Go Back Benchmark Reviews Discussion Forum > Hardware > General Hardware Forum
General Hardware Forum Discuss anything and everything hardware related here.
Reply
Thread Tools Display Modes
#11
Unread 15th October 2008, 12:10 PM
Matt Williams Matt Williams is offline
Kilobyte
If you're looking for another drive, I've heard good things about the Seagate ST3640323AS
Edit: I did some more checking and this drive doesn't have the greatest access times. Read and burst speeds are decent though.
http://www.hardforum.com/showthread.php?t=1342467
My personal drive of choice is the WD6400AAKS. They're fast, and I haven't had any failures yet, although I don't know how they'd perform in a server environment.
#12
Unread 24th June 2010, 01:39 AM
Austin Downing Austin Downing is offline
Contributing Editor
I have 2x1.5 7200.11 in my personal server, and 1x1.5 7200.11 for a video editing rig, and they are going strong hopefully i will have 2 more 1.5 by the end of summer
#13
Unread 25th November 2010, 01:30 AM
Daryl Greene Daryl Greene is offline
Gigabyte
Send a message via ICQ to Daryl Greene Send a message via AIM to Daryl Greene Send a message via MSN to Daryl Greene Send a message via Yahoo to Daryl Greene Send a message via Skype™ to Daryl Greene
Slightly OT but, with a 2TB drive, would you format it as a single drive or break it into several virtual drives?
#14
Unread 1st December 2010, 04:54 PM
Gigabyte
Well, I guess no one has an opinion on my question?
#15
Unread 6th December 2010, 06:41 AM
Olle P Olle P is offline
Terabyte
Quote:
Depends on the use. If it's your only physical drive, then multiple partitions help keeping things tidy. (I use one partition for the OS, one for programs and one for file storage.)
Cheers
Olle
#16
Unread 6th December 2010, 04:31 PM
Gigabyte
The HDD is one of those 5900rpm Seagate drives. Seems to work decently. just don't know if it will slow it down after I get a large amount of data stored on it. Right now I only have about 27GB stored on it so it seems to run pretty quick.
I always heard that breaking a large drive up made accessing information stay at a faster rate. Sounds hokey to me, but who knows? Never played with the different possibilities to see.
#17
Unread 6th December 2010, 08:16 PM
Bruce Normann's Avatar
Bruce Normann Bruce Normann is offline
Senior Contributing Editor
I just did two partitions: one for the OS and then the rest. The performance boost is real. I didn't test mine, I let other people do the testing.... Then I just applied their knowledge. Make sure you choose a decent size for the OS partition. It gets real messy if you need to adjust the partition size. OTOH, the smaller you make it, the faster it is....
Honestly though, the best bang for the buck is a $90 SSD as the boot drive. You won't believe the difference.
__________________
Men wanted for Hazardous Journey,
small wages, bitter cold,
long months of complete darkness,
constant danger, safe return journey doubtful.
Honour and recognition in case of success.
Ernest Shackleton
#18
Unread 7th December 2010, 12:05 AM
Terabyte
There is, at least in theory, a real performance boost based on the fact that the reading head won't have to travel that far between the endpoints of the partition, thus somewhat reducing the read/write times.
The actual performance boost depends on two factors:
1) How much data fragmentation is there?
The performance boost compared to a bigger partition is somewhat proportional to the level of fragmentation. With frequent (weekly or more often) defragmentation runs this shouldn't be a problem in the first place.
2) How often does the head have to switch between partitions?
If it has to constantly alternate between partitions the result might be reduced rather than increased performance.
Cheers
Olle
Sponsored links
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Vista Home Premium to 7 Home Permium Install FAILURE iapmc424 Operating Systems 5 29th October 2009 11:49 AM
Seagate Barracuda XT 6Gbps SATA-III HDD Preview Olin Coles Article & Review Forum 0 20th September 2009 11:25 PM
Seagate Interview: SSD and Enterprise Storage Olin Coles Article & Review Forum 0 20th September 2009 11:06 PM
Year In Review: 2008 Computer Hardware Industry Failure Olin Coles Article & Review Forum 13 28th January 2009 08:24 AM
Remove advertisements
