Go Back Benchmark Reviews Discussion Forum > Benchmark Reviews Forum > Off-Topic Discussions
Off-Topic Discussions If it doesn't fit in another section, it probably belongs here. Keep discussions civil and respectful.
Reply
Thread Tools Display Modes
#11
Unread 10th August 2009, 07:11 AM
RagingShadow07 RagingShadow07 is offline
Terabyte
Send a message via MSN to RagingShadow07
Quote:
Originally Posted by Daryl Greene View Post
I couldn't get that screensaver to work right either!
It started throwing up an error message at me after running it once. Did it do the same for you?
__________________
_______________________________________
"Don't fix what isn't broken; Just upgrade it."
#12
Unread 10th August 2009, 09:03 AM
XJnine XJnine is offline
Gigabyte
Send a message via ICQ to XJnine
Quote:
therefore I'm seriously considering using Win7 Premium as my main OS with XP as a dual boot option, beginning somewhere around X-mas
If you go with Windows 7 Pro or Ultimate you'll be able to use the new XP mode and negate the need for dual booting. http://www.microsoft.com/windows/vir...c/default.aspx
__________________
Asrock Z68 Fatal1ty mobo
Intel Core i7 2600k CPU @ 4.8ghz
Noctua NH-D14 HSF
2x PNY GeForce 680 GTX SLI
32gb G.Skill Sniper DDR3 1866 @ 2133
2x Samsung 840Pro 256gb SSD's, Raid 0
2x Seagate Barracuda 3tb HD's, RAID 1
Vertex 4 128gb SRT Cache Drive
Memorex MRX-800 Blu-Ray drive
Corsair 1000 watt power supply
Fractal Design Define XL R2 Case
Dell U3011 30" monitor
#13
Unread 10th August 2009, 10:31 AM
Mathew Thompson Mathew Thompson is offline
Megabyte
Quote:
With the ease of using Virtual software, such as VirtualBox or the free version of VMware, there's been little need to dual boot OSes for a while.
#14
Unread 10th August 2009, 01:40 PM
Gigabyte
I agree however the XP mode built into Windows 7 is quite a bit slicker and easier to use. I've been using it for a while and I love how XP apps run as if they're native Win7 apps, you can't really tell that you're virtualizing them. Is that a word?
__________________
Noctua NH-D14 HSF
#15
Unread 11th August 2009, 01:56 AM
Olle P Olle P is offline
Terabyte
Quote:
... XP mode built into Windows 7 is quite a bit slicker and easier to use. I've been using it for a while and I love how XP apps run ...
As mentioned XP mode come only with the two most expensive versions of Win7, and since I'm buying a full version of the OS the extra cost for this feature will most probably be prohibitive.
Furthermore the jury is still out on exactly how well it interacts with software written for MS-DOS, Win3 or Win95... Mind you, I'm having trouble getting these softwares to run properly in XP.
Virtual OS is the other option that's been discussed. I have no experience with this and don't know what's required in terms of hardware, software, licenses, etc. The same compatibility questions as for XP mode applies as well.
What I do have is a straight XP Home OEM license, planning to add a Win 7 Premium full license.
Cheers
Olle
#16
Unread 12th August 2009, 02:43 PM
Megabyte
I'll just wait for a technet event. I got a free copy of Vista Ultimate last summer and I don't feel like paying for an OS
Sponsored links
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Windows Live issues on Windows 7... Remacno Programs & Applications 5 15th October 2010 03:37 PM
Download Windows XP Service Pack 3 Olin Coles Operating Systems 8 8th February 2010 02:29 AM
Windows 7 House Parties XJnine Off-Topic Discussions 7 26th October 2009 08:41 AM
A couple useful Windows 7 links XJnine Operating Systems 0 24th October 2009 05:40 PM
Help: Restarting Windows XP kevbin20 Operating Systems 2 12th May 2008 02:33 PM
Remove advertisements
