Go Back Benchmark Reviews Discussion Forum > Software > Operating Systems
Operating Systems Discuss the latest bug, patch, or new release in this section.
Reply
Thread Tools Display Modes
#11
Unread 15th October 2010, 09:50 PM
Olin Coles's Avatar
Executive Editor
What I mean is that ever since Windows 2000, you've had to copy Windows installation discs as an ISO or comparible disc image format. I used DVD Dycrypter to create ISO files for Windows Vista and Windows 7, and burned copies from the save file.
__________________
#12
Unread 16th October 2010, 09:43 PM
Daryl Greene Daryl Greene is offline
Gigabyte
Send a message via ICQ to Daryl Greene Send a message via AIM to Daryl Greene Send a message via MSN to Daryl Greene Send a message via Yahoo to Daryl Greene Send a message via Skype™ to Daryl Greene
I know what you said. I just never did anything of the sort before with my Windblows XP install disk.
It does suck that there's nothing to be done to make what I do have useful. I would like to get Win7 installed and running. But, at the moment, I settled for XP pro x 64. That is, if it doesn't give me problems and I decide to scrap it.
#13
Unread 17th October 2010, 12:32 AM
Steven Iglesias-Hearst's Avatar
Steven Iglesias-Hearst Steven Iglesias-Hearst is offline
Contributing Editor
Quote:
Originally Posted by Olin Coles View Post
Point taken. Download a trail version of Alcohol 120%, or Nero Burning ROM. Both will work extremely well for making a disc image in only a few basic steps through the main menu.
Do what Olin said with the files you already have. Should work oki.
Copy from DVD to desktop, use a burning program to make them into an .ISO, burn that .ISO image to a DVD (remembering to make it bootable).
or
If you have an 8GB or bigger flash drive you could allways Make a bootable USB installer for Windows XP, Vista, 7 with WinToFlash
__________________
#14
Unread 17th October 2010, 09:24 PM
Gigabyte
Steven,
i tried that with Nero. I made the files into an .iso and burned it with Nero, but didn't see anything that allowed for me to make it bootable. Maybe I missed something.
EDIT: I installed XP 64 bit edition a couple days ago and decided to try the .iso thing with the disk I have. Funny thing is that I put it into the dvd drive and it works! What the.......? Guess I'll have a go at installing it. Let you guys know what happens later. Though I still need a bootable copy of this disk for future incidences.
#15
Unread 17th October 2010, 09:59 PM
Olin Coles's Avatar
Executive Editor
You can't just make a bad Windows CD/DVD copy into a bootable ISO. You need the original CD/DVD with boot files to do that, unless you're willing to search them down on the web.
__________________
#16
Unread 18th October 2010, 01:08 AM
Gigabyte
The DVD I have has a boot folder and, I assume, everything else that was on the original disk. I just don't know how to make what I have bootable.
Remacno said that he read where a lot of people were having issues with the 64 bit win7. Now I am wondering if it is an issue trying to do it from within windows. I get the feeling that it won't run that way on a 32 bit win OS, since it ran on mine after installing XP 64.
BTW, it installed just fine for me after it started up. On win7 now working on all my programs.
Sponsored links
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Remove advertisements
