Go Back Benchmark Reviews Discussion Forum > Hardware > Computer System Hardware
Computer System Hardware If it belongs inside the computer, you can discuss it here.
Reply
Thread Tools Display Modes
#11
Unread 18th March 2013, 08:28 PM
Remacno's Avatar
Remacno Remacno is offline
Gigabyte
Send a message via MSN to Remacno
So then the only other thing that it could be is the motherboard. Guess I will need to give that a shot.
__________________
Cameron Greene
#12
Unread 19th March 2013, 02:29 PM
Remacno's Avatar
Gigabyte
Can you suggest a motherboard for a mid tower build that would support both an AMD Phenom 2 3.2 processor with DDR3 RAM for a decent price? Somewhere between $50 and $100.
The one that I have is a small board, doesn't fit properly in the case. Had to place a rubber stud to support one corner of the board.
__________________
Cameron Greene
#13
Unread 20th March 2013, 09:02 AM
Olin Coles's Avatar
Executive Editor
I would use the Newegg power search feature to narrow your options. I'm not familiar with AMD offerings, so that's probably your best resource.
__________________
Sponsored links
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Remove advertisements
