize spreadsheet data. I’ve only tried the built-in chat feature in one app, and I’m not sure whether I should be looking for a general-purpose assistant or separate tools for each task.
What are the best AI tools for this kind of mixed use? I’m also confused by terms like models, agents, context windows, and local versus cloud processing. Which of those differences actually matter for handling documents and routine office work without a complicated setup?
I compared the options by assigning each one a single practical job, then checking what it accepts, what it produces, and how much follow-up work its description suggests. That kept the comparison consistent across 20 tools in 20 categories, even when the categories themselves had little in common.
Research, writing, and information
For general work, 1. ChatGPT covers brainstorming, explanations, writing, and everyday problem-solving in one conversation. For longer material, 2. uploaded documents can be summarized, questioned, drafted around, and revised in Claude’s workspace.
Source visibility separates 5. give Perplexity a look from a plain chatbot, since its conversational search includes supporting links. Academic work is the narrower job for 6. Elicit’s research tools, which find papers, summarize findings, and extract details into structured tables.
For editing, 7. the Grammarly writing assistant checks grammar, spelling, clarity, and tone, with rewrites for larger problems. Translation is handled by 8. DeepL, which processes text and documents into supported languages for later review.
If work already lives in one workspace, 9. Notion AI features can search notes and connected apps, then create summaries or documents.
I’d treat detection cautiously. The 3. Clever AI Detector checks up to 10,000 words, allows unlimited runs without registration, gives an overall AI probability, and highlights sentences, but those estimates aren’t proof of authorship. For revision, 4. Clever AI Humanizer handles up to 3,000 words per run with no monthly word cap, targets repetition and uneven flow, preserves meaning, and can save history through an optional account.
Visual, audio, and presentation output
For slides, 10. you can start a deck in Gamma from prompts, outlines, or existing content, then edit the layout. Image work splits between 11. Adobe Firefly, which generates and edits visuals for use across Adobe apps, and 12. Ideogram editing tools, which put extra attention on typography for posters and promotional graphics.
Motion is covered by 13. Runway’s creative tools, using prompts and reference images for video clips. Scripted presenter videos are the job for 14. Synthesia, including generated voiceovers for explainers and instruction without filming someone.
For audio, 17. the ElevenLabs voice platform generates speech, voices, narration variations, and dubbing. Music descriptions become vocal songs or instrumentals through 18. Suno, letting you test genres, moods, and ideas without arranging from scratch.
Building and ongoing work
Development is split between 15. the Cursor editor, which explains projects and proposes cross-file edits from plain-language requests, and 16. v0 by Vercel, which turns a website or app description into an initial implementation for preview and revision.
After meetings, 19. Otter’s meeting assistant provides transcripts, summaries, and action items without requiring a full replay. For connected processes, 20. Zapier automation tools can summarize incoming information, categorize it, and route the result between apps.
I’d change these category picks if side-by-side task results showed another tool producing more accurate output, requiring fewer corrections, or handling the same workload with less friction.
The hidden cost is file cleanup: scanned PDFs and messy tables can trip up any chatbot. I’d start with ChatGPT for all three tasks, then try Claude only if document summaries are the weak spot.
Don’t upload the PDF until you’ve checked it for client names, financial details, addresses, or anything else you would not want stored outside your own system. Privacy settings and data-retention rules vary, and that matters more than a small difference in summary quality.
For this project, I would start with ChatGPT rather than build a collection of specialized tools. Ask it to produce a short overview, a section-by-section outline, and a list of claims that need verification. Requiring page references is useful because polished summaries can still omit a qualifier or attach a conclusion to the wrong section. @deep_proxy899 is right about scanned pages too. If you cannot select the text normally, run OCR first or expect errors.
Email drafting is straightforward, but give the model the recipient, desired tone, purpose, and required action. “Turn these notes into an email” often produces a padded, generic message. “Write a direct email to a supplier, keep every date, and end with a request for confirmation” tends to produce something you can actually send after editing.
I would be much more cautious with spreadsheet work. Never let an AI reorganize your only copy. Duplicate the file, describe the intended structure, and ask it to explain the proposed columns, formulas, or cleanup rules before applying anything. Missing rows and converted dates are easy to overlook when the final sheet looks tidy.
The broad tool list is useful for larger workflows, but it is probably too much for a side project. Switching between services creates its own work, especially when each tool needs the same context entered again. Use one general tool for a week, note where it causes real friction, and only add a second service for that specific failure. Claude would be the next one I’d compare if the PDF work becomes the main task, but I would not start by paying for several overlapping subscriptions.
If the spreadsheet contains formulas, merged cells, or linked tabs, the answer changes. A chatbot can analyze a clean table, but “organize this workbook” is an underspecified request and may alter relationships you did not realize were important. For anything beyond a basic list, use the AI inside Excel or Google Sheets, where you can inspect changes in context and undo them.
For the PDF and email work, either ChatGPT or Claude should cover the project without much setup. I would choose based on which one follows your requested output format more reliably. Give both the same document and ask for a summary with a fixed structure: purpose, major conclusions, open questions, and a table mapping each conclusion to its page or section. The better tool is the one that returns usable references and admits when the document does not support a claim, not the one that writes the smoothest paragraph.
My mild disagreement with the “single tool for everything” approach is that spreadsheet editing is a different type of task. Document summarization and email drafting produce text that is easy to review. Spreadsheet changes can silently affect data types, formulas, and row relationships. I would use the general AI to write cleanup instructions, formulas, or a transformation script, then apply those inside the spreadsheet program rather than repeatedly exporting and importing files.
For emails, save a reusable prompt instead of judging tools by random drafts: “Convert these notes into a concise email. Preserve names, dates, amounts, and commitments exactly. Do not invent missing details. Put unresolved items in a short questions section.” That will improve the result more than switching among several similar services. The practical choice is one document-capable assistant plus the spreadsheet software you already use, with the AI acting as a helper rather than the system of record.
Do not let the chat thread become the only place where your summaries, email drafts, or spreadsheet rules exist. AI conversations are useful workbenches, but poor project archives. Save final outputs in ordinary formats such as DOCX, Markdown, or CSV, and keep the original files untouched.
I’d compare ChatGPT and Claude using a small sample from your actual workload, but score the whole process rather than judging which response sounds smarter. Can you get a summary with usable page references? Does the email preserve every name, date, and commitment? Can you move the spreadsheet result back into Excel or Google Sheets without rebuilding the formatting? Include one correction round too. Some tools produce an impressive first answer, then become frustrating when asked to revise only one section without changing everything else.
My practical choice would be whichever general assistant handles the PDF and email test with less cleanup, paired with the spreadsheet program you already use. Keep the AI focused on proposing formulas, column structures, and cleanup rules rather than owning the workbook. If one assistant wins two of those tests and exports cleanly, that is enough for a side project. Chasing a separate “best” tool for every task usually creates more file shuffling than value.
The missing detail is whether the PDF relies on charts, footnotes, or appendices. If it does, a smooth chatbot summary may quietly miss the actual point. I’d use NotebookLM for the document, then keep email and spreadsheet work inside your existing office suite. Less elegant than “one tool for everything,” but less likely to turn a chart into creative writing.
Summarizing a PDF you’ll act on is a different job than summarizing one you just need the gist of. For the first kind, keep the original open beside the summary and treat the AI output as an index, not a replacement, since the whole point is jumping back to the source. For a throwaway skim, none of the careful page-reference stuff earlier in the thread really matters, so don’t burn time on it.
Before picking any tool, drag-select a paragraph in the PDF. If the text highlights cleanly, skip the upload and just paste the sections you actually care about, since raw text dodges most of the layout parsing junk a file upload introduces. @smartrunner453 has a point on the charts though, those never survive a copy-paste, so keep the original open for anything visual.
